      08-06-2007, 03:07 PM   #1
trippinbillies40
Drives: '04 Z4 3.0i
12v switched wire in trunk?
Anyone know which wire in the trunk of my Z might be 12v switched? I need one for my dice w/ dsp install. Thanks for the help!
      09-01-2007, 02:22 AM   #2
flypenfly
Drives: 2020 Cayenne, 2015 Msport 228i
bumping this question...
      09-01-2007, 02:50 AM   #3
BimmerZealot
Drives: 2019 BMW X3 xDrive30i
Definition of switched? On when key is pass ignition two? On when radio is on? On when lights are on? Might help figure out which wire to use.
      09-01-2007, 07:45 AM   #4
flypenfly
Switched to key On
      09-11-2007, 05:46 PM   #5
daveysew
daveysew's Avatar
Drives: '91 318is/'05 Z4 SC/'18 440ix
Purple & White in the wiring loom behind the firewall in my Canadian 2003 Z4 3.0
dave
      09-25-2007, 03:14 PM   #6
eu835795
nardi
Drives: 2004 3.0 Z4
How did the Dice work out for you,
Does the Text work on the head unit, how is the playlist/album selection, is it easy to find what you want to listen to. How is the sound quality with the DSP interface?
I'm currently looking at different options and the dice looks to be the best value for money.
      10-18-2007, 01:09 AM   #7
flypenfly
dave
Seems to be a lot of purple and white, any ideas which?
http://www.jae-designs.com/Z4Trunk/
      11-01-2008, 08:13 PM   #8
daveysew
daveysew's Avatar
Purple wire with a single white stripe running the length. Mine was wrapped in a wiring loom.
dave
