      02-08-2014, 11:58 AM   #1
timhill78
Drives: 2007 Z4 M Coupe
Apex EC7 Rims and TPMS 18x9.5 18x10
These are sold!!!
      02-08-2014, 07:18 PM   #2
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
nice size, you could go to 285s in the rear with that. How much do they weigh?
      02-08-2014, 08:54 PM   #3
timhill78
21.7 lbs in the front and 22.4 lbs in the rear
      02-08-2014, 11:52 PM   #4
Spedracer81
Drives: Z4MC
whats the finish?
| 2008 Interlagos Blue Z4MC |
| AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust |
      02-08-2014, 11:57 PM   #5
timhill78
Satin Black
      02-11-2014, 05:29 PM   #6
timhill78
bump
      02-15-2014, 03:56 PM   #7
timhill78
Obo
      02-16-2014, 09:07 AM   #8
1SerieStud
1SerieStud's Avatar
184
Drives: '11 VO 1M (498 of 740)
So, they would rub against the oem suspension as well, correct? Considering that the geometry of most suspensions leads to negative camber when compressing/hitting bumps?
      02-16-2014, 09:58 AM   #9
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
MacPherson struts are fixed solid to the knuckle. it is not possible for the tire to contact the strut due to compression. coilovers typically have a lower spring perch than stock struts on these cars, which is likely the cause of his contact issues.
      02-16-2014, 01:37 PM   #10
1SerieStud
1SerieStud's Avatar
184
Hmm…but typically, the coil over spring perch is not in the way of the circumference of the wheel. I wonder what caused the rubbing…
Would these wheels with these offsets clear the OEM suspension and fenders?
      02-17-2014, 11:36 PM   #11
timhill78
It actually just barely touched one of the adjustment perches of the AST coilover. The stock spring perch doesn't go that low so it should fit fine. It wouldn't have touched at all if I didn't run 2.5 degrees of camber with shims. Even with that much camber it only took a 3mm spacer to fix it.
      02-19-2014, 09:26 AM   #12
F360C
Drives: E86 S54
The price is with out tires correct?
07 Z4 M Coupe AW/IR
      02-19-2014, 09:36 AM   #13
timhill78
Yes. No tires offered.
      02-24-2014, 08:40 PM   #14
timhill78
bump
      03-01-2014, 07:55 AM   #15
timhill78
bump
