      10-21-2010, 03:38 PM   #1
Eccentric
Eccentric's Avatar
51
Drives: Interlagos Z4 M Coupe
Largest tires on stock rims
Hey guys, what's the largest width tires I realistically can fit on stock rims? I'm sure there's a post about this but the search bar came up with too many unrelated results. So, can u guys help me out?
      10-21-2010, 03:45 PM   #2
F360C
Drives: E86 S54
I run 255/35/18 front and 275/35/18 rear Toyo R888 rcomps on the stock rims. I tried the 285/30/18 R888 in the rear but it wouldn't even fit in side the fender when it was not on the rim. I did run a 285/30/19 Bridgestone RE050A on my OEM zcps but if you want the car low expect a bit of rub de dub
07 Z4 M Coupe AW/IR
      10-21-2010, 03:50 PM   #3
Eccentric
Eccentric's Avatar
51
Thanks, man- if I dropped the car 1.5" do you think the 275s would rub?
      10-21-2010, 04:08 PM   #4
F360C
Drives: E86 S54
With the 18s you shouldn't rub at all. I am low in the rear... like the top of the tire and fender are equal height and I don't have any rub at all with the 275 18's.
07 Z4 M Coupe AW/IR
      10-21-2010, 04:12 PM   #5
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
WOW. 255's R comps on a 8.0in? Now I can stop worrying about future 245s on 8.0" then...
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      10-21-2010, 05:00 PM   #6
Serious
1M advocate
Serious's Avatar
Drives: 2018 S4. 2011 M3. 2012 S1000RR
Be aware a wider tire isn't always a superior setup.
As you increase width you decrease turn in response due to increase sidewall flex, and increased tramlining... also the contact patch area doesn't increase nearly as much as you would think going from a 255 to 275 tire.
I stick with the stock tire sizes, I've tried all the various sizing on my e46 m3 and honestly I never found the results desirable... most of the increase in grip was going from old dead worn out tires to new tires with improved compounds.
2012 BMW S1000RR
2011 BMW M3
      10-21-2010, 11:43 PM   #7
Eccentric
Eccentric's Avatar
51
thanks for the advice, guys
