      05-25-2014, 08:31 PM   #1
Z4Lee
Z4Lee's Avatar
Drives: 2006 Z4 3.0i
Z4 Caliper Painting with Epoxy Paint - DIY
Made some low wooden ramps to be able to get the hydraulic jack under the car (car is so low)
Name:  z4 caliper for zpost_.jpg
First jacking up the front from the jack point under the engine.
Name:  z4 caliper for zpost_-12.jpg
Then jacking up the rear from the jack point just in front of the rear differential.
Name:  z4 caliper for zpost_-2.jpg
All four wheels off the ground on 4 solid jack stands.
Name:  z4 caliper for zpost_-3.jpg
Using wheel lug pins makes it a lot easier to get the wheels off without damage
Name:  z4 caliper for zpost_-4.jpg
Calipers were pretty dirty with that BMW organic brake pad goo (like dry creosote)
Name:  z4 caliper for zpost_-5.jpg
Next step is 30-60 minutes per wheel of disassembly of calipers, removal of pads, several iterations of spraying with brake cleaner and scrubbing with a wire brush. I did a small amount of grinding with a grinding wheel on the dremel to reduce the appearance of the lines from when the calipers were cast. I inserted the slider pins to hold the caliper together for the process. This is what mine looked like when I was done cleaning - turned out to be good enough for the paint to stick.
Name:  z4 caliper for zpost_-6.jpg
Then I applied 4 coats of G2 epoxy caliper paint with a small brush, by the time you get back to the 1st wheel it is ready for another coat.
Name:  z4 caliper for zpost_-7.jpg
I only painted the visible part of the caliper. I think it might be good in the long run because it is easier to work on the caliper without worrying about all the surfaces that might get damaged during a repair. As I was replacing 50% worn pads with new ones I had to push the caliper piston in with a c-clamp, and draw off some brake fluid every two wheels to prevent overflowing the brake reservoir.
Name:  z4 caliper for zpost_-8.jpg
I saw someone chromed the anti-rattle clips but I didn’t get around to it… so I used a dremel tool with an 80 grit flap wheel to polish the clips and finished off with some scotchbrite pads and polish (not sure how long the shiny finish will last, perhaps I can get another set and have them chromed one day…
Name:  z4 caliper for zpost_-10.jpg
The finished product (note the reconnected brake wear sensor, I had one on the right rear wheel and one on the left front – I was surprised they were not on all 4 wheels). The sensors only need replacing if you wore the pads to their limit destroying the contact on the sensor in the process, I reused mine. I replaced the stock pads with ceramic Akebono Euros to hopefully avoid the creosote-like brake dust from the stock pads, after a few days there is some dust but it is clear in colour and not noticeable. I was pretty tired of washing the wheels every week. Don’t forget to grease the brake pad contact points with proper brake grease during reassembly, and I like to put a thin layer of anti-seize paste on the wheel where it contacts the hub to ease future removal.
Name:  z4 caliper for zpost_-9.jpg
My five spoke rims don’t show off the finished product as well as more open designs, but I still like the look.
Name:  z4 caliper for zpost_-11.jpg
      05-26-2014, 02:53 AM   #2
StigJ
StigJ's Avatar
Norway
333
Drives: '06 Z4 Coupe & '14 F30
Like the polished clip detail
      05-26-2014, 08:47 AM   #3
BMWdriver1
Drives: BMW
Love the red man, looks good!
      05-26-2014, 08:56 AM   #4
E86Z
Drives: 3.0si
Good work on the paint. How are those akebonos? Mine have a very spongy feel compared to OEM. And I feel like the pads are loose in the calipers. Thoughts?
      05-26-2014, 06:34 PM   #5
Z4Lee
Z4Lee's Avatar
Thanks for the compliments.
So far I feel no difference with the Akebonos vs OEM. I did some very minor filing on the tabs to make them slide smoothly - but that's not unusual.
A month later I still have no visible dirt on the wheels from the Akebono pads - loving that!
      03-22-2015, 12:55 PM   #6
Z4Lee
Z4Lee's Avatar
Update - One year later the calipers look like I just painted them, wheels remain virtually dust free between car washes, all round a great experience.
Now don't attack me but I just bought an '08 Audi TT/3.2/M6/AWD as a year round vehicle (keeping the Z4 as my sports car - not leaving the tribe). I've already bought another G2 paint kit (red again) and some ceramic brake pads (Hawk this time), so I'll be back to my DIY to remember how I did the paint job last year).
      04-19-2017, 09:05 PM   #7
Zippy Z
Drives: 2003 BMW Z4 3.0
2003 BMW Z4  [10.00]
2003 BMW Z4  [0.00]
2003 BMW Z4  [0.00]
Great write up on the G2 caliper product. I wonder once you mixed the epoxy and paint together how long did you have to paint all four calipers? I am planning on painting mine this coming weekend. I will be changing the pads and rotors at the same time. Thanks for any additional tips you may have.
      04-20-2017, 09:15 AM   #8
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
That post was 2 years old so I don't know if the OP will answer you. My son and I did his calipers with the G2 and the working time is 4 -6 hours
http://www.g2usa.com/INST.html
      04-20-2017, 07:44 PM   #9
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
I divided the paint and the hardener into halves and did one side of the car on Saturday and the other on Sunday. Gave me lots of time to get each side done.
Top Down 365
      04-20-2017, 07:46 PM   #10
Z4Lee
Z4Lee's Avatar
Hi - still here.... yep a few hours, I found the paint started to get stiffer after 3 or so hours but it depends on temperature. I used a foam paint brush on the TT and it worked well. Put the coats on quickly, don't overwork the paint as it will self level and plan to put on at least 3 coats (the first one will look very thin).
