05-25-2013, 02:53 PM | #1 |
#dubspec
6336
Rep 5,201
feel like building some brake ducts
so i need a small project i can work on, and decided i want to build some cooling ducts. i have the ducting itself and flanges just need a plate to mount the ducting to. most likely will be something custom since i have not seen any yet. anyways, here is a quick shop of where i want to place the ducts, finished in black. what do you think?
05-25-2013, 02:59 PM | #2 |
Rep 892
I'm planning to do the same thing in the same spot. Need to check if the E46 M3 backing plates fit our cars.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
05-25-2013, 04:40 PM | #5 |
#dubspec
6336
Rep 5,201
Ya same. Trying to dig up some info
05-25-2013, 06:30 PM | #7 |
#dubspec
6336
Rep 5,201
im looking if the turner ones fit from the e46 application
05-25-2013, 08:43 PM | #8 |
Rep 387
I called and asked sometime ago. No one could give me a straight answer. Not sure their backing plates fit our brakes. If you have BBK you are in a different situation then the rest of us.
05-25-2013, 09:21 PM | #9 |
Rep 1,663
I'm curious to see what you find out, if they fit or if they can be modified to fit. Turner's brake backing plates say they are for the non-M Z4.
05-26-2013, 08:21 AM | #10 | ||
Rep 4,726
Why are you guys thinking of putting ducts in that spot, would be easier to route from the OEM spot, just have to contend with the od shape opening.
05-26-2013, 08:39 AM | #11 |
#dubspec
6336
Rep 5,201
The oem ducts blow air against the tire, and it would be harder to feed the ducting from where the opening is in the wheel well. Also, it would look modified from the front view and with the wheels off with cut and hacked wheel liner. I think placing them where I photoshoped will be a cleaner install and direct more air than using the factory ducts
05-26-2013, 10:55 AM | #12 |
Bimmer Noob
30
Rep 566
When I was in the shop getting my car aligned and corner balanced, they asked me if I was interested in a brake duct kit. I said not until I have my BBK.
They were looking for a car to do the test fit to adapt their kit to. The guy wanting to do the work was the one who did the cage for z4mnyc, so he's very familiar with our cars (despite being a porsche shop). I'd be willing to let them use my car if there is enough interest. Here is their kit for an E9x. http://www.cantrellmotorsport.com/in...art&Itemid=117
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
05-26-2013, 11:07 PM | #14 | |
Rep 4,726
05-27-2013, 05:42 AM | #15 |
Rep 102
Here's an install on a non-M Z4 coupe. I believe we could essentially do the same thing, but we have a different front suspension setup. Ours is closer to an E36 configuration than E46, but I'm not sure if E36 backing plates would work without some modification. I think you could modify the stock backing plate by cutting a hole and riveting on a duct, similar to this. I would either try to modify the backing plate in place or cut it off so I wouldn't have to remove the wheel bearing (unless I needed to replace the wheel bearing.) It would also make sense to run the intakes to the center grill and modify it so the outer holes are actually open as seen here.
05-27-2013, 07:22 AM | #16 |
Rep 387
Jon1275 did exactly what we are talking about using Turner's kit for the e46 m3.
He posted some picks here: http://www.zpost.com/forums/showpost...7&postcount=14 |
05-27-2013, 08:03 AM | #17 |
#dubspec
6336
Rep 5,201
Awesome. Thanks. Will read up on his install
05-27-2013, 08:09 AM | #18 |
Rep 222
05-27-2013, 10:14 PM | #19 |
Rep 1,739
Drives: 2008 Z4MC
I understand a project, but do you have plans to track your car with that stance / those wheels? Otherwise, it's overkill for a show-pony.
Plus two big holes in your front fascia with some wire-wound ducting exposed would ruin the whole aesthetic. Make sure u at least get some proper double ply ducting with a smooth inner wall for unrestricted flow. Jmo |
05-28-2013, 07:28 AM | #20 |
#dubspec
6336
Rep 5,201
I do go to the track with my car. Not religously since I have other priorities, but 2-3 times a season to open events. I don't think that makes the car a show-pony, lol. I drive it regularly on public roads. As for the ducts, I probably don't NEED them, but I think the car can only benefit from them. I also like the look and agressive apperance they give off, and I enjoy making things myself and figuring out mounting options ect.
Thank you exdos for the link. Very helpful as well
05-29-2013, 08:22 PM | #21 |
#dubspec
6336
Rep 5,201
well i managed to get the ducting sorted into the wheel well and the bezel mounted at the grille. just moved into my new house so no pavement yet....assembling some new cabinets with the family hauler in its new home as well
