09-25-2012, 10:51 PM | #1 |
Rep 112
Power steering line failure
Thought i would share this with you guys and gals, I had my expansion line fail ( part #3) right at the banjo bolt #6 on the tubing,There was no strain on the hose or tubing, nothing else was out of place,this maybe a weak spot on the part or just bad luck for me but it is something that probably should be checked during routine inspection. http://www.realoem.com/bmw/showparts...31&hg=32&fg=20
09-26-2012, 03:28 AM | #2 |
///M-fanatic
196
Rep 3,885
Dafuq?! Thanks for the heads up.
Curious if you happened to drive the car with no steering assistance? My MR2 (which was sold earlier this year) had manual steering and it actually felt really nice at the track. Wondering what our cars would feel like with manual steering |
09-26-2012, 06:40 AM | #3 |
Rep 2,002
That is the first time I have seen a failure like that, but it is a known issue as far as weeping/leaks are concerned. Many folks have had that line replaced under warranty.
09-26-2012, 10:56 PM | #4 | |
Rep 112
09-27-2012, 06:48 PM | #6 |
M = Midlife Crisis
67
Rep 2,006
IIRC BMW did a supersession on the part # due to failures in or around 2007. They were known to weep or leak in early Z4M's and e46 M3's.
2006 Z4MC - #LL93158
09-27-2012, 06:52 PM | #7 |
M = Midlife Crisis
67
Rep 2,006
Realoem shows the change in May 2007 in the attached link.
09-28-2012, 10:29 AM | #9 | |
Rep 1,771
Drives: 2007 Z4M Coupe
Found this http://www.m3forum.net/m3forum/showt...power+steering
Gruppe M CAI / Euro Headers / Rogue Engineering X-pipe / RE Diablo Exhaust Last edited by SCHMOUPE; 09-28-2012 at 12:11 PM.. |
09-28-2012, 12:13 PM | #10 | |
Rep 195
09-28-2012, 12:28 PM | #11 | |
instagram 997turbotom
296
Rep 7,381
09-28-2012, 12:54 PM | #12 |
Dark Sider
131
Rep 1,779
Drives: 2008 Space Gray Z4MC
Had mine replaced on the 2006 E85 and on the 2008 E86. Both under warranty, leaking. Common problem I was told on M's.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
09-28-2012, 01:10 PM | #13 |
Rep 1,771
ps the expansion hose by itself is 190 from Tischer. yikes
09-28-2012, 02:33 PM | #14 | |
Rep 238
Is the bracket at the bottom of the 'U' attached to the body of the car? The broken part of the banjo is, presumably, attached to the pump? I wonder if this is fatigue... |
09-29-2012, 08:24 AM | #16 | |
Rep 112
09-29-2012, 08:33 AM | #17 |
Rep 112
It was a Fairly easy job to do,on a stock car should take around 2 hr to do.On my car i had to remove some of the plumbing that went from the SC to the inter cooler and the banjo bolt #6 was a PIA!
09-29-2012, 08:37 AM | #18 |
Rep 112
I pay $235.00 up here in Vancouver,And they didn't even kiss me before they f*cked me.
09-29-2012, 08:40 AM | #19 | |
Rep 112
09-29-2012, 10:27 AM | #20 |
Rep 1,771
I guess that part 3 (expansion hose) is pretty much the culprit for all leaks and failures?!
09-29-2012, 10:29 AM | #21 |
Rep 1,771
You need to get pretty intimate under the car to see the power steering rack and hose and notice the leak. I saw it when I was re-routing my O2 wires. Slow leak but a leak nontheless and I think will replace it next year when the car comes out of storage
09-29-2012, 11:10 AM | #22 |
Rep 195
