11-11-2012, 11:37 AM | #771 |
Rep 5,329
BTW i'll check mine, i installed mine on the cold side of the motor and installed it the inner bodywork down by the firewall, last time i looked it was fine but i will defo check :-) i noticed that the top section of your already appeared to be damaged as mine is quite abit longer than your item.
11-11-2012, 12:15 PM | #772 |
Rep 112
Hi Guys,
Sorry i don't contribute much to Zpost but i stalk it every day especially this thread . Excellent job on your time Rof..er ZStig your a full second and 1/2 faster than me but im not running meth. Your right about the accuracy at the truck stops my car with stock wheels and battery was 3600lb full tank this cant be right. And Beedub is right, our axles are weak this is what happened to my passenger half shaft in second gear under full throttle at around 6500 RPM. ZStig have you sourced out and after market axles yet?
11-11-2012, 01:26 PM | #773 |
Rep 5,329
YUP...... seen a few like this now...... wouldnt expect it to go at high rev situations, more high grip, drag situations.... @ 6500 tq is gradual and linear... talk us through your car and kit bro??? hows it running and hows things?? Meth at this time of year shouldn't make to much difference now..... here in the UK its sub 10 deg C so meth would cause bog situations.... my car runs lovely at this time of year, sadly it only comes out on the sunny, dry days :-(
11-11-2012, 03:03 PM | #774 | |
instagram 997turbotom
286
Rep 7,377
thanks man. You're definitely looking at the right thread, this is where I post EVERYTHING related to my experience What kind of kit are you running on your car? Vt1-445 or VT2-500? If your axles broke running as much power as me, that DOES worry me. Might have to be my next major mod before I upgrade power. I definitely won't run slicks without upgrading my axles I think I'm only getting minor gains from my meth kit. The pump isn't mounted lower than the meth tank, the nozzle can be moved upstream another 6", and I have to get an adapter for my aftermarket check valve so I'm not running TWO check valves. I wanna mount my pump so that the line coming from it, to the nozzle, is as short as possible so it could theoretically kick in faster even though a check valve should keep it pre-loaded..
11-11-2012, 03:27 PM | #775 |
286
Rep 7,377
here's my first run, against an AA tuned 135i. Pretty crappy launch, as you can hear my rpms drop a little. The 2-3 shift was freaking instantaneous though! Obviously the exhaust cutouts were wide open, so it sounded like a chainsaw
11-12-2012, 12:04 AM | #776 | |
Rep 112
I only drive the car on sunny dry days as-well,parked for the winter now. Broke the axle last month, ambient temp was around 12*c around 11 pm, out driving having some fun.., got some wheel hop into second then it hooked up and bang. Fixed it myself, got a used half shaft from a 06 M3.
11-12-2012, 02:13 AM | #777 | |
Rep 5,329
we need to look into the DSS axles imo asap.... they were mega money tho ;-) and it requires you sending your stockers in.... :-( really nice to see the FI community growing.
11-12-2012, 02:14 AM | #778 | |
Rep 5,329
so we use the same half shafts as the m3?? i thought they may be slightly shorter, thats good info ;-)
11-12-2012, 03:10 AM | #779 | |
Rep 892
11-12-2012, 06:28 AM | #780 |
Rep 5,329
i agree, its Partly down to wheel hop but extra power surely has to be a contributing factor.... every failure on the z4m platform documented so far has been on an Fi car..... i know it only takes one bout of sever wheel hop and pop But imo.... The Fi guys should be looking at this at some point, its your dragging then you DEFinitely should be looking at an axle upgrade. i will be for sure....... no stone unturned and all that....
11-12-2012, 08:12 AM | #782 |
Rep 5,329
11-12-2012, 12:16 PM | #784 |
Rep 112
Yes same as the M3. DIY not to bad,you need to remove part of the exhaust and sway bar, you defiantly need the right tool to remove the spindle form the hub to get the half shaft out.
11-12-2012, 12:52 PM | #785 |
Rep 112
Beedub Is this what your referring to:http://www.driveshaftshop.com/import-axles/bmw/e46-m3
2001 to 2006 e46 M3 should be the same as our cars according to http://www.realoem.com/bmw/ Please correct me if im wrong.
11-12-2012, 02:12 PM | #786 | |
Rep 5,329
im doing lots of standing starts from the start line of the sprint course.... we'll see if i pop one of these... i'll do some proper checks on these items once the car is in the air next time.
11-13-2012, 03:53 AM | #788 |
Rep 33
Hi guys.
I'm an Italian guy who reads for a long time. My Z4M E85 2006 (call Pina) has: -CFR525 Ess kits (8 psi) -differential 4.10 -EUR catless headers -SS xpipe -Bartoli racing mufflers -AEM Meth kit (start 2psi, full 6 psi) -front 245/35-19 rear 275/35-19 - 505.9 Rwhp 518 Nm (AFR 11.6) I also fear for our drive shafts and when there are jumps do i care. Early photos and chart. Sorry my English much at school. Best regards Gabriele |
11-13-2012, 07:26 AM | #789 | |
Rep 5,329
pics pics ppppppiiiiicccsssss!!!!! 500 rwhp @ 8psi sounds alittle much however!!!!!!! AFR perfect, loved those ess kits with the ASA blowers.... they should have offered it as an option imo!!!
11-13-2012, 10:21 AM | #790 |
286
Rep 7,377
AA said they could hook me up with an ASA blower upgrade if I wanted. $$$ hahaha. too tempting.
pandusr! welcome! sounds like you have a great setup. 500rwhp must be perfect for this chassis. Don't worry about your english. How much torque are you making, and what is the model of your supercharger?
11-13-2012, 01:42 PM | #791 |
Rep 33
Hi and thanks for the welcome.
I also think 505rwhp are many. I kept here the same braked dynamometer, before and after installation, to analyze the difference, and i felt it was a bit rich. Soon i will do more testing. I want to see the performance of the AEM meth kit. Torque is 382 lb/ft (518 Nm). The model of supercharger is ASA TM1-20 HD. Gabriele |
11-13-2012, 01:45 PM | #792 | ||
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
Now that is why you need an ASA! Super expensive, but man, the midrange power band and torque is OUT OF THIS WORLD! I would love to see what AA would do if you got an ASA. That thing be such a blast to drive on the street and track!
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
