04-19-2012, 01:48 PM | #331 |
Hug the road... Carpe Asphalt
106
Rep 722
What is the easiest way to attach this front lip permanently? Remove the front bumper from the car, bolt the front lip spoiler underneath and install the front bumber back onto the car? I have one of these MSTACHE laying around, but have yet to install it...
2007 BMW ///M Coupe
04-19-2012, 02:16 PM | #332 |
Rep 782
having done it, I will will be doing the following after I repair and paint it.
i will lift the car, put it on jacks. get a heat gun heat the double side tape. Affix the tape to the MStache, then heat the double side tape on the other side then affix to the car. then bolt on firmly. Hope fully this will end up better than my previous attempt
2011 30i
[SIGPIC]/SIGPIC] |
04-19-2012, 05:59 PM | #333 | |||
Rep 361
I use the 4 factory screws and then 3M double sided automotive molding tape such as this http://www.sears.com/shc/s/p_10153_1...=SPM5901845408 Make sure the mounting surfaces are clean and that the ambient temperature is warm enough for the tape adhesive to set and you're good to go. The Mstache won't go anywhere if installed properly. Quote:
Thanks, Steve |
04-22-2012, 11:32 AM | #334 |
Rep 782
Well got it done. I uised the glazing putty, sanded and used some black glossy metallic paint and well this is how it turned out. I think it came out pretty good. Thanks for the advice on how to "fix" it Steve
Also. I used some transparent heat/freeze/waterproof silicone in the small gap, just to make sure that water etc doesn't get to the tape. But all in all I think it came out pretty good
2011 30i
[SIGPIC]/SIGPIC] Last edited by ricanbandit; 04-22-2012 at 11:38 AM.. |
04-23-2012, 10:17 AM | #335 |
Rep 446
Drives: 2013 335is
It looks good from here, very nice look, I can't wait to get mine installed.
Regards
2013 335is E93 2018 X5 35d BMWCCA / ZSCCA Member |
05-06-2012, 09:14 PM | #337 |
Rep 381
Hello, I love the Mstache!!! is there a CF version. (with pre drilled holes)
regards and could you put the 3m tape before shipping it out. Im in mexico and it is hard to source the tape here. thanks diego |
05-07-2012, 03:54 AM | #338 |
Rep 446
Drives: 2013 335is
Finished and installed. Bruce came up with support clamps on the front. We used 2 screws per side, three clamps in the middle and the double tape across the whole thing. It ain't coming off unless it gets ripped off.
05-07-2012, 03:58 AM | #339 |
Rep 446
Drives: 2013 335is
Here are the clips he came up with. Short pieces of aluminum bent slightly in the middle to give a piniching effect once screwed in place.
05-07-2012, 03:59 AM | #340 |
Rep 446
Drives: 2013 335is
The clip reaches up under the lip and holds it in place using the exsisting screw hole. No new holes to drill in the bumper.
05-07-2012, 04:01 AM | #341 |
Rep 446
Drives: 2013 335is
The black on the red makes it really pop out at you. I love it on my car, but it looks even better on the red.
05-07-2012, 12:53 PM | #342 |
Rep 361
05-07-2012, 08:00 PM | #345 |
Rep 1,739
Drives: 2008 Z4MC
When will the lower profile units be available?
05-07-2012, 08:10 PM | #346 |
Rep 932
The bolt for the mounting plates looks too large. I don't want to enlarge the existing hole in case you want to revert back. Did you have to use a different clip?
05-07-2012, 08:30 PM | #347 |
#dubspec
6865
Rep 5,277
more info on this please
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
05-08-2012, 08:41 AM | #349 | |
Rep 446
Drives: 2013 335is
No holes were enlarged to accomidate any new size screws. Bruce matched up his two outside holes and used same size screws. I matched up 1 each of the far outside holes but afte we got it up I simply shot a screw threw the bottom of the bumper in the meat of the mustache. There is no reqiurement to really match the holes if you don't want too. You can not see any of the fasteners once installed.
05-08-2012, 08:02 PM | #350 | |
Rep 932
05-09-2012, 08:07 AM | #351 |
Rep 446
Drives: 2013 335is
It looks like to me someone has already substituted the original screws for those. They are not the same. You should have the hex washer type b screw like on our cars. They are all over mine, so unless BMW decided to change up screws on the underside apron someone did that for you.
In any case more than likely the body of the screws are the same size, our screws just look bigger because of the head and washer combination. EOS.
05-09-2012, 09:14 AM | #352 | |
Rep 932
