02-16-2014, 03:07 PM | #1 |
Rep 384
Is it my speedo console, or maybe the fuel system. Or maybe the car key???
The problem is very sporadic. It will go days or weeks with no problems and then do it several times in a day. Here’s what happens – When I get in and turn the key, it just spins the starter and will not start no matter how long I keep the key in start position. At first I thought it was just cold weather and a weak battery. So I had the battery changed. This was done at the dealer so the battery was installed correctly and registered to the car as described in the manual for 2006 3.0si This did not fix the issue.
Here’s the kicker and why I believe it is an electrical issue and not the fuel system. I noticed the last few times it occurred that my dash console lights were not coming on right away. e.g. – I insert the key and turn to position 2, no dash or console lights. At this point if I turn to position 3 to start the engine, it will not start. The starter will just whine as if the engine isn’t getting fuel. However, If I wait for the console lights to come on, sometimes a delay of several seconds, sometimes not until I turn the key from position 2 back to position 0 and start over to get the console to light up. As soon as the console lights up. The engine will start. Does this sound like a problem with the console? Or maybe the key itself? Has anyone here ever seen this before?
02-17-2014, 10:02 AM | #3 | |
Rep 384
I'm assuming since over 100 people have looked at this post without commenting that it's a problem no one else has had?
02-18-2014, 08:23 AM | #5 |
Rep 1,772
Drives: 2007 Z4M Coupe
Does this happen with all your keys? Assuming you have more than one master key
02-18-2014, 09:12 AM | #6 |
Rep 12,570
That reminds me, how many keys are we supposed to have, 2 or 3? Don't recall if it was 2 keys but 1 master key for reprogramming purposes or something.
02-18-2014, 09:33 AM | #7 |
Rep 2,882
You should have 2 regular keys and 1 plastic key. There is no "master" key. Both key "fobs" are the same, but can be programmed independently for key-specific memory features.
02-18-2014, 10:30 AM | #8 |
Rep 384
I have 2 keys. The second on hasnt been used since Fall so I will switch it out and see what happens.
02-18-2014, 10:31 AM | #9 |
Rep 1,772
Masters are the diamond ones. You can have regular metal keys with no buttons. I have one. To answer the how many, I think you get 2 from BMW but you can have an additional 6 (I think) programmed through dealer.
02-18-2014, 10:33 AM | #10 |
Rep 1,772
Yes, definitely do that and report your findings.
02-19-2014, 01:43 PM | #11 |
///Multiple
2993
Rep 4,243
If you are not the original owner and didn't get the plastic key when you bought your car, I would highly recommend that you order the plastic key from the dealer. I think it's around $36.
My car only came with one key and didn't include the plastic key. I immediately bought a second key because I didn't want to be without a spare. I ended up locking my keys in the trunk one day and wasted an hour or so of my time getting a ride home to pick up the spare key. I decided I should get the plastic key and keep it in my wallet. Last August I drove to Oktoberfest early so that I could attend a couple of events the prior weekend. On Thursday night I was at Baja Cantina in Carmel Valley and I put my ///M jacket on a chair. My car key was in a pocket. I left my seat and when I came back my jacket was gone along with the keys (fortunately, the car wasn't). I had the plastic key in my wallet which not only allowed me to open the car but also to start it. My wife drove up on Saturday and brought her key which I used until I got back home and was able to order another key.
02-21-2014, 05:32 PM | #12 |
Rep 384
So, It happens with both keys. I'm pretty sure its a bad ignition switch. When the console does not light up, jiggling the key does nothing but turning the key off and back on until the console lights up works every time.
I figure by process of elimination, switch the ignition out and see if it still happens.
