08-18-2012, 07:55 PM | #1 |
Custom User Title
149
Rep 661
Valve shims w/ local expert Kevin
Today Kevin ("KAIV" on the M3 forums of bimmerpost) did valve check & shim adjustments on my '06 Z4MR, in my garage, in about 90 minutes, successful and painless. Car is just over 40K miles. I did the VANOS filter myself the day before.
Six shims needed to be replaced. I got to watch & learn. I used the gasket kit from Turner Motorsports to replace the spark plug gaskets, VCG, etc. Attachment 736962 Not a terribly complicated procedure; you just need to be meticulous. Kevin was a real pro who clearly knows what he's doing. He works as a mobile service, doing anything up to a full Inspection II. If you're in SoCal, I hightly recommend you contact him as an alternative to a full shop or the Stealership. Last edited by blender; 11-21-2012 at 10:30 PM.. |
08-18-2012, 11:49 PM | #2 |
636
Rep 3,124
08-19-2012, 01:41 AM | #3 |
636
Rep 3,124
Started looking up the individual parts from Tischer and just with the valve cover and the spark plug gaskets it was nearly $100.
ECS seems like a good deal, even with shipping. |
08-19-2012, 08:29 AM | #4 | |
Rep 11,669
http://www.trademotion.com/partlocat...egoryID=123145 the kit is $95 with Tischer
08-19-2012, 08:57 AM | #5 | |
Rep 1,002
ECS had the best price when I bought mine. |
08-19-2012, 02:04 PM | #6 |
Custom User Title
149
Rep 661
Yes, that's why I went with TMS... got the gasket kit and two vanos filter kits for < $200... and I wanted to support TMS since they've helped me out in the past, and I've had previous bad luck with an ECS kit. That said, no vendor is perfect... caveat emptor, etc.
08-19-2012, 02:11 PM | #7 | |
Rep 376
How are you rotating the engine over? Wrench on the cam? Special tool on the crank?
Mods: OEM Euro Headers, RPI Scoop Daily: 2010 Tacoma Double Cab |
08-19-2012, 03:16 PM | #8 |
Rep 11,669
08-20-2012, 02:13 PM | #10 | ||
IG: limited.slip
338
Rep 1,927
I personally remove the front TOP plastic cover and slide the radiator fan up and out. It's only held by one screw and one expansion rivet. No need to go underneath the car. No special tool, just a regular 32mm socket and a ratchet. Of course make sure the car is in neutral to rotate the engine |
09-11-2012, 06:30 PM | #11 |
///Multiple
2993
Rep 4,243
I'm sending you a PM. I need a valve adjustment/Inspection I on my 2006 Z4MR and I'm also located in San Diego.
09-11-2012, 08:19 PM | #12 |
6 of Diamonds (ret)
82
Rep 566
Push the car back and forth or 32mm socket on the crank - PITA to get on but it works. A short socket or grinding it down would ease the clearance
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
09-12-2012, 10:51 AM | #14 | |
Rep 1,031
You could add an extension to the socket wrench but this way was easier for us. However, if you do the extension you might have a challenge turning the wrench intially to get the handle to the top, after that not an issue. |
09-12-2012, 11:03 AM | #15 |
Bad Lieutenant
233
Rep 3,517
I put it in 4th and rolled the bitch
04-15-2013, 02:00 AM | #16 | |
Rep 18
Another satisfied customer...
Overall score: 10/10. After watching a master do the adjustment, I now wonder how the dealerships or even some independent shops charge the kind of money for what is essentially a 2-hour job.
Sold the Z. Got the G. Sold the G. Got a Z... 4... M. I still want a Jeepney! |
04-15-2013, 10:52 AM | #17 |
Rep 2,882
Agreed...Plus the fact that you get to watch and knowing the adjustment is actually being done and done properly (I have trust issues with dealers, as you can tell ). You also get the peace of mind that the VANOS hubs are being checked at the same time
As long as Kevin wants to do this, he has the "valve adjusting and inspections job" for my MC |
Tags |
shims, valves |
