FORUMS
- 5
| 11-13-2012, 03:14 PM | #1 |
![]() ![]() Drives: Sapphire Black/Black Z4Mc Join Date: Oct 2008
Wheel Fitment Database/Summary/Grid
We have the wheel fitment thread sticky, but there's no easy way to find all the options out there (and results) without reading through it (painful).
Here is a Google Doc that Flyzipper shared with me. I've modified it a little bit so that we can try both M and non-M fitments. Please feel free to add your information to the list. Here is the link.
![]() 2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047 Last edited by Finnegan; 03-24-2013 at 06:03 PM. |
| 12-11-2012, 10:35 PM | #3 |
you need a 8.5et35 front and 9.5et38 rear. will fit the z4 non m flush
2006 ///M Coupe TiAg / IR -- H&R coilovers/RPI exhaust/ZHP knob/19" Morr vs8.2 hand brushed/Stoptech 355mm 6/4 BBK/Turner strut bar/polished diagonal braces/m tower caps/tekarbon 2x2 coil cover/Michelin PSS/gloss black kidneys/painted gloss black roof/mstache 2 front lip/AFE dry intake/RPI forced induction/colormatch corners/black chrome //M badges/rear diffuser/aeroskirts/rogue mounts/DKF adjustable hangers/22%tint/euromode lighting/LED interior & plate lighting
| 12-12-2012, 01:16 AM | #5 |
Great. I'll work on it over the holiday break!
![]() 2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047 |
| 12-12-2012, 01:37 PM | #6 |
![]() ![]() ![]() Drives: '08 Z4 M Coupé (Sepang Bronze) Join Date: Apr 2010
There already is a google doc someone put together but I can't find it. Perhaps you can use it/tweak it without starting from scratch.
![]() #1765/1815 — 1 of 68 Sepang Bronze / Black Nappa / Madeira Wood 19" Advan RS Dark Gun / Hankook Ventus V12 / H&R Springs / StopTech SS lines / StopTech Street Perf pads / R.E. Diablo / CF Grills / CDV Delete |
| 12-12-2012, 02:37 PM | #7 |
Thanks, I'll search. If it's public (or if I can find the source thread here) that would save work!
| 12-12-2012, 02:59 PM | #8 |
It must be somewhere in the Definitive Wheels Spec thread. It's pretty detailed.
| 12-12-2012, 03:02 PM | #9 |
Thanks. Will look there.
| 12-13-2012, 12:42 PM | #10 |
![]() ![]() Drives: flat out Join Date: Apr 2008
Spreadsheet via Google Docs, that way you can add filters for m vs non-m, diameter, width, etc
OR just create a spreadsheet with a calculator built-in. It won't be 100% absolutely correct (tire width will vary by make) but at least for stock suspension it should be close enough. If someone gives me baseline clearances on strut & fender sides, I can create a spreadsheet that will do the rest.
![]() Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance Click here for my track videos Last edited by DSC_OFF; 12-13-2012 at 12:50 PM. |
| 12-13-2012, 08:50 PM | #11 |
Brilliant idea. Will be a great one stop database.
Mods: APEX EC-7 | Michelin PSS | Koni Yellow | Eibach Pro-Kit Springs | Rogue RSM | Z4M Sport Seats | ZHP Shift Knob | Mangowalk 2.4" Antenna
| 12-21-2012, 07:28 PM | #12 |
Spreadsheet already exists as Aestheticstorm noted.
I cannot be edited however, and we'd need to add a few more data elements. the good thing is that it's a really great start, and has data already. I've PM'd the spreadsheet owner regarding using their spreadsheet, or using their data for a new one. I've asked that it be opened to editing (like the battery summary spreadsheet), since allowing folks to add their own data (if they have the right link) is just easier than trying to maintain it. Once I hear back, and we have a plan, we'll move to sticky the thread with the existing spreadsheet or this thread, and then open it for data entry/viewing.
| 12-22-2012, 05:50 PM | #14 |
^Yep
Got access from Flyzipper, and I'll add a few fields and get it stickied after Christmas.
| 12-31-2012, 09:03 PM | #15 |
![]() ![]() Drives: 2005 z4 3.0 Join Date: Jun 2012
good work, looking forward to it, looking for new wheels for the summer
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | first aid boxes | stubby antenna | polished exhaust tips |
| 03-18-2013, 10:37 AM | #17 | |
The Wrapgician
Drives: z4si Join Date: Jan 2012
| 03-18-2013, 11:28 AM | #18 |
![]() Drives: 2006 BMW M COUPE Join Date: Dec 2008
I am no expert but the R +45 may be out too far ? Most used here in 9'5 are 22 or around there ? Gee those wheels are not cheap are they ?
is this the spreadsheet you were referring to > https://docs.google.com/spreadsheet/...WeUg1b2c#gid=0
2006 M COUPE - one of 38 Imola Red produced for NA that year, ESS 455 Supercharger
![]() Last edited by drbvac; 03-18-2013 at 11:42 AM. |
| 03-18-2013, 01:10 PM | #19 | |
The Wrapgician
isnt the +smaller number will be outer? mine OEM is like +50 and people doing +35~+40 to make it flash? confused yes... they are not cheap and all custom made and shipped from Taiwan... so i dont really wanna screw up at any point...
| 03-18-2013, 01:17 PM | #20 |
Mine is an M coupe so sorry if I confused you :\\
Here is a link you can plug in different offsets and see what it does. http://www.1010tires.com/Tools/Wheel-Offset-Calculator
| 03-19-2013, 12:41 PM | #21 |
The Wrapgician
![]() so I did this check, is inner clearance 14mm less mean like it will appear like i put on a 14mm spacer on my OEM wheels? whats outer position means? ![]()
| 03-19-2013, 01:33 PM | #22 | |
the 14mm less inner clearance means it will be 14mm's closer to the shock |
| Bookmarks |
