      03-25-2011, 10:42 AM   #1
robrwalker
M addicted
robrwalker's Avatar
Drives: 2017 YMB F82, 2018 AW F86
CDV delete - is this right part?
Is this the proper part to use for the CDV delete?
http://www.bavauto.com/shop.asp
Thank you.
      03-25-2011, 12:09 PM   #2
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
http://store.zeckhausen.com/catalog/...roducts_id=276
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      03-25-2011, 12:16 PM   #3
robrwalker
M addicted
robrwalker's Avatar
Originally Posted by a_riddler View Post
Thank you sir.
      03-25-2011, 12:24 PM   #4
robrwalker
M addicted
robrwalker's Avatar
Ordered.
      03-25-2011, 01:59 PM   #5
HaiDef
Drives: M240i
i just removed it completely.. Saved me 30 dollars and works just fine
      03-25-2011, 02:45 PM   #6
mhughett
Drives: 2007 Z4 M Coupe
+1 on this. For those that are already out of warranty or soon will be, it is a complete waste of $30-$35. The brake line screws into the clutch slave cylinder without the CDV with no issues at all. A perfect example of "less is more".
      03-25-2011, 03:01 PM   #7
robrwalker
M addicted
robrwalker's Avatar
Well sh1t. I am out of warranty. Oh well - just burned a few Jacksons.
      03-25-2011, 03:52 PM   #8
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
is there DIY on this? I like to remove mine completely
The Raspinator
      03-25-2011, 04:49 PM   #9
HaiDef
Drives: M240i
http://www.zeckhausen.com/CDV.htm
      03-25-2011, 05:15 PM   #10
fighting_fish
Drives: 2.5i Z4 2004
+1 on a how-to with pictures. Figured I'd replace my brake fluid while I'm at it.
      03-25-2011, 08:12 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I agree
nada
      03-26-2011, 12:22 AM   #12
jdl1pt
jdl1pt's Avatar
49
Drives: Z4M coupe 2007 IL Blue
http://m3.madrussian.net/diy_cdv.shtml
The only difference will be on the shield you remove to access the transmission. Only need to remove one shield where this write up talks about removing two. Will be pretty obvious once under the car.
I'm sure you can find other references by searching, but this is the guide I used.
One other thing. Not sure if this write up talks about it, but use a c clamp on clutch line to squeeze the line closed just before the valve. It's a good idea or otherwise you'll drain the entire reservoir.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      03-26-2011, 01:40 PM   #13
fighting_fish
Great link, thanks jdl1pt.
      03-26-2011, 11:36 PM   #14
jdl1pt
jdl1pt's Avatar
49
Happy to help.
