01-28-2024, 02:57 PM | #1 |
Rep 35
Help removing exhaust manifold
Replacing the head gasket on my 2003 3.0i, but I can’t get enough room to slip the exhaust manifolds over the studs. Anyone have any tricks for getting these out? I bent the head shield out of the way with a mallet, but it doesn’t seem to want to go any further.
01-29-2024, 08:14 PM | #2 |
Rep 2,706
When I replaced the OEM manifolds with tubular headers, a number of the studs wound out with the frozen nuts.
You might try (not a recommendation) double nutting the studs and try winding them out of the head. This is what I ended up doing. Luckily I did not damage any threads in the head. OR just remove the head with manifolds attached.
01-29-2024, 08:18 PM | #3 | |
Rep 35
01-29-2024, 09:00 PM | #4 |
Rep 2,706
Not exactly what you're dealing with as the manifolds go, but shows the extent of the manifold overhang to the collector flanges.
01-30-2024, 01:05 PM | #5 |
Rep 424
Sent from my smart phone...
01-30-2024, 03:37 PM | #6 |
Get off my lawn
938
Rep 1,162
Not sure I fully understand the situation, however here is an image from when I replaced the exhaust manifolds and gaskets - removed the air pump valve and hose for clearance if I recall
This DIY may be helpful https://www.billswebspace.com/BMWZ4M...stallation.htm |
01-30-2024, 06:46 PM | #7 |
Rep 2,706
Might be that the M54 head sits a bit closer to the strut towers and other interferences than the S54 head
02-06-2024, 06:53 AM | #8 |
Rep 35
Just a sort of update in case anyone has the same/similar issue, you are in fact able to pull the head and just leave the manifolds intact. I did end up snapping both of the side tensioner guides, but I think as long as you know what you are doing ( I didn’t know they were there D: ) then you should be fine
