      05-13-2012, 02:24 AM   #1
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
CDV Quick Question
Hello,
I don't have warranty with my stealership and not worried about it..
Should I delete the CDV or install modified one??
Is it possible actually to just delete it?
2006 M Coupe E86
Thanks
      05-13-2012, 03:21 AM   #2
epbrown
epbrown's Avatar
If you're out of warranty, just remove it. The only reason for a modded one is to fool the dealer...
      05-13-2012, 01:43 PM   #3
asirvr4
Oman
38
Thanks for replaying.
Should I do clutch bleed also?
If yes, whats the most basic diy easy way?
      05-13-2012, 02:01 PM   #4
seank
enthusiast
seank's Avatar
48
Can't you just remove it and reinstall for the VERY FEW things that are under warranty?
      05-13-2012, 08:43 PM   #5
BIMMERGUY91
Drives: 2014 335I M Sport
Just delete it. I did it while under warranty and they never even noticed
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      05-14-2012, 06:11 AM   #6
gtMc
gtMc's Avatar
21
Drives: '08 MC
'03 e39 m sport  [0.00]
'08 mc  [0.00]
yes pretty sure you need to bleed it too. They def bled mine after they opened up the line for the CDV job.
      06-01-2012, 11:40 PM   #7
ArminTamzarian
Drives: Ti 2006 Z4 3.0si
You should bleed the brakes at the same time to change to hydraulic fluid there too. There is only one reservoir.
      06-03-2012, 01:25 AM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
I replaced mine with a modified one, because I was afraid the hose wouldn't easily reach.
Turns out it would have.
I used a "hose squeezer" to keep the leakage to a minimum, and did a fast swap.
Didn't lose any fluid except what was in the volume of the CDV.
Just did a quick bleed to work that one bubble out.
Much smoother shifts from 1st to 2nd, and less clutch wear. Definitely a "must do" mod.
      07-15-2012, 08:43 AM   #9
asirvr4
Oman
38
i did it.. i never regret it.. my M feels much better now..
      07-20-2012, 05:29 PM   #10
D Nice
Drives: 06 BMW Z4 3.0si
Not to high jack the thread, but typically how much would it cost to have an indi shop change the CDV for you? I'm I'm northern NJ and was quoted $300 to replace the CDV as well as change my diff and tran fluids. Which by the way I be providing Redline fluids.
      07-20-2012, 06:06 PM   #11
Geauxkart
Geauxkart's Avatar
13
Drives: 2007 Z4 M Coupe Sepang
You could do all 3 in an hour, 1 helper for 5 minutes to bleed the clutch.
Seems a bit pricey.
      07-20-2012, 07:58 PM   #12
D Nice
I thought so too. Thanks for the response.
      07-24-2012, 09:14 PM   #13
gtMc
gtMc's Avatar
21
Drives: '08 MC
'08 mc  [0.00]
Had mine done along w a tranny mount swap at same time for about the same amount. In north Nj.
      07-25-2012, 08:54 AM   #14
Stromtech
Stromtech's Avatar
Drives: 2004 Z4 3.0i 6-speed Sport
My Indie pulled my CDV off while he had the car on the hoist for something else...no extra charge for the 5 minutes it took him. Hardly worth trying to do it yourself when you can get it done for nothing.
