      07-27-2013, 02:01 AM   #1
alpwhite46
Drives: 2013 X3 35i Mpkg
Antenna won't come off?
My Z4 came with a stubby antenna ready to be put on, but for the life of me i can't get the old one off.
I just tried applying wd40 to the base and letting it sit and still nothing.
      07-27-2013, 02:24 AM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Never heard of that issue before. Perhaps try a heat gun? Or let it sit in the sun? It should unscrew very easily.
      07-27-2013, 03:09 AM   #3
THE JEDI
Drives: 2005 Z4 2.5i
grip pliers...really really slow
      07-27-2013, 03:39 AM   #4
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
A friend showed me a trick awhile ago for unscrewing things. Find a fat rubber band and wrap it tight around the antenna a few time and it gives you better grip to twist the atenna off. Same thing works on jars and such. This might work, or some grip pliers.
      07-27-2013, 06:27 AM   #5
GammaZeta
Drives: 1
Pull harder.
      07-28-2013, 01:12 PM   #6
alpwhite46
Nope nothing tried the rubber band and all no luck..
just put some penetrating oil in between teh crack see if that will do anything.
      07-28-2013, 03:02 PM   #7
Nate4641
Nate4641's Avatar
Sounds like its time for 'ole faithful.
      07-28-2013, 03:13 PM   #8
Z4inAZ
Drives: Z4 2.5 03
It likely wasnt screwed on quite enough in the past allowing a thin film of water to penetrate the thread and rust it. Just give it a good amount of effort.
Soft rag around the antennae (if you want to save the antennae) and then pliers, unscrew it left, it should come off
Otherwise the antennae and antennae base are only attached through one torx screw in the trunk. If the antennae is really seized and wont move at all, you can always replace the replace the antennae base too. Just peel back the carpet in the left side of the trunk and you will see a metal box with a gold/copper colored torx screw in the center. Unscrew all the way, and the box will dangle and the antennae assembly can be removed as a whole unit from the top of the car. However this should be a last resort, I think you are just not unscrewing the antennae with enough force.
      07-28-2013, 05:56 PM   #9
Shipkiller
Shipkiller's Avatar
Drives: Me
That metal box is one of the diversity amplifiers...
      07-29-2013, 12:47 AM   #10
Loogey Clapp
Loogey Clapp's Avatar
Drives: 2006 Z4 3.0si
I was wondering if you were trying to unscrew the base instead of just the antennae.
      07-29-2013, 05:23 AM   #11
Shipkiller
Shipkiller's Avatar
Drives: Me
If you just try to unscrew the base, two things will happen.
You are going to scratch up the fender.
Good chance you will damage the diversity amplifier that the base is mounted.
      07-29-2013, 09:53 AM   #12
NSummers
Drives: Z4 3.0i
I underscrew mine from under the trunk, once that whole piece is out, it came out easily, us a ratchet + socket, take a look with flash light..
-Nathan Summers
      07-29-2013, 10:11 AM   #13
Shipkiller
Shipkiller's Avatar
Drives: Me
Z4inAZ is correct in that the screw is a torx, a six or eight, so I do not know how you unfastened the amp from the base with a socket....unless someone else was in there, stripped or broke the OEM screw and replaced it with something else.
also, my previous comment was about just grabbing the base with some pliers and turning... That would be bad.
      07-29-2013, 08:26 PM   #14
alpwhite46
Nope i was not grabbing the base, i was grabbing the actual antenna base ..i grabbed above the gap / base.
      07-29-2013, 09:18 PM   #15
Z4inAZ
Drives: Z4 2.5 03
I grew up in a mostly white area as a kid and I really think my school could have really used a diversity amplifier or two.
jwolf81.00
      07-31-2013, 04:52 AM   #16
Urluz3n
Lackey
Drives: 07 BMW M Coupe
      09-16-2024, 06:45 PM   #17
JB50
Drives: BMW Z4 E89 30i (2010)
Did you do it?
I have exactly the same problem, pliers, mould grips, WD40, it will not unscrew. Did you ever remove it? Thanks
EDIT: I just got it off, even when I relubed it with grease, it still didn't screw in well at the very end, like there is some sort of ribbed mating system to prevent it unscrewing when driving. I used mould grips and a cloth, adjusting the grips to get the best pressure worked.
