11-11-2012, 11:34 PM | #1 |
711
Rep 7,850
Installed - Black ARC-8s on Imola Red and EC-7s on Sapphire Black
A few shots of each.
ARC-8s on Imola Red 8.5 x 18 ET 38 with Pss 245/40/18s, and 9.5 x 18 ET ET 22 275/35/18s. Front is running 2 camber washers, which pushes the bottom of the strut out. But ET 38 works, with about 10-11mm space between rim/tire and strut. I didn't want to deal with potential tire rubbing rear (if we moved up to a square shouldered 275/35 tire), and the 9.5 width, is the measured rim size for 275/35, so the upgrade path is clear. The PSS tires are much better on these size wheels than stock; more lateral stability, and I don't feel them moving now, better traction too. None of the issues I observed running these tires on the stock sized wheels. The lighter wheels seem to make the car a bit more nimble as well (Krissi agrees).EC-7s on Sapphire Black Metallic 9 x 18 ET 42 (5mm spacer) with NT05 235/40/18s, and 9.5 x 18 ET ET 22 265/35/18s. Just as with Krissi's car, I didn't want to deal with potential tire rubbing rear, and the 9.5 width is the measured rim size for 265/35 and 275/35. ET 22 looks pretty darn good. Front is coming in about ET 37 with the spacer (I could probably have gotten away with 3mm), and I added hub extenders just to be on the safe side with this "micro spacer". ET 42 would probably fit a stock setup, but the shimsI'm using push the strut towards the wheel (~ -5mm clearance), so it was a no go. If I go with camber plates next year, and ditch the camber washers, in which case I can probably run the wheels w/o spacers if I wanted to.I really like the look of both wheels (IR/Black is more striking IMO), they're light, and they offer a lot of flexibility. The guys at APEX are great to work with too! Last edited by Finnegan; 11-17-2012 at 02:17 PM.. |
11-12-2012, 11:07 AM | #8 |
Rep 2,784
Welcome to the Apex club! I bought my black ARC-8's back when there was no ET22 offset for the rear wheels, so I'm looking at getting 12mm spacers.
The ride quality degradation could be a result of going to lighter wheels and the wheels following the road more closely. Which do you prefer, the EC-7's or the ARC-8's? Both look good!
11-12-2012, 11:40 AM | #10 | |||
711
Rep 7,850
Thanks!
It's really hard to pick one over the other! I guess I'd say I prefer the EC-7, since it's the one I picked for my car! Can't go wrong with either. If you're after absolute lightness, the ARC-8s run a pound or so lighter. If you want room for a BBK, the EC-7s are probably the way to go--especially up front--as the spoke design leaves a lot more room. I just prefer the "look" of the EC-7 too, it's totally subjective. Quote:
I can say I'm pretty certain the ride quality is a result of the tires, not the wheels. The ride with the 235/40 and 265/35 is actually better than when I had Star Specs in that same size on stock wheels. Krissi's car has the better ride at the moment, but that's a function of the additional rubber that's closer to stock in diameter. IIRC, the rubber acts as a "spring" in terms of suspension, so I guess it's tuned more to the stock springs/dampers. Coils could probably help dial in the ride a bit. (I have a set of stock wheels with stock sized HTRZs, ride is better there too, again, diameter of rubber.) I can't really pick one over the other than easily. I'm leaning towards the EC-7s though, I like the way the spokes flow out with some curvature. Since I picked those for my car, I guess I better like them more! Krissi wanted the ARC-8s. Price is the same for either at this point, so that's not a deciding factor. Krissi really likes the ARC-8s better--it's all about the look you're after. Yup. Going for the totally blacked out look, have more work to do on that! |
11-12-2012, 12:07 PM | #11 |
Rep 2,770
I think both look good but prefer the ARC-8's.
I was considering the 9" front wheel with 245 tire. With your 235 tire you thought you could do it without a spacer but would the 245 tire require the spacer (or your best guess). I thought the wider tire might change how much space is available. I would prefer to avoid spacers. Also, with any spacer fitting requirement, if the wheel was available in the correct offset it wouldn't be needed, correct? |
11-12-2012, 12:24 PM | #12 | |
711
Rep 7,850
The 9" ET42 didn't clear the strut not due to the tire, but due to the wheel rubbing on the strut. The camber washers (2 washers) on my car push out things on the bottom of the strut, which results in less clearance there (I'd guess about 5-7mm less clearance). A 245/40 tire, especially one like the PSS (rounded shoulder) on a completely stock front end (or stock, with camber plates, not washers) will clear the strut, on a 9" ET42. It's been done, look here. Remember the 10" ET25 will probably rub with 275/35 in a square shouldered tire, unless you roll the fenders or run a lot of negative camber, but the PSS (again, rounded shoulder) fits. Otherwise, if you want to run a 275 rear, the 9.5 ET 22 is probably a better choice. (275/35 is about ~2/10" wider on the 10" wheel vs. the 9.5" wheel.) Last edited by Finnegan; 11-12-2012 at 12:30 PM.. |
11-12-2012, 12:44 PM | #13 |
Rep 956
I really like the smooth, sculpted, clean look of the EC-7s, but you really can't go wrong with either. It's a preference, but not one I'd argue for more than 30 seconds. Both are gorgeous.
Any plans for roundels? Or stick with the APEX inserts? |
11-12-2012, 01:16 PM | #14 |
Rep 2,935
Drives: Anything
Imola/Black is starting to grow on me after looking at your pictures. At least you don't have to clean your wheels every week or so from brake dust
11-12-2012, 01:23 PM | #15 | |
711
Rep 7,850
Hear hear! I hate it when the car is still pretty clean and the wheels start to look all dusty. Black eliminates that issue for the most part. It's an added plus. I really do think the black/red is striking, black black is a look, but it doesn't "pop" the way the black/red does. |
11-12-2012, 02:51 PM | #16 |
Rep 2,709
The cars look beautiful! Thank you for posting up the photos. It’s these photos along with reviews and feedback that help others understand easier the complex details of these fitments
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
11-12-2012, 11:43 PM | #18 |
Rep 4,531
Looks awesome!
I'm going to try and get some APEX wheels for a square set-up next year. Attempting to fit 265 up front. We'll see how that goes. |
11-13-2012, 01:51 AM | #19 |
711
Rep 7,850
Thanks Joe and Gernard!
Kgolf, I want to see those 265s up front. It's going to take a lot of negative camber I think, but it can be done. I'm guessing you're going to go with a 9.5 ET35 wheel? |
11-13-2012, 09:09 AM | #20 | |
Rep 4,531
I am probably going to do a 9.5" wheel (don't know about any offsets yet). I know I can squeeze on a 9" wheel, but don't know if 9.5" would be better to get rid of tire squirm. I'm running a 9" wheel know with 265s, so it's easily possible. |
11-13-2012, 09:26 AM | #21 |
Rep 11,667
WOW... I missed these.
Those are great setups. pics are great!!! IDK which I like best
11-13-2012, 12:08 PM | #22 | |
711
Rep 7,850
My thinking these days is that for front wheels, it may be even better to have a .5" wider wheel than the tire's measured rim size. I think that helps manage tread squirm and tire movement, and realizes the full potential of the tire. (Although fitting a 10" wheel on the front isn't really feasible.) Rear doesn't see the same lateral forces, and measured rim size works there. Stock wheels and tires have a .5" wider than tire measured rim size on the front--I think there's a reason for that. Thanks! Tough choice isn't it? Last edited by Finnegan; 11-13-2012 at 12:19 PM.. |
