07-27-2023, 03:23 PM | #1 |
Rep 7
Drives: 08 3.0SI Black/Red Conv. Man
Red light, no roof
I replaced the pump motor on my 08 Z4 without removing the roof. Now when I open the roof all is good. Roof actuates, goes into the well, led lamp goes out, motor stops. However the roof won't close. Motor runs but roof won't move. If I pick the roof up appox 1/4-1/2" then then try to close it, using the pump it does close. No problem. So now I open the roof, but stop just short of were the roof would stop automatically. But that means I drive around with that light blinking if I have the top down. Is there an adjustment or sensor that can moved to fix this?
07-28-2023, 01:43 PM | #2 |
Rep 160
There are two sensors on the hinge lifter located behind the drivers seat. You'll have to drop the top to see them.
Unless something is lose, I honestly wouldn't play with them. Your issue might be a sensor but, it also might be the start of the convertible controller going bad. Since the top is now coming down and with a little help going back up I wouldn't fool with it. |
07-30-2023, 01:38 PM | #3 |
Rep 4,062
In the trunk next to each hinge there is a black plastic knob. By rotating both of these knobs you can raise the dash in the rear window to make more cargo space in the trunk. Doing so locks out the roof motor.
Check to see that both knobs and the dash are fully in the lowest position. |
Aloyouis210.00 |
12-31-2023, 04:29 PM | #5 | |
Rep 82
01-02-2024, 02:43 PM | #6 |
Rep 4,062
I’m delighted that you found this helpful. By the way, lots of other good info in the owners manual at https://cdn.dealereprocess.org/cdn/s...mw/2007-z4.pdf
01-02-2024, 07:47 PM | #7 | |
Rep 82
I had downloaded the manual from another thread. Was that you too? |
