10-08-2011, 04:29 PM | #1 |
Rep 322
Just installed Advan TC IIIs on my MC
I finally got my tires mounted on my Advan TC IIIs. No rubbing issues but used 10mm ECS spacers just to kick out the rears to make them flush with the wheel well. The specs are:
18x8.5 +30 w/Dunlop Direzza 235/40 18x9.5 +30 w/Dunlop Direzza 275/35 Also used studs with neochrome lugs to complete the look & function. Enjoy.
10-09-2011, 05:21 PM | #6 |
Rep 1,143
Nice-looking wheels. Those offsets are pretty similar to mine (a tiny bit more aggressive in the front, less to a similar degree in the back). I notice you're running 235's up front -- any particular reason? I have 245/40R18 up front which end up being closer to the overall diameter of the 275/35 rear, also using tires with fairly aggressive sidewalls (Nitto NT-05) with no rubbing, although I have about -2 camber up front from installing shims on the strut.
10-09-2011, 08:50 PM | #8 | |
Rep 322
11-11-2011, 01:06 AM | #9 |
Rep 700
I don't know know what it is but maybe I have just got used to the new look.
After you go to 19's, 18's look really small When I first got my Z4-M I thought 18's where huge.
11-11-2011, 01:46 AM | #10 |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
18's do look small once you get used to 19's. however you can make up for the size by going lower and running a more aggressive offset. i went from stock 18's to 20's to 19's to another set of 19's and then back to 18's. =P
you can also look at it this way, 18's look big compared to 17's
