      10-28-2011, 08:41 PM   #1
F360C
Drives: E86 S54
Rogue Engineering "Race Brace"
So I have been working with the guys at Rogue Engineering to make a set of front control arm bushings for the Z4M. While there I have fallen in love with this "Race Brace" and had to have one. I like that it was a no BS performance part, light and very strong! Not to mention it looks awesome but that just a bonus. Great so lets bolt it on! Not soo easy..
The issue is that although it looks very close to being able to fit when he put it on the my car it was no where near close. So Mason Engineering (the manufacturer of the Rogue Bars) shipped a raw e46 M3 bar for Ben to custom fit to my car. Turns out that it was a lot of work to fit but after Ben used his magic hands he was able to make it fit perfectly and it will have NO clearance issues all! No washers, no notches, no tight fit! The bar will bolt right on. So instead of just make it a one off he was convinced to make a production run of "Race Braces" for the Z4!
Here are some pics of the raw bar being prototyped on my car. The bar has been test fitted on my brothers car today to confirm fitment and has no been shipped to Mason to make the last modifications and to make the jig.
I am going to try and set up a group buy for these for the community. The non- group buy price should be very similar to the E46 bar. Let me know who would be interested.
07 Z4 M Coupe AW/IR
      10-28-2011, 08:50 PM   #2
johanness
Drives: 2008 Z4MC
Count me in. I've had my eye on the Mason brace since day 1. Thx for the ground-work!
Will they be painted to match stock firewall braces? (i.e. black)
      10-28-2011, 08:52 PM   #3
F360C
Drives: E86 S54
Yep they will be painted black to match!
07 Z4 M Coupe AW/IR
      10-28-2011, 09:00 PM   #4
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Crap on a stick! I just got my Strong Strut installed, and now this nasty piece of temptation comes along! I think I shall have a hard time NOT buying one. (Seriously, thank you for the work on this. It's appreciated!)
But, no red to match your custom valve cover colors?
      10-28-2011, 09:14 PM   #5
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
Nice, it'll be very tempting if the price is under $300
      10-28-2011, 09:24 PM   #6
dorifto88
Drives: 88 Nissan Pathfinder
im in
      10-28-2011, 09:40 PM   #7
Pheonix
2007 BMW/Z4MC  [0.00]
Me too... Count me in
      10-28-2011, 09:54 PM   #8
crfine88
crfine88's Avatar
442
Drives: E86M
Count me in!
      10-28-2011, 10:12 PM   #9
jdl1pt
Drives: Z4M coupe 2007 IL Blue
I could be down depending on price!
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      10-28-2011, 10:23 PM   #10
3002 tii
3002 tii's Avatar
2286
Damn, I wonder if this fits the n52. I'd drive down to Rogue to let Ben fit on mine if he didn't already send out!
Follow for latest mods
      10-28-2011, 10:31 PM   #11
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Drives: Z4 M Roadster
Let me know what you find out! I want one for my n52!
Remus, ZHP, Stubby, H&R Coilovers
      10-29-2011, 12:10 AM   #12
psygnosis
psygnosis's Avatar
23
I'm guessing it does, I would think that the engine that would have most clearance issues is the S54. If it fits that it should fit the rest. The BMW strut brace works on all Z4s doesn't it?
      10-29-2011, 01:13 AM   #13
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
The positioning of the bolt holes for the endplates are the same, but the clearance for non-M motors has to do with the positioning of the oil filler cap.
      10-29-2011, 02:19 AM   #14
sleevez
Drives: 06 Z4MR
I'm in for 1, do keep me posted!!
      10-29-2011, 02:47 AM   #15
claritycheck
Rolling Republic
claritycheck's Avatar
Drives: M Coupe
Count me in for now!
      10-29-2011, 03:20 AM   #16
beta
Drives: 2006 M Roadster
Where's aerobod when you need him with his engineering skills. I'm wondering if it's really worth it to upgrade from the bmw brace to this beefier one.
It certainly looks really well made. Props for sticking with it and getting it modified for our cars
      10-29-2011, 04:44 AM   #17
Beedub
Originally Posted by crfine88 View Post
Count me in!
i dont think this will clear our BPV for the supercharger :-(
      10-29-2011, 07:23 AM   #18
chickdr
Just looked at the Mason Engineering web site. The same bar for the Z3 is $405 in steel and $455 in aluminum. Doubt this will be cheaper....
http://www.masonengineering.net/Subpages/Z3.htm
      10-29-2011, 10:30 AM   #19
BookerM3
BookerM3's Avatar
Drives: Z4 M Coupe
I'm in for an Aluminum one.
      10-29-2011, 10:46 AM   #20
johanness
Drives: 2008 Z4MC
Um, the point of a GB is to be less than the advertised price. OP said "The non- group buy price should be very similar to the E46 bar."
      10-29-2011, 11:43 AM   #21
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
So, a few thoughts about strut braces in general on the Z4. First, referring to the hastily sketched diagram below, there are a few structural considerations:
- A strut brace closes the triangle between the strut towers and the firewall-to-strut braces.
- Most of the problematic flex in the strut towers comes from the vertical wheel loads as the suspension is compressed due to either bumps or load transfer in cornering, this load tries to rotate the tower inwards by applying pressure to the outer point of the triangle formed by the strut, strut tower and lower control arm. The horizontal cornering loads are mainly reacted into the lower reinforcement plate, having little effect on the top of the strut tower.
- A strut brace can only really transfer loads from one strut tower to the other due to a horizontal shearing of the brace, the strut towers and the lower reinforcement. This means the added stiffness comes from making the two strut towers flex together as opposed to independently.
- In the case of the relatively thin strut brace end plates due to clearance issues, the brace can provide little resistance to bending between itself and the top of the strut tower, therefore most resistance is in the form of compressive or tension load along the brace.
Assuming a maximum state cornering situation where ther inner wheels are about to lift off the ground, the maximum load transferred into rotating the strut tower would be about 4000N (assuming about 400kg on each front wheel resolves to 800kg on the loaded wheel, 0kg on the unloaded one). As the outer lower control arm ball joint is about half the distance from the bottom of the strut as the length of the strut, this would lead to a shearing force of up to 2000N at the top of the strut tower.
This shearing force is going to be dissipated through the inner fender/frame reinforcement, triangular braces and strut brace. Assuming the elements other than the strut brace are relatively flexible (which they aren't, but we'll look at worst case), then lets take 2000N as the lateral load on the strut brace.
If we look at material properties, assume a brace length of 1m. The Rogue Engineering brace seems to weigh about 4kg for the steel version, so allow 3kg for the main brace, 1kg for the end plates (M3 brace specs). This leads to a cross-sectional area of 390mm^2. Assuming 200GPa Young's Modulus for steel and a 2000N load, we find the compression or tension in the strut at that load leads to a change of length in the strut bar of 0.026mm.
0.026mm length change is probably very small relative to the inherent flex of both strut towers, so they can effectively be seen as rigidly joined, meaning that flex of one tower can potentially be halved, due to inducing an equivalent flex in the other tower when the strut brace is in place. I would say the OEM brace would probably incur closer to a 0.05mm length change in the same circumstances, but this is still very small (leading to a camber change of about 0.006 degrees, assuming a strut length of 0.5m).
Overall I'd say the Rogue Engineering strut would look very nice especially if painted black, but would be hard pressed to see any noticeable improvement compared with the OEM one in terms of usable stiffness.
      10-29-2011, 01:03 PM   #22
CJW2OO4
CJW2OO4's Avatar
I may be interested in this or the other numerous strut bars members will be selling once they get theirs
