      01-24-2023, 04:43 PM   #1
rocky79
rocky79's Avatar
Drives: 2007 Z4 Coupe 3.0SI
E86 Fuel Smell
Hello,
Did anyone experience fuel smell from his E85/6.
Mine is a 2007 E86. When I park inside the garage i started noticing a significant fuel smell.
I checked the engine, there is nothing there ( no smell), no fuel dripping.
The gas cap looks good ( the rubber still soft and no cracks)
The smell is stronger around the rear wheel well area near the tank. Before I start taking things apart I would like to see if this happened to anyone here and maybe can pinpoint where it might be.
Any ideas is highly appreciated.
Thanks in advance.
Do it yourself Illustrative site.
http://diyrabbit.com/
      01-25-2023, 08:52 AM   #2
wdb
dances with roads
wdb's Avatar
4763
I'm not aware of any particular issue on these cars but I'm not an expert -- just a longtime reader of the forum. First thing that I thought of was the evaporative canister though. Those can become saturated and fail.
Good luck and please keep us updated!
      01-26-2023, 02:03 PM   #3
rocky79
rocky79's Avatar
Thanks for the reply. I might have to do a smoke test.
      01-26-2023, 09:37 PM   #4
Our03z4
Drives: 2008 BMW Z4 3.0si Coupe,
I've noticed a fuel smell in my garage as well but I just assumed it was my Omni. Interesting thought that it may be the Z.
      01-29-2023, 02:48 PM   #5
rocky79
rocky79's Avatar
I took it to a Bimmer mechanic and he immediately told me it’s a leak around the fuel pump which will require a new fuel pump assembly.
He said that’s very common.
Failed plastic parts in critical locations cause so much pain and unneeded repair bills.
wdb4762.50
      02-04-2023, 01:58 PM   #6
rocky79
rocky79's Avatar
Some shots of where the leak is. It turns out it sure was from the fuel pump housing. It’s mostly plastic parts and the location of the pump makes the repair $$$.
I got quoted 5 hours of repair time @$150 an hour.
Although it might be only a seal issue I have been told by multiple mechanic to change the pump and the filter at the same time.
Total parts is ~$ 650 ( Only OEM, no afftermarket option available)
Labor is $650.
A $1300 repair
      02-04-2023, 02:14 PM   #7
Our03z4
For $650 in labor I wouldn't of messed with it myself. I don't think the price is too bad, glad you got it figured out!
      02-04-2023, 02:32 PM   #8
grannyknot
grannyknot's Avatar
953
Drives: 2008 Z4M coupe
They made getting to the fuel pump about as difficult as they possibly could.
I know that's a lot of money but the whole job in 5hrs, that's pretty good, big job.
2008 E86 M coupe
      02-05-2023, 05:55 PM   #9
rocky79
rocky79's Avatar
Thanks.
Yes, they did. it’s a compact car to begin with. Not much wiggle room.
Next step is replacing the oil pan seal, that’s another $$ repair.
