07-23-2010, 06:58 PM | #1 |
Rep 2,460
just got the bavauto ashtray drop in aux/audio thing....
it comes with a nice little cable already attached with a plug at the end....question is, where does it go? i see no corresponding plug that will mate to it. advice?
07-28-2010, 08:49 AM | #4 |
Rep 4,062
So how do you get at the back of the radio?
Huz-Z
10-14-2010, 10:34 PM | #6 |
Viper Driver
36
Rep 1,311
^giant bump here, but i just did this mod myself. was actually more straightforward than i'd thought! ashtray is actually made of soft touch material, feels better than the stock ashtray. then again, it is an ashtray.
1. remove old ashtray and remove single screw + washer. 2. gently wiggle the console piece (it's one entire piece with the dsc, heated seats, convertible buttons etc) side-to-side grasping at the empty hole. it will be helpful to remove the cigarette lighter. 3. once the console piece pops out (rear first, then front), thread the aux input cable through the huge opening where the ashtray sits and line the cable off to the right side directly under and slightly to the left of the cigarette lighter socket. thread the rest of the long cable into the actual dashboard itself. 4. using a flathead screwdriver, pry open the plastic cover directly underneath the hvac controls. using ur left hand (right hand doesn't seem to work for this diy), reach down and grab (so to speak) the aux cable head. 5. the actual seating of the socket is the bottom left corner of the radio head unit when u're staring straight at it. using ur left hand again (right hand will not fit), grasp the socket with the clip on top and the whole piece facing u and reach into and behind the radio head unit and seat the socket into the back. there is a noticeable seating area and u will feel a satisfying click when the socket is properly seated. 6. turn on radio and test! voila! 10 minutes tops. this will not work if u have a 6-cd changer or satellite radio plugged into where the aux input would go. |
02-27-2011, 09:24 AM | #7 | |
Rep 204
Very helpful
I just installed the AUX input and r4gs' directions are right on the money — with some added commentary below... sorry, no pics!
04-24-2011, 03:43 PM | #9 |
Rep 428
I just got ashtray/aux input piece and am looking to install it today. Everything sounds pretty straight forward. Did you both disconnect the heated seats/DSC plug when pulling the console out? You said you gave the console a good yank....I guess I'll understand when I see it.
Other than that, the directions make it seem pretty easy to do.
1999 /// M3 Convertible Techno Violet |
04-25-2011, 12:16 PM | #11 |
Rep 428
So, I got everything apart and I was sitting in the passenger seat, trying to feel around on the back of the radio and I didn't feel any open port....there wasn't much to feel for.....could something be plugged in already? I don't have a 6 disc changer, but I do have NAV.
04-25-2011, 01:13 PM | #12 | |
Rep 428
#3, my console actually has no clips up front, and the "hangars" that look like half-moons are actually on the rear (facing it) So, after you remove the screw, you pull the front of the console up and swing the rear down. The half moons fit into two slots that you'll see. When you reinstall the console, you have to make sure those two "half-moons" fit into those two slots, fit the rear underneath the trim and push down on the front of the console. I went ahead and removed the front vents, which took some time, but wasn't too tough. Close the vents, and move both center slides to the middle. You will hardly see two tabs (they are painted black, which through my multiple trials of pushing them down, chipped them so they are silver again). Credit cards weren't thick enough, but once you get those tabs staying down, you can pull the vents forward. Two silver screws and the radio pulls out. I found a plug in the slot that I needed. Once I removed the plug (there is a tab that you push down that will allow the plug to be removed) the plug from the aux/ashtray is exactly the same kind and slides right in. Reinstalled everything and hit "Mode" until I saw the Aux function....I chewed up my left hand reaching behind there, so if you are unfamiliar, removing the vent and pulling the radio may be easier for you to understand how everything is supposed to fit. Just my $.02.....if I had to do it again, I'd have it done in 20 minutes. Took me an hour after all was said and done. Make sure you use the new screw that comes with the aux/ashtray.
04-25-2011, 03:54 PM | #13 |
Viper Driver
36
Rep 1,311
^glad my instructions were of some help, however limited. i was contemplating going the air vents and removing the radio route, but i was able to maneuver my hand and wrist to slot the connector in-place.
what was the other connector that was occupying the slot originally? it's either sat radio or cd changer. Last edited by r4gs; 04-25-2011 at 04:06 PM.. |
04-25-2011, 04:00 PM | #14 |
Rep 428
You're instructions were fine. Had there been nothing plugged into the slot, I'm sure it would have taken me a couple minutes to get it in there.
I have no clue what the plug is for...I don't have satellite radio or a cd changer.
04-25-2011, 04:22 PM | #16 |
Rep 428
I wish I did this two years ago when I bought the car.....love having my iPod music in the car now! Don't have to have all those CDs.
05-01-2011, 10:08 AM | #18 |
Rep 428
I bought mine from the dealer....was around $70. But easy to install and well worth it to me.
05-07-2011, 05:45 PM | #19 |
Rep 715
bought mine from bavauto few months ago as well...great mod!
simple 30mins...loving it with my mp3 player
RPI scoop|BMC drop in filter|EAS V1 aluminum mount|ZHP shiftknob|RHO plate holder|matte black grill|LED interior & license plate light|RE SSK|RE tranny mount|UUC engine mount|Bavarian CDV|clutch stop|18" Forgestar CF5 GOLD|RPI exhaust|H&R coilovers| RE RSM|
coming soon: aFe intake|tune|secondary cat delete| |
