06-17-2012, 12:55 PM | #1 |
Rep 4,531
Camber Alignment for Auto-x/DD/HPDE
Hey guys,
I came to the decision that I'm not going to get camber plates. It's not worth the money for the minimal gains (not to mention a bump in SCCA Class). So, with that being said...I want to get a new alignment that won't increase excessive tire wear but still provide the gains that a camber plate set-up would provide. I realize that the front cannot be adjusted, so basically I'm screwed? I don't know anything though with camber and toe ranges though. As of now, both my DD and Auto-x Tires have outside wear. So some additional camber as of now will only help, not hurt. Any suggestions? I'm running a 30mm front bar if that helps. Last edited by Kgolf31; 06-17-2012 at 03:17 PM.. |
06-18-2012, 01:57 PM | #2 |
instagram 997turbotom
279
Rep 7,377
Front camber is adjustable a bit. There are these pins on top that should/can be removed, and the 3 nuts holding the assembly can be loosened. That will get you about -1.5* up front. Then you can add turner's camber washer kit, and get like -2.5* or a bit more.
I'm running -2.5* camber up front and its great for autox and DD wear, I also have the front toe at ZERO. feels wonderful
06-18-2012, 02:56 PM | #3 | |
Rep 4,531
What's the specs in your rear? I was planning on going around -2 to -2.5 with zero toe up front. How many washers did you need to use to get -2.5? |
06-18-2012, 04:54 PM | #5 | |
Rep 4,531
Just to clarify, how do you push the strut in? Do you have to loosen up the 3 bolts? By what Hack said, 2 washers will only get -1.7. Others said it gets them -2.5...I'm confused now when I thought I had it |
06-18-2012, 04:57 PM | #6 |
Rep 11,667
The 2.5 to 2.7 is with the washers plus adjusted at the top.
06-18-2012, 05:04 PM | #7 |
Rep 4,531
06-18-2012, 05:48 PM | #8 |
Rep 2,138
Drives: Me
All of this is predicated on how thick the shims (washers) are. Some will get more, some will get less.
I have -2.5 with two matched sets of washers and the alignment pin installed. |
06-18-2012, 05:51 PM | #9 | |
703
If you want the camber to be even side to side you're need to measure it yourself, or have it done as part of the alignment--the adjustment on the top of the strut tower is for fine-tuning. If you're DIYing this, be very careful re-installing the bolts after attaching the washers. It's very easy to cross thread, and be sure to use red loctite. Lots on this and steps and cautions in this thread, Last edited by Finnegan; 06-18-2012 at 05:58 PM.. |
06-18-2012, 06:26 PM | #10 | ||
Rep 4,531
So if the camber is off on each side, just adjusting the strut towers on the rack will fix it? I'm assuming all alignment shops know this? |
06-18-2012, 06:34 PM | #11 | |
703
06-18-2012, 06:37 PM | #12 | |
Rep 4,531
I ordered my shims this morning, and they shipped out already. By the end of the week I should have my camber good to go for autocross on Sunday. |
06-18-2012, 08:30 PM | #15 |
Rep 4,531
06-18-2012, 09:20 PM | #16 |
Rep 2,138
Drives: Me
Yes, I left the pins installed. I did this to get a baseline delta after installing the shims. I took each shim and measured them with a micrometer and mixed and matched each set so I was as uniform thickness as possible. Essentially I ended up with -2.5 left and -2.4 right. Since this was the values I was looking for, I left the pins in. I could get more camber by pulling the pins but I personally don't need -3+ on a daily driver.
Just remember, if you want to move the strut inward, you do have to take the weight off the car to do this.... For rear camber adjustment, each car will be a little different due to construction variations. I am able to get -2.0' of camber in the rear. I leave 1/16" total toe in the rear for stability. This was the recommendation from the shop. Zero toe in the front. One more thing about 'maintenance documentation'. Generate it and keep it. You will spot trends that will lead you to potential problems. Example: I get my suspension aligned every nine months or so. I keep the before/after alignment sheets in my maintenance book. After three alignments, I started to see a trend that the right rear was always out of alignment much more than the other side. When I had the car up on the alignment rack I asked the shop to investigate this. Easier for them than me. We found a faulty eccentric camber bolt. I even keep an Excel spread sheet with all maintenance performed, by date, mileage etc.. receipts go in the back of the book. |
06-24-2012, 07:37 PM | #18 |
Rep 16
I just had it done Friday...
I decided to keep the centering pins out and move the struts toward the engine to lessen the chance of front tires rubbing against the struts. This would be a concern if you run wider tires. Turns out, there were plenty of space between the tires and the struts. I went with 1 washer inside and 2 washers out side. Ended up with 2.3 - 2.4 negative camber. I'm guessing 2 washers on the inside would give you ~3.2 to 3.3 maximum camber.
You actually have significantly more adjustability with the rear camber as is. |
06-27-2012, 11:14 PM | #20 |
703
06-28-2012, 07:12 PM | #21 |
Rep 4,531
Thanks!
Came back from alignment, ended up with -2.3 in the front at 0 In the rear, it was only -1.3 at 1/16 in. The before rear was at -0.5, which was crazy out of spec. He got the most adjustment he could, but couldn't get anymore. |
06-28-2012, 10:46 PM | #22 |
E86MPilot
23
Rep 265
Mine need to be done too, once I finished adjusting the new coil height. Is the rear camber adjustable without aftermarket parts? I'm hoping maxing out rear camber to (-1.8) can clear my rubbers, it is rubbing slightly on high speed bumps.
Any good alignment shop in Philly/jersey?
E46M, E60/545I, E36/Z3M, E92M DTC, E93M 6spd, E86M(x2), F10 550XI (S2)(Current)
