      09-12-2010, 08:21 PM   #1
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
EZ-Key on my car
Just finished installing this today.
No keys needed, not even for doors.
Give me your thoughts on it
[u2b]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/kOWgprraujo&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_ US&feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/kOWgprraujo&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_ US&feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>[/u2b]
      09-12-2010, 08:31 PM   #2
Diokaef
Engineer
Diokaef's Avatar
some pictures
      09-12-2010, 08:46 PM   #3
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Go to the "Edit Video" page from your YouTube account "My Videos" tab. Then you'll see a snapshot of your video in the center & somewhat on you right-hand side of the screen. On the bottom right of this snapshot will be a little pull-up button which will provide you the proper Embed link. I haven't had any issues using the link generated by that pull-up button. G'luck!
      09-12-2010, 09:36 PM   #4
r4gs
Viper Driver
Singapore
36
Drives: F-16
looks very neatly done. where exactly does the key go since it looks to be a push start ignition?
      09-12-2010, 09:49 PM   #5
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
^ no keys anymore. He inputs a code to start the car up.
135i N54 manual
MR-S with a 2zz swap and mods Sold
EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold
Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold
      09-12-2010, 09:55 PM   #6
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Awesome mod. I suppose you still need the key to get into the car if it's locked.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      09-12-2010, 10:15 PM   #7
Diokaef
Engineer
Diokaef's Avatar
Nope, I just need to touch the door in a certain sequence. No keys, the transponder of the key is replicated by the module.
      09-12-2010, 10:27 PM   #8
Diokaef
Engineer
Diokaef's Avatar
Thank's it did fix.
      09-12-2010, 11:52 PM   #9
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
wow, f'ing sweet. I would love love love to get that done to my car! road trip to East Peoria IL?
      09-12-2010, 11:57 PM   #10
Diokaef
Engineer
Diokaef's Avatar
System overview EZ-Key
␣ Up to 5 user codes can be easily programmed at the keypad to give temporary or permanent access to family or friends.
To unlock the car system, simply enter your personalized 4 to 8 digit access code at the Keypad. After a valid code is entered, trailing digits can be used to open a trunk, storage compartment or operate any electrically controlled auxiliary device.
␣ Keypad lights at first touch for nighttime convenience. Not really a diy type device.
Tamper Alarm Multiple incorrect entries trigger Tamper Alarm, lock out system for 30 seconds and flash the dome light • Easily Programmable at the Keypad Add, Modify or Delete Users from the Keypad • Vandal Resistant Design Fully encapsulated, back mounted piezoelectric keypad and main Module built with 3500 PSI impact resistant Urethane and is fully water resistant, also keypad water resistant.
• Current Draw
Standby < 15mA < 25mA Maximum 75 mA 100 mA
• Keypad Switch Technology Solid State Piezoelectric with no moving parts • Dimensions
Height Width Keypad 1” (2.5 cm) 5” (12.7 cm)
• Keypad Operating Environment
- 40°C to + 70°C (- 40°F to + 160°F) 100% Relative Humidity Depth 1⁄2” (1.3 cm)
Last edited by Diokaef; 09-13-2010 at 01:05 AM.. Reason: corrected the text that was posted for one of my other systems, sorry
      09-13-2010, 12:00 AM   #11
Diokaef
Engineer
Diokaef's Avatar
      09-13-2010, 12:07 AM   #12
Diokaef
Engineer
Diokaef's Avatar
I forgot to mention that I did not cut any wires on my car, all was done plug and play. only thing that I had to do was remove the tumbler lock with no damages to it and drill the dash and the sunglass holder.
      09-13-2010, 12:33 AM   #13
papitosabe
Drives: '06 Z4 Coupe
nice!
      09-13-2010, 12:47 AM   #14
mhrir
Drives: Very fast
I actually had to watch the video a few times. It is facinating the mods that are available in this world. I will admit it is not for me, but it looks pretty good.
      09-13-2010, 12:50 AM   #15
Diokaef
Engineer
Diokaef's Avatar
you can do anything that you put your head to, this system will last around 25 years if I press that button 11 times per minute during 25 years.
      09-13-2010, 12:54 AM   #16
Diokaef
Engineer
Diokaef's Avatar
Yes the lighter on the old ignition key hole is fully functional and I build the module with an extra output just for that.
      09-13-2010, 01:07 AM   #17
Diokaef
Engineer
Diokaef's Avatar
I will post a video to show how the door work's once I'm done installing it.
      09-13-2010, 12:02 PM   #18
WhoU4
WhoU4's Avatar
Drives: '05 Z4 3.0i
Surprised EZ-Key doesn't have a web site... What's up with that?
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP
      09-13-2010, 12:22 PM   #19
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
that's friggin SUHWEET!!!
how much, if you don't mind, did that cost and how long did it take to install??
also, that cig lighter/acc in your old ignition, is that now a second one? I only ask b/c it's inconvenient, for me, b/c I use my radar and GPS...but only one cig lighter, so I can only use one at a time, or until the GPS dies...
      09-13-2010, 12:53 PM   #20
-c-
-c-'s Avatar
Drives: bmw
yea were do you buy something like this. also would the push button retrofit kit for the mini cooper work with are ignition?
      09-13-2010, 05:30 PM   #21
jrich4411
Drives: 2006 ///M black on black
Do you have to press your code each time you stop your car? It looked in the video like the car went to accessory mode when you pressed the start/stop button with the car running, and that you had to enter your code to get all the electronics to actually shut down. Also, do you need to enter your code to lock the car or is there a quick shortcut? On my Fords I only need to press the 7 & 9 keys together on the door and it will lock all the doors.
      09-13-2010, 05:41 PM   #22
Crimson92
Smiling Politely
Crimson92's Avatar
Drives: Like a boss
this will makes trips to the dealer interesting
awesome mod dude
Some people are like slinkies...not really good for much but you can't help but smile when you see one tumble down the stairs"
