      08-27-2012, 09:45 PM   #1
achoi05
Drives: 06 z4 3.0i
Windows Have a Mind of their Own!
Quite frequently if i try to close the windows, they will fully close, then open. It was not a big deal until I was closing the top and the window was fully closed. Anybody know of anyways to fix this?
      08-28-2012, 12:25 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
There's an incantation to recalibrate the auto-up on the windows. I had to do it after replacing the battery. The key step is to hold the switch in the close position for a few seconds after the window is fully closed. You will hear an audible click.
See post #6 here.
Note that the windows are programmed to go back down if they hit the slightest resistance, so you don't accidentally strangle your dog.
It sometimes takes me 2-3 tries to get the passenger side closed. It rubs a little about 2/3 of the way up and often reverses.
      08-28-2012, 12:45 AM   #3
achoi05
Drives: 06 z4 3.0i
Ahhh! thanks for the info. Come to think of it, I think the problem started after I got my tints. Could the slight thickness of the tint actually be causing the resistance?
      08-28-2012, 12:48 AM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
Probably not so much the thickness as the tackiness.
      09-06-2012, 05:46 AM   #5
DAR
Drives: 2008 Z4 3.0i Roadster
Have the same problem with my '08 since new. Occurs occasionally, on driver's side- if it happens I just open the door and raise window. Didn't realize there was an easy fix as noted by StickMon. (I didn't want the dealer taking apart the door to get to the window assembly as this issue is a very minor annoyance.)
      09-06-2012, 12:16 PM   #6
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
my car does this once in a while to screw with me, sometimes when raining
      09-06-2012, 02:51 PM   #7
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
When I go to lift both windows simultaneously, but actually hit the driver's switch at tad late, both windows will rise all the way, but the driver's window will come right back down. It will lift on it's own on the next pull, so it's not a huge issue, just kinda weird. If I pull both buttons at the exact same time, there is no issue.
      09-12-2012, 09:21 PM   #8
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
This is exactly how my windows work, if I hit them both at the exact same time then they stay up. If I close one window slightly before the other, when the one window is fully closed, the other will start to open at that exact moment.
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      09-15-2012, 12:56 AM   #9
StickMon
StickMon's Avatar
Drives: 2006 MR
Given how litigious we are here in the U.S. it amazes me that this feature even exists.
I'm sure some idiot has rolled them up on his hand/neck/wife/kid/dog/shmekel.
The auto-reverse has to be incredibly sensitive to keep BMW out of court.
