      10-19-2012, 08:36 PM   #1
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
"Ironing" marks on Roadie Top
That's what they look like to me, but they must be from when the top is down. They are those marks on the roof where the material is flattened. Any idea h to get rid of them? Maybe steam and then a brush?
      10-20-2012, 03:00 AM   #2
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
Clean and protect with BMW, Ragg Topp, or 303
      10-20-2012, 03:53 AM   #3
Hogndos
Hogndos's Avatar
Drives: 2003 Z4 3.0i Titanium Silver
I have the same marks on my black top..."ironing marks" is a perfect description...I do clean and protect with RaggTop and it has had no impact... I think they are pressure points from the frame when folded and even if you could raise the nap somehow I would guess they would just re-appear once the top is folded again...my 2cents
I can't imagine putting 303 on a cloth top but maybe so... the RaggTop is really great stuff...
      10-20-2012, 08:03 AM   #4
mike519
mike519's Avatar
Drives: 2018 M240i
Yup, I use Raggtopp as well and it certainly will have no effect on the fold lines. I too wonder about steaming. Has anyone tried this? I wold think that as long as the top is kept stretched (closed) while drying that, in theory, this should work.
      10-20-2012, 08:16 AM   #5
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Take it to a really good detailer. That or replacing the top are your only options. A good detailer might have the knowledge on this and would be cheaper.
      10-20-2012, 12:14 PM   #6
elerner61
elerner61's Avatar
157
Found a previous thread on this. http://www.zpost.com/forums/showthread.php?t=548211
Doesn't seem like much can be done for these "age lines" in the top. I'll just think of them as smile creases from good times with the top down more than its up.
Actually, there was one suggestion in that thread about using Downy to try and lift the crushed fibers. I'll see what the Raggtop folks say about it.
      10-20-2012, 05:47 PM   #7
GammaZeta
Drives: 1
Why is your top up in the first place?
You're doing it wrong!
      10-21-2012, 04:04 PM   #8
Huz-Z
Huz-Z's Avatar
No arguing with that advice!!!!
Now, I do believe that some folks have remarked that either the BMW or Ragg-Topp canvas top cleaner and conditioner will get rid of some of these marks. but they will return as you continue to use the roof.
If that is so, then I guess that when you get enough of these lines to really annoy you, it wil serve to remind you to clean and condition the top again.
Huz-Z
      10-21-2012, 05:16 PM   #9
puciorek
puciorek's Avatar
No_Country
Drives: 2008 Z4M
just a quick question: is this what I should use to clean and protect the top for my roadster, just want to make sure I am getting the right product...thanks much.
RAGGTOPP Convertible Top Fabric Care Kit - #01165
One Bottle of RAGGTOPP Fabric/Vinyl Cleaner
One Can of RAGGTOPP Fabric Protectant
MSRP$37.95
FREE SHIPPING Special!
      10-21-2012, 05:40 PM   #10
mike519
mike519's Avatar
Drives: 2018 M240i
MSRP$37.95
Yup
      10-21-2012, 07:27 PM   #11
beta
Drives: 2006 M Roadster
303 is also really good, check out this thread I posted a picture of my top.
There's really nothing you can do about the "ironing" marks, but you can minimize them.
      10-21-2012, 07:32 PM   #12
puciorek
puciorek's Avatar
No_Country
Drives: 2008 Z4M
good stuff, thank you gentlemen!
      10-24-2012, 12:40 PM   #13
elerner61
elerner61's Avatar
157
So I've spoken with Rick at Wolfsteins (makers of Raggtopp) and then Marc Elliott over at Haartz. The bottom line is we shouldn't be storing/leaving our roadies with the tops down.
The crease lines that are merely marks will come out over time with cleaning and having the top up in sun.
The crease lines where the fabric pile is now compressed and has a shiny appearance are pretty much there for good. Those are from when the top is down and the car is in motion, and the fabric is wearing against itself AND when the top is stored in the down position for periods of time.
The only change I may be making is if I know I'm done with the car for the day, I may put the top up for the night in the garage.
      10-24-2012, 01:30 PM   #14
Huz-Z
Huz-Z's Avatar
Good advice.
I don't mind leaving the top down for a while if the car is in the shade. But if its parked in the direct sunlight on a hot summer day, I tend to close the top to avoid all that UV beating up on the interior of the car's leather and plastic and possibly damaging or weathering it over the long term.
Huz-Z
      10-24-2012, 01:53 PM   #15
GammaZeta
Drives: 1
Ok...
So to make sure you don't get the lines in the top, keep the top up as much as possible.
Or, if you have the top down, make sure to put it up each and every time you are done with the car. But of course that method means that the rubbing will cause the lines as well.
And then you'll put extra wear and tear on the top motor and have to replace that sooner than later.
      10-24-2012, 02:07 PM   #16
Huz-Z
Huz-Z's Avatar
I generally don't leave the top down when the car is unattended in public, parked overnight even at my house, or if its parked in the direct hot sun. Parking in public top down worries me - I don't want to be the victim of a hater who may toss garbage or a lit cigarette butt into the car. Based on occasional reports here and on other Z forums, there are folks out there who would probably do such a thing and get a kick out of it.
Other than that, it gets used and if the motor wears, I'll have it replaced or use the top manually.
Huz-Z
      10-24-2012, 03:37 PM   #17
Nate4641
Nate4641's Avatar
Even when I had my Miata I never left the top down in public anywhere. It too had a locking mechanism for interior storage, but I just dont trust people, period. The Bimmer would definitely draw the attention of "haters" though. I've already been keyed once, I can only imagine if I had left the top down what would have happened
      10-24-2012, 04:09 PM   #18
Loogey Clapp
Loogey Clapp's Avatar
Drives: 2006 Z4 3.0si
Dang! Bum news for sure elerner61. I leave my top down for about 5 months while I am using the hardtop. In the summer, when I park in my garage, I generally leave it down overnight too.
      10-24-2012, 08:47 PM   #19
elerner61
elerner61's Avatar
157
I forgot about the "top down while the hardtop is on" thing. I had a hardtop on my Miatas (I miss it, been keeping my eye out for one, but they sure are hard to grab for the Z).
And yeah, been thinking about the "extra down and up at the end of the day in the garage burning out the motor sooner" thing.
Basically...we're screwed. May as well just do as you want and pay the piper when you need to, with this one.
      10-25-2012, 06:46 AM   #20
Huz-Z
Huz-Z's Avatar
I think most top motor failures are due to water damaging the motor. The water accumulates when the drains get blocked. So, if you keep the drains clear, or reduce opportunity for them to get blocked by garaging your car at night, in bad weather or during the winter, you may dodge that bullet for quite some time.
Huz-Z
      10-25-2012, 09:32 AM   #21
puciorek
puciorek's Avatar
No_Country
Drives: 2008 Z4M
..."The water accumulates when the drains get blocked. So, if you keep the drains clear"...
Sorry to ask this question, I am sure it has been talked about in the past but how do you clean these drains? or check whether or not they are clean?
Secondly, let's say I only drive short distances daily (8 miles and less) so by folding the top and putting it back up, does that drain significantly the battery?
      10-25-2012, 05:36 PM   #22
SD ///M4
///Multiple
SD ///M4's Avatar
My previous car was an S2000. I had it for 13 years and used to leave the top open all the time when it was parked. After I had the top replaced at 10 years I used to put the top up when it was parked but I would leave the windows down, unless I was just making a quick stop somewhere. It wasn't until two years ago that I parked with the top down and someone threw a little plastic container of tzatziki sauce that opened up and splashed all over the passenger seat. That's the only act of vandalism I've experienced with that car.
However, the BMW roundel tends to set some people off even more, but I still park it with the top up and windows down.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
