04-05-2012, 03:22 PM | #1 |
Rep 91
18" vs 19"
How does the diameter of the wheels affect the car. I'm not talking about look here. Obviously weight is going to be a factor. Would you have insight to share?
04-05-2012, 03:36 PM | #2 |
instagram 997turbotom
286
Rep 7,377
other than weight, the ride is much rougher, the wheel is more prone to bending because there is less rubber to protect it, and the tires usually cost more. If you're considering going wider than 285mm, do research for availability in both diameters.
04-05-2012, 08:09 PM | #3 |
Rep 91
So, there's pretty much no good reason for going from 18" to 19" apart the look (which I don't care for).
Thanks |
04-05-2012, 08:20 PM | #4 |
40
Rep 1,481
I've run both. It really depends on points like >>
a)-one piece cast ? b)-two piece welded ? c)-fully forged ? d)-3-piece & forged center ? Although my 18's had a slightly thicker sidewall...there were a few times it might have felt better than my 19's. But really not enough diff to tell. A hard transition on the Z's transfers quick and hard...end of story really. I put 50K miles on 2 sets of 19's.....one set bent with the breeze and often...the other set is still perfect today. Both weighed in the same and were one piece cast. My 3-piece wheels have seen much less road time....so I'll be finding out how they deal soon. |
04-05-2012, 10:09 PM | #5 |
Rep 206
I have to say that the 19's are much harsher than the 18's. Wish I would have stuck with the 18's for the summer. I run 18's for the winter and 19's for the summer.
04-06-2012, 04:10 AM | #6 |
Rep 5,329
i dont notice any difference, many 19s are now as light as 18s so i think its down to personal preference.... my 19s which were lighter than my stock 18s and have a thinner sidewall honestly??? could i tell the difference?? no way...
04-06-2012, 05:26 AM | #7 | |
Rep 174
Having said that, I'm not sure how much difference one gets from going from the stock 18"s to, say, 18" TE-37's. That is, how much performance/fuel saving you get from that weight reduction. Anyone know? |
04-06-2012, 03:36 PM | #8 | |
Rep 91
From what I understand, the main benefit in weight reduction of the wheels is with the suspension (unspring mass).
04-06-2012, 08:14 PM | #10 |
Rep 91
04-08-2012, 05:26 AM | #13 |
Rep 5,329
thing is with the tyres you run, add the spacers, in all honesty you not "THAT" much lighter imo.....
04-08-2012, 10:49 AM | #14 |
Rep 2,782
The biggest difference is going to be the car's ability to stay glued to the road... like when putting power down on rough pavement, or midcorner bumps upsetting the car quite a bit less. Ride quality varies, because the more quickly the wheel responds the more movement is translated into the cabin, and the rougher the ride feels. Heavy 19's feel like they ride the same as stock because they respond so slowly that the lack of sidewall cushion is offset by the lack of responsiveness. On a sports car this is a terrible, horrible, no good, very bad thing.
Tire Rack conducted a test with wheels of different sizes and weights concluding the same thing I posted above. Another Euro tuner mag put lightweight wheels on their E36 M3 and saw a 7 hp increase on the dyno, although that will vary based on how quickly the car spins up the dyno. All I know is that I have never heard of anyone going to 19's on a Z4 non-M to increase performance- at least anyone who could back up their reasoning.
04-08-2012, 01:09 PM | #15 | |
286
Rep 7,377
18x9 volk te-37 =17.7LBS 20mm ltw spacer = .5LBS max 265/35/18 RE-11 tire = 28LBS total = 46.2lbs stock z4m 18s =25.88 lbs stock size 265/40/18 re-11 tire= 31lbs total = 56.88lbs (10.68lbs over mine) average aftermarket wheel 19x9 =24LBS (OEM CSL =25.5lbs) 265/35/19 re-11 tire =29LBS total = 53LBS (6.8lbs more than mine) to me, thats significant rotational mass
04-08-2012, 03:57 PM | #16 | ||
Rep 91
04-08-2012, 08:24 PM | #17 | |
Rep 1,739
Drives: 2008 Z4MC
Edit - just read Roffle's post above. What he said. |
04-08-2012, 11:12 PM | #18 |
enthusiast
48
Rep 1,695
Tire sizes, and the availability of different tires is the biggest factor for me, which is why I choose the 18's. They also look more racey/performance, rather that cool.
04-09-2012, 12:23 AM | #19 |
Rep 429
IMO 19s are just for looks. However, I've noticed tires play a huge role in ride comfort too, and can mitigate the 19 vs 18 effect. My 19s with Michelins tend to ride better than the Continentals I had on my OEM wheels - though a dip or bump in the road sucks on both of them
04-09-2012, 02:29 AM | #20 | |
Rep 5,329
when i get my REALLY lightweight 18s maybe ill see a difference??? As of now i feel or felt nothing, i believe the stock CSLs were alittle lighter than the stockers but by a tiny amount, as were the studs and nuts, as is the AP BBK, by some margin compared to the stock items..... so factoring in the other losses, my CSL setup is quite abit lighter than my stock setup in terms of unspring mass.....
04-09-2012, 02:35 AM | #21 | |
Rep 5,329
my CSL is lighter than the stock 18" rim, Add in the studs and composite Kics nuts, The AP BBK which was considerably lighter that stock FR and Rear, i think my losses are a decent amount more.... still i notice no difference..... Rotational masses are bigger losses felt due to their nature..... In all honesty??? i dont think we can Ever really start talking about weight loss benefits when we have 30lb of supercharger and cooling gear for the s/c up front..... Once we get into seat installs, now were talking, as were offsetting a good chunk of added weight...
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 04-09-2012 at 05:40 AM.. |
04-09-2012, 08:42 AM | #22 |
Rep 206
Another difference between the M and the other cars were the factory tire sizes. The M came with 225/45/18 and 255/40/18. The Si came with 225/40/18 and 255/35/18. Going to a 19 means 235/35 and 265/30 which does not leave much of a sidewall. Might be why some of you with an M are not noticing at as much.
