      01-23-2011, 10:38 PM   #1
Starscream
Starscream's Avatar
Lets talk X-Pipes, Rouge or SuperSprint?
Well after doing the Euro header and Euro car pipe the only other pipe left would be the X-Pipe,
Is it actually worth doing?
Do you honestly get any power from it?
I'd imagine it would help the headers blow out a few more, so I'm thinking to buy a pipe for when I do my headers in the next few weeks,
But I see Supersprint and Rogue makes them (possibly more vendors too)
I haven't done too much research but whats the call on these?
The cans out back are Supersprint Powerloops, as I'm not a fan of over loud exhausts,
Sporty is fine, noisy is not
Give me your opinions guys
Imola Red Roadster
      01-23-2011, 10:42 PM   #2
Starscream
Starscream's Avatar
This is the Rouge pipe,
[IMG]http://www.**********s.com/zoom_img/_1290169536.jpg[/IMG]
It replaces the green pipe in the picture
[IMG]http://www.**********s.com/images/Products/Black%20Friday/mini-mz4_stock_pic.jpg[/IMG]
and this is the supersprint pipe
Imola Red Roadster
      01-23-2011, 10:54 PM   #3
johanness
Drives: 2008 Z4MC
I have the SS ones, and I noticed a definite increase in power. From what ive read, this is where a good percentage of the bottle-neck is, and opening it up makes nothing but sense. I retained the stock mufflers, so the sound has turned into more of a growl, but minimally so. My $0.02
      01-23-2011, 11:00 PM   #4
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
SS I would said I don't like the quality and the looks of it but I think that they have being better designed then the RE ones. technically our cars don't need a x-pipe and SS is not a real x-pipe design in contrary to the RE's that are truly a x-pipe design. I can see around 7hp for SS and maybe loss of some Hp for RE, but I have not tested the RE ones tho, I will in the future tho.. just my 2 cents...
      01-23-2011, 11:01 PM   #5
Diokaef
Engineer
Diokaef's Avatar
Also SS should not alter the sound as much as the RE's
      01-23-2011, 11:22 PM   #6
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
Hey Diokaef
Why would the Rouges reduce HP???
///M - Some Mods 'N Stuff
      01-23-2011, 11:26 PM   #7
Diokaef
Engineer
Diokaef's Avatar
It's hard for me to describe but in his case he still using cats on sec 1 what change the flow and in the case with the RE's the flow can overlap on the x and increase back pressure.
(I need technical english school)
      01-24-2011, 12:32 AM   #8
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Hmmm.. I was thinkingof getting the RE's when they get stock in from overseas.. It does look like the RE pipe merges with the other pipe. Wonder how much research RE has done on this pipe? From my research the RE pipe is the only one that will mate w/o welding and cutting too. I had the SS pipe but did not feel like messing with the fab work. Johanness had his modded and said it fits good.
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      01-24-2011, 12:38 AM   #9
Diokaef
Engineer
Diokaef's Avatar
It should not be a big problem if you are catless tho!
Edit: Because the design is more consistent with a catless system
Last edited by Diokaef; 01-24-2011 at 12:47 AM.. Reason: Because the design is more consistent with a catless system
      01-24-2011, 12:44 AM   #10
Diokaef
Engineer
Diokaef's Avatar
I don't think that a lot of people know this but half of the design of a x-pipe is done with a muffler in mind. (is kind like a soup, you can't really eat w/o a spoon) so the SS are that way because when you mate to their mufflers you get the expected performance but as a stand alone they don't guarantee improvement or don't even consider the use of other muffler since it can work completely against of what was designed for.
So for the OP, that already have the PL cans the x-pipe should perform as expected, meaning improving sound and performance.
      01-24-2011, 12:55 AM   #11
Diokaef
Engineer
Diokaef's Avatar
Also the other half take in consideration the matching possibilities of the section right before it and usually that is accomplished by a change in pipe diameter to match with the possibilities of running or not running with cats, you will most likely compromise on that area.
      01-24-2011, 01:46 AM   #12
Z4-VILLA
Afghanistan
114
Drives: Z4M Hardtop Roadster
i cant waitt for ocha to chime in
      01-24-2011, 05:51 AM   #13
Starscream
Starscream's Avatar
Well Supersprints look to be the way to go then,
I have the SS pwerloops as mentioned so they should bolt up to that without mod,
Do they bolt up to the section 1 (cat pipes) without mods?
Could have sworn somewhere I read the SS x pipes required modding to fit,
This way the cars exhaust setup will be OEM Euro Headers, OEM Euro Cat Pipe with o2+EGT Bungs from factory (unsure of Cat cell count, Assuming same as USA cats) "Brand xxxxx" X Pipe, Finished with Supersprint Powerloops
Imola Red Roadster
      01-24-2011, 07:38 AM   #14
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I had the SS X section & P.Loops on my M Roady & they were a great setup.
Since you have the loops I would definitely stay with the SS X.
For many; the main consideration will be matching to the rear cans you have.
The RE is a direct OE replacement with no extra fittings.
Since I have Eisenmann cans (OE flanges), I ordered a RE X section.
I'll post my findings when I get it.
      01-24-2011, 07:45 AM   #15
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Are you powder coating the X-Pipe too?
2006 Z4MC - #LL93158
      01-24-2011, 07:47 AM   #16
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
don't see much point to it
      01-24-2011, 07:47 AM   #17
Starscream
Starscream's Avatar
Does the Ssection 1 pipe end match up on the SS X pipe?
From the pictures it looks a little off,
Imola Red Roadster
      01-24-2011, 07:47 AM   #18
mousitch
Dark Sider
mousitch's Avatar
129
How long were these backordered? Im waiting till they are stocking. Have any clue when they will be in the states?
      01-24-2011, 07:49 AM   #19
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes, it's a direct fit.
      01-24-2011, 07:52 AM   #20
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
IIRC, end of Feb. mid March.
I wanted to get my order placed because backorders will be filled before new orders.
I have no idea how many they're bringing in & didn't want to miss this 1st shipment.
      01-24-2011, 07:53 AM   #21
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
There's a certain perfection in everything you do (to the car) - would not have surprised me if you matched the mufflers
      01-24-2011, 07:59 AM   #22
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
They say there is better heat retention within the system when ceramic coated.
