      09-27-2010, 11:52 AM   #1
dekaliber
Ugh, drove with the gas cap open
Stupid confession:
I arrived at the track this weekend about 30 miles from where I filled up and noticed, much to my great chagrin, that my gas cap was off. The only possible explanation was that I simply forgot to cap off the tank after filling up (a first). I'm still pretty perplexed as to how I didn't notice this even in my mirror aside from the fact that it was very early in the morning and still dark.
Anyway, most of the drive was highway but about a 1/4 mile was over a gravel road where the cars in front of mine kicked up some pretty mighty clouds of dust. My car arrived with a light film of dust over it but the gas tank opening didn't look visibly dirty. However, I'm wondering if I should be considering changing out the fuel filter. Car is at about 18600 miles or so after the weekend.
Oddly enough, I didn't see that a fuel filter replacement was ever listed on either the Inspection I or Inspection II checklists -- is this supposed to be a "lifetime" part?
I haven't noticed anything negative in terms of performance. The engine felt strong and responsive both days and my fuel economy on the 3.5 hr drive back home seemed as good or better than it ever has been, so I'm wondering if I'm getting all worked up over nothing.
      09-27-2010, 12:25 PM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
lol don't worry about it dude. I've never done this before, but I'm pretty darn sure there's nothing wrong with your car. You probably didn't notice the gas cap thing because the fuel door was probably slightly shut due to air turbulence when you were driving after the fill-up. In which case, you're even more safe, since the filler door probably by-passed over 90% of all the debris. Thennn you've got the actual little metal sliding plate where the fuel nozzle goes. That will act as your second "door" to block out debris. And fuel should be evaporating ever so slightly out of the uncapped portion of your filler. I would say all of that adds up to blocking almost 100% of all debris. So I wouldn't worry about this incident at all
      09-27-2010, 02:01 PM   #3
Alicate
Raw Conscript
Drives: Z4M - E90M3
I failed to tighten mine properly and the computer threw a CEL light in less than a mile. I immediately stopped but after tightening it, it still took several cycles before it disappeared. Anyway, even if some dust entered your tank, the particles are very small and if not trapped by the filter, I don't think they would cause trouble.
      09-27-2010, 02:37 PM   #4
bhoch
SSGT USMC - '78 - '86
bhoch's Avatar
Drives: Z4 3.0si
2007 BMW Z4  [7.33]
Not in my Z.. but in wife's 325ci we had the light on dash come on shortly after filling. took cap off/on twice and drive a little bit before it cleared. I am surprised you did not get a warning light on dash. Either way, you should be fine.
Thanks,
Bill
2007 3.0si Roadster Black/Red, sport, Piano Black F14 Forgestar's
      09-27-2010, 03:03 PM   #5
epbrown
epbrown's Avatar
I bought my first Z4 in Des Moines and drove it back. About halfway home I discovered I had left the gas cap off. The CEL came on, but it had cycled off by the time I got home and I drove the car for two more years without incident.
      09-27-2010, 03:44 PM   #6
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Car is ruined, might as well sell it to me on the cheap
I think you should be fine. Little grit in the tank won't hurt much. God made dirt, dirt don't hurt. If it is large enough, it would get caught by the filter. Smaller stuff won't cause a problem.
      09-27-2010, 04:52 PM   #7
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
What's odd is we actually have a "check gas cap" light. The only time I've actually seen it illuminate was when I drove off from the gas station, saw my fuel door open, stopped and closed it... THEN the "check gas cap" light turned on. I turned off the car and restarted it - no light. Maybe it can only sense a change in the gas cap's state and not its position?
      09-27-2010, 06:17 PM   #8
Swashplate
Swashplate's Avatar
Drives: in Anger.
Well It might be harder than you think. Please correct me if I am wrong but isnt there a filter on the pump inlet that is inside the fuel tank. This is very common with most modern cars....
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      09-27-2010, 10:18 PM   #9
dekaliber
Yeah, weird thing is that my CEL never came on. I thought that it would if the cap was loose or not on at all. The last time I saw a CEL was on my '04 RX-8, and it was when I hadn't tightened the cap the full 3 clicks, so I'm surprised that it didn't come on in this case.
I guess my only concern was that if any crap got in the tank it would prematurely clog the fuel filter, but it sounds like I shouldn't be stressin'. Thanks everyone.
