      08-02-2010, 07:29 PM   #1
03BeastCharmer
03BeastCharmer's Avatar
260
Drives: '13 M3
Vorshlag Camber Plates for Z4M?
Has anyone installed Vorshlag camber plates on a M Coupe/Roadster? Trying to figure out which set to get, and if they suffer from the same issue that other camber plates have where you can't adjust all bolts without lowering the strut. Want to be able to just quickly jack up front and shift from street to track settings without taking apart half the front suspension.
If not Vorshlag, any other recommendation where this approach would work?
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      08-02-2010, 07:50 PM   #2
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
You might want to try TC Kline's. They say it only takes like 5ish mins per side.
http://www.tcklineracing.com/monoball.htm
      08-02-2010, 08:53 PM   #3
jmillet
jmillet's Avatar
65
I have TCK camber/caster plates in conjunction with the TCK DA Coil Over suspension. It takes me about ten minutes per side to adjust the camber.
Name:  TCK DA Coilover.jpg
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      08-02-2010, 09:08 PM   #4
Juice84
Juice84's Avatar
Drives: '03 2.5i Z4
Which rear top mounts did you get? Ive started leaning toward the TC Kline setup over the GCs and KWs
      08-03-2010, 08:45 AM   #5
03BeastCharmer
260
Drives: '13 M3
But Jim haven't you said the TC Kline versions is loud.? What are the basic steps you have to go through to change camber with the TC Kline set?
      08-03-2010, 09:13 AM   #6
Shereef_Osman
Drives: 06 Z4MC & 89 325is
It's very basic:
- Jack up one side of the car.
- Loosen the three strut bolts.
- Push the top of the wheel in to increase camber, or adjust as required.
- Tighten the three strut bolts.
- Drop the car.
- Do the same for the other side.
