02-12-2014, 07:49 PM | #1 |
Rep 3,939
New to me 07 M Coupe!
Hello all,
I am the proud owner of an e86 M Coupe …I've wanted to own one for ages, and I finally had the opportunity to take ownership of a clean example. This is my 6th BMW (after a 135i, a 1M, 2 e46 M3's, and an e36 M Coupe) and it's quickly becoming one of my favorite cars. I have a few questions about the car that maybe someone could answer for me. For a 7-year-old car, the car is flawless, but obviously, certain things will come with age, regardless of care. 1) I noticed that the door mirrors are starting to look a bit polarized towards the bottom - is this an indication that the auto dimming feature is broken and the fluid is about to start leaking? Would the fix be changing the mirrors? Has anyone tackled this job before? 2) Is there a way to ensure that the navi doesn't open up and turn on every time I start up my car? More often than not I know where I'm going, and I already have my radio stations preset, so I really don't need the screen to pop open every single time. 3) The cowl cover (plastic cover under the wipers) has solidified and started chipping. I already have the replacement piece. How easy is it to swap? Also, I've noticed that the wiper arms themselves are looking a big aged/rough. Is there a way to restore these to a gloss black, or is paint the only option? Thanks in advance for your help and advice! Happy motoring! |
02-12-2014, 08:01 PM | #2 |
Rep 1,443
Congrats on the purchase! What made you get rid of the 1M (unless you now have both)?
1) I think there are threads about this issue. If it does need to be replaced its pretty easy to remove the mirror portion. DIY write up here, too somewhere. Edit: I think this is the one I used to install my Tekarbon covers: http://www.bimmerfest.com/forums/sho...9&postcount=28 2) I don't have nav in my M but my 3.0si had it. I'm pretty sure there was a way to make it stay down - one of the buttons next to it? I don't quite remember. Maybe if you keep pushing the down adjustment button next to it that adjusts the tilt it'll just go all the way down. 3) Never done it so I can't say. Good luck!
02-12-2014, 08:09 PM | #3 |
Rep 2,707
I can answer #3
Take a look at the back side of your new cowl cover and there should be white or black clips that simply push into holes in the cowl sheet metal. To remove the old one insert a flat blade screwdriver or putty knife in the area where the clips would be and pry up .Again use the new one as a reference to locate the plugs. Good Luck and don't forget the customary pics of the new ride.
02-12-2014, 10:30 PM | #6 |
Rep 2,882
For #2 - The buttons to the right of the Navi screen will control its up/down. The button toward the windshield is up. The thing I hate is that if you have the screen down, any button you touch will cause it to pop back up I wished there was a way to make it remain in the open position all the time instead of closing every power down.
02-13-2014, 12:00 AM | #7 | |
636
Rep 3,124
Some have been able to just rock them off, but it's a tapered spline, so they might be on there pretty good. I used a small gear puller on mine, and I had to hack out the grommets to clear the hooks of the puller. New part comes with grommets installed, so they were scrap anyway. I think I saw some wiper pullers at Griot's Garage, but I would hate to buy something and use it maybe once. While you're at it, get the piece that goes around the rest of the windshield. It's about $25-$30 and just snaps into place. If the cowl cover's cracking, that piece will soon do the same. OH: Use painter's tape on your windshield to mark the position of the wiper arms before you pull them. Much to my surprise, the splines are a very fine pitch and there's no keying.
02-13-2014, 06:47 AM | #8 | |
Rep 2,707
Yes wiper arms need to come off, puller as Stickmon says. There are also a couple of plastic push in fasteners into the top of the firewall that need to be removed.
02-13-2014, 06:50 AM | #9 |
Rep 3,939
Thank you for all the replies folks, I'm looking to tackle this diy sometime this week or next week. I'm loving the car...what a machine!
For those who asked, I sold the 1M for two reasons. Reason #1 is called a Porsche 911 Carrera S (which I have sold as well), and reason #2 was that I was looking for a BMW with more pedigree. The 1M is a special and phenomenal car, sometimes I wonder if I should have kept it; that said, my favorite car so far has been the 911 C2S, and the z4 M Coupe is coming in at second. Speaking of the navi, I know I can close it with a button after I start the car, but every time I select something (like a radio station) it pops back up. I was wondering if there is a way to tell the car "hey, when I start you up, leave the navi closed unless I press the button to open it up." Thanks again, I purchased and picked up the car yesterday, so I don't have many pictures, but I'll attach 1 for now...with proper ones to follow later |
02-13-2014, 09:26 AM | #10 |
Rep 1,443
Oh, I see. Sorry, to be honest, I never really noticed the screen that much in my previous car so I never tried to get it to go down semipermanently. That would be convenient though. Hope someone finds an answer for you.
02-14-2014, 06:29 AM | #11 |
Rep 3,939
Does this baby like to dance, or do I need better tires? lol VERY tail happy around corners and I'm loving it!
Two more questions: 1) all 3 ///M emblems are fading. I corrected this on my z3 M Coupe by replacing just the stickers on the emblems, made by Never Done. I've emailed them asking if they make the stickers for the z4 M, but no response yet. Does anyone know if they do, or will I need to get new emblems at the dealer? 2) I noticed that there is a BMW carbon fiber spoiler than I'm really digging. A replica is made by an aftermarket company (tekarbon I think?)...does anyone have experience with any of these pieces? In the past I've had great experiences with OEM carbon fiber pieces and terrible experiences with aftermarket carbon fiber. All input will be greatly appreciated. By the way, I'm very picky, so I care about the fit, finish, the way the weave looks, etc. Happy Friday! Can't wait to get off work and go driving! |
02-14-2014, 09:15 AM | #12 |
Rep 1,443
2) I have the Tekarbon mirrors and they're nice but not top notch. Others have gotten very nice ones and some of us not so much. I do have the BMW spoiler and it is excellent quality. So, I'm not saying you'll receive a subpar Tekarbon one but if you're a perfectionist spending the extra money on the BMW one might be worth it.
02-14-2014, 09:24 AM | #13 |
Two Wheels or Four?
95
Rep 655
I just bought a Tekcarbon rear spoiler. I'd say it's 90%. I haven't mounted it yet, there is one small area/sharp edge about an inch long that's not perfect, unfortunately it's on the rear facing outward so it's most noticeable. However I doubt anyone but me would even notice the blemish. Certainly not from more than 5 feet away.
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
02-14-2014, 10:34 AM | #14 |
Rep 3,939
Good to know, folks! I've had fitment issues as well as fading issues due to cheap manufacturing processes. So I think I'll opt to spend a bit more and go with the real thing.
02-14-2014, 11:02 AM | #15 | |
636
Rep 3,124
Here's the solution to faded ///Ms. See posts #6 and #8.
02-14-2014, 09:25 PM | #16 |
1624
Rep 4,296
The stickers from Tyler at never done are awesome! I've got his first ever set for the z4 coupe on mine and fit is great. Tyler is a great guy and a bonus to our community. Just email him and ask him. He does have them, just not listed yet.
Also congrats on your car, looks like you got the BEST color ; D The nav screen will stay down, not sure how or what, but mine now stays down unless I open it. I also have my radio station preset, and no need for the stupid mk4 gps that it houses. Pics inside of the coupe would be nice too |
02-15-2014, 03:19 PM | #18 | ||
Rep 3,939
By the way, everyone knows that the Imola red adds 20hp to the car…that;s why I picked it :P … I'll try to get some better pictures in the next few days. I noticed that my nav now stays down, unless I try to change radio stations, then it pops up…hmmm…who knows! Thank you…I think I'll go OEM! |
02-15-2014, 03:32 PM | #19 |
Rep 2,882
02-21-2014, 09:30 AM | #20 |
Rep 3,939
Does anyone know where I can get an OEM carbon fiber spoiler? I can't find one to save my life and my local dealer can't locate one either. Thanks!!
