      08-09-2022, 01:32 AM   #1
aureliogut
Drives: Z4M Coupe
DME 2F71 ans 2C92 diagnosis faults
Good.
Last week I experienced a rough running of the engine, similar to an injection failure in my Z4M coupe. After a long day of travel, about 8h.
I have looked at the diagnostics and found 2 faults.
2F71 electrical device box fan.
and 2C92 exhaust temperature sensor.
Has anyone had these errors?
The sensor is easy to change but the fan could be a more complicated fault to solve?
Thank you
      08-09-2022, 03:09 AM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1624
Drives: 2007 Z4MC
I've had the 2c92 egt sensor code, easy to swap out, just make sure you buy the correct one, USA is different from euro.
      08-09-2022, 09:33 AM   #3
aureliogut
Drives: Z4M Coupe
thanks. I see is easy to change.
i´ve tryed the car 3 times after the motor fail, and the motor worked well.
I think the problem is an electronic component which heated and made a bad signal.
maybe wouldnt happen againg if i dont drive for many ours, but ill try to repair the fan code.
