      05-24-2009, 10:29 PM   #1
spg
spg's Avatar
Drives: IR Z4mC
zcp/csl pics on lowered z4mc
Looking for forum members pics Z4MC lowerd w/ csl/zcp???
      05-24-2009, 11:07 PM   #2
jra
Drives: 2005 z4
search for threads by forum member sixspeed, I believe he has pics of his oem zcp wheels in both silver and a new refinished version.
      05-25-2009, 06:07 AM   #3
epbrown
epbrown's Avatar
Here are a few of mine:
      05-25-2009, 08:50 AM   #4
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
sixspeed has gunmetal csl's
Best Website EVER!
      05-25-2009, 04:44 PM   #5
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Just picked this up a few weeks ago, still modding it but need to snap some better pictures now that it's here in FL. Going to get the stock ZCP wheels powdercoated in Charcoal or Black like my M3 in the next few weeks but happy with how it looks now.
      05-25-2009, 06:14 PM   #6
apexstrafer
Drives: Z4 M Coupe
It probably isn't very practical, but your car looks awesome at that ride height. That's what I initially envisioned my Z4MC looking like before I got mine; white slammed on CSLs. I vote for keeping the wheels in silver, but props either way.
      05-25-2009, 07:53 PM   #7
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
I drive the car everyday like that , so far so good. Added the RPI skidplates to the car and don't go off-roading but haven't had any problems. Had quite a few sports car prior to this so I'm used to driving cars that are slammed, here in FL we're fortunately to have relatively smooth flat roads.
I'm still up in the air on wheel color, all my other cars normally have black wheels so I figure why make this one any different, car will likely get CCW C2Ks for the track so I'll switch it up.
      05-25-2009, 09:35 PM   #8
spg
spg's Avatar
Drives: IR Z4mC
Is that stock ride height?
      05-26-2009, 06:34 AM   #9
epbrown
epbrown's Avatar
The black one is stock, the white one is lowered.
      05-26-2009, 08:38 PM   #10
F360C
Drives: E86 S54
My OEM ZCP with a 15mm front spacer and running H&R springs. I think I am going to grab a 3/5mm rear spacer because I have been running my brothers BBS ch's for the past week and the more aggresive rear offset of those wheels looks much better. Oh and the red stripe on the wheels is now gone....
07 Z4 M Coupe AW/IR
      05-26-2009, 09:34 PM   #11
crfine88
crfine88's Avatar
442
Drives: E86M
csl's + 1" drop
19" csl's H&R sport springs (for now)
sorry about pic size
      08-17-2009, 08:59 PM   #12
spg
spg's Avatar
Drives: IR Z4mC
any updated pics?
      08-18-2009, 10:10 AM   #13
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
A few, I've since had the reflectors color matched and am about to have the wheels re-powdercoated a darker color.
      08-18-2009, 02:45 PM   #14
apexstrafer
Drives: Z4 M Coupe
^^^ So nice...
SPG: Sounds like you've been thinking about CSLs for a while now, what's stopping you? They may be common on the forums but I've only seen one other M coupe with them in person. In my opinion they really are the best wheel for the car. I have the 18" reps, only because R-comp tires are hard to find in 19", but if I didn't have that requirement I'd have the 19s, they look much better. Do it.
Pic of 18s for reference...
      08-19-2009, 04:08 AM   #15
mimsterzx7r
mimsterzx7r's Avatar
Drives: 07 M Roadster, 03 Pathfinder
Anybody else running front spacers on the ZCP wheels? I did the calculations and the fronts are retracted 5mm from the outside edge with the ZCP front offsets vs the stock wheels (the rears extend 11mm vs stock). I'm thinking of running spacers on the front but I'm not sure how much to extend them. I know some guy run anywhere from 5mm to 15mm.
After installing the wheels I can tell that the fronts are more recessed than I would like them to be. For people running 15mm spacers have you had any rubbing issues at full lock?
I've also heard that spacers aren't good for the overall life of your wheel and they can be a detriment on the track/spirited driving, causing undue stress on the wheel.
BTW I'm dropped on Dinan springs so much more subtle than the H&R springs. I'll post some pictures when I can.
ZHP knob/Zeckhausen CDV/ESS Tune/More to come
      08-19-2009, 09:35 AM   #16
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
I' believe I've got a 10mm (may be 15mm) on the front with camber plates maxed out, no rub at full lock.. I've also converted to bullnose studs on all 4 corners.
^^^ So nice...
Where did you get the 18" Reps and what do they weigh ? Been searching for track wheels but most of the Reps I've found are 4-5lbs heavier than comparible SSR/TR Motorsports/Enkei/Volks etc.
      08-19-2009, 01:32 PM   #17
apexstrafer
Drives: Z4 M Coupe
Spacers aren't needed with genuine CSLs or reps (.5" wider than ZCPs).
I got my reps through **********s.com, killer price and service.
Link (select M3 fitment): http://www.**********s.com/_e/Veloci...d_M3_cars_.htm
They weigh 24lbs each, which isn't the lightest on the market but they're strong enough for harsh track duty and so cheap that they're almost expendable if you do bend one.
For $750 a set of good looking, strong, perfectly-fitting wheels, I'm certainly not complaining. Remember, when it comes to wheels, pick two of the following: light, strong, cheap.
      08-19-2009, 07:34 PM   #18
epbrown
epbrown's Avatar
That's the "net factor." You see a ton of them on forums and figure everyone's got them. In reality, I've seen 3 other M Coupes in person since 2006, none of which had CSL-style wheels. It's only here it looks like everyone has them.
      08-20-2009, 08:57 PM   #19
spg
spg's Avatar
Drives: IR Z4mC
^^^ So nice...
oem zcp's ordered!
      08-23-2009, 03:11 PM   #20
Evoking
Drives: Z4M Coupe
Onelove, what suspension are you running. I have H&R springs but want to go lower!
      08-23-2009, 04:06 PM   #21
JB 007
JB 007's Avatar
Cyprus
44
Drives: Z4MC RRS MINI...
If you want to go lower read "lowest suspension?" thread on suspension & braking chat.
I hopefully It helps you
Z4MC_Black Sapphire/Imola-_-DMS ECU ll H&S cat-back ll H&R coilovers ll CF Lip ll Lamin-X ll Matte black kidneys ll Afe drop in ll Afe intake elbow ll RPi scoop ll LeatherZ imola shift boot ll ZHP knob...
      08-23-2009, 09:21 PM   #22
onelove
Track Head
onelove's Avatar
Drives: 07 Z4M
Full TC Kline DA setup with maxed out camber plates.
