05-09-2012, 04:57 PM | #1 |
///M-fanatic
193
Rep 3,885
Volk Wheel Hubcentric Rings
Just putting this here for those that have Volk wheels and might be needing hubcentric rings. I've already done some research for you folks
What you'll need are FOUR (4) 75mm --> 72.56mm rings. I'd recommend getting aluminum/metal hub rings if you do any tracking at all, as cheaper plastic ones will melt at track temps. You can order hubcentric rings from various online vendors, but here's one to start off the thread: https://www.1010tires.com/store/p-93...-set-of-4.aspx Just for reference, I personally spent about $50 USD for a full set of four aluminum rings, shipped to me. Good luck, and let me know if you have any questions. Happy motoring! Last edited by mfanatic325; 05-09-2012 at 05:04 PM.. |
05-09-2012, 05:45 PM | #2 | |
Rep 12,565
05-09-2012, 06:14 PM | #3 |
Rep 11,667
Some Volks come in the right hub size
05-09-2012, 06:23 PM | #4 |
///M-fanatic
193
Rep 3,885
Yup! The ones that came with my wheels upon purchase were urethane ones, which were already an upgrade from normal plastics, but they too couldn't take the heat. And I also got some PM's regarding the topic so I figured I'd post it up for the good of all that read
Oh do they now? Because I was under the impression-from some quick research-that Volk just did 75mm center bores for all BMWs, since that way it's less work on them and they have a one size fit all application. Apparently some 5-series have slightly larger hub bore than the usual 72.6mm |
05-09-2012, 06:28 PM | #5 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
E39 5-series, current gen X5s and current gen X6s (only on the front) have the oversized hubs. All others 5 bolt BMWs are the 72.6mm
05-09-2012, 06:33 PM | #7 |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
05-09-2012, 09:44 PM | #9 | |
Rep 11,667
05-09-2012, 11:02 PM | #10 | ||
Rep 12,565
One example: http://forum.e46fanatics.com/showthread.php?t=804763 |
05-10-2012, 12:24 AM | #11 |
///M-fanatic
193
Rep 3,885
Those hubcentric Volks must have been custom-ordered/made. Others--part of Volks' typical run batches--were bored to 75mm for one-size fits all applications (with the use of hub rings of course)
Everyone's right in here. Why are we so damned smart? Can't we be wrong for once? |
05-10-2012, 06:59 AM | #12 |
Rep 11,667
The correct hub size is one of the features of the VR.G2.
With the G2 they do it for all the various model fitments. I guess it's just a feature of this particular Volk wheel . http://www.rayswheels.co.jp/2009/pro...-18&for=import
05-10-2012, 10:38 AM | #14 | |
Rep 12,565
05-10-2012, 10:40 AM | #15 |
Rep 11,667
05-11-2012, 02:28 PM | #18 |
Rep 12,565
Will they ship to nj? If so I'll ship to you.
05-15-2012, 08:09 PM | #22 |
///M-fanatic
193
Rep 3,885
I got my rings in today and surprisingly they're blue anodized
I personally don't mind, since I currently have blue lugs, and there's some blue Volk stickers on my wheels. Plus, you can't really see the hub ring once installed anyhow. I swapped my old warped and cracked urethane-plastic rings out with these aluminum ones and went for a test drive. Found a noticeable decrease in wheel vibration and smoothness |
