      05-19-2019, 07:49 AM   #1
DVCNick
Drives: 2006 M Roadster
Houston, we have a problem... (another starting issue)
So yesterday I hop in the car (06 M roadster). Turn the key, everything lights up normally at the accessory position. As soon as I hit the starter, I hear a very faint pop and all power is lost. No click, no lights, absolutely nothing.
Any ideas what this could be? I just changed the battery a couple weeks ago, and took it out for a drive after that; it started just fine several times post-battery install.
      05-19-2019, 08:28 AM   #2
DVCNick
Another piece of data... reading 2.4 volts on the voltage terminals under the hood.
This was at 1.7V when I replaced the old battery, and over 12V just after battery replacement. I wonder if I have a severe battery drain somewhere; that wouldn't explain why everything powered up fine and then immediately cut off to zero yesterday though would it?
      05-19-2019, 09:12 AM   #3
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
check this thread out from farther down the page. the pop you heard may be the BST failing.
Stranded/no start. Any brilliant ideas? https://www.zpost.com/forums/showthread.php?t=1608309
      05-19-2019, 09:19 AM   #4
DVCNick
I will definitely check out that thread, thanks...
First, I have another interesting bit of info... reading the battery directly on the terminals, is 12.5V.
The ports up front under the hood, still 3V.
It appears the battery is not dead and something else is going on. There is no indication the car has any power at all: no interior lights, no windows indexing, nothing.
      05-19-2019, 10:22 AM   #5
The HACK
The HACK's Avatar
1821
The faint pop is the explosives going off in the battery terminal. v3.2mc has pointed you in the right direction. Once that terminal pops the entire vehicle will be without power as it is not connected to the battery.
      05-19-2019, 10:28 AM   #6
DVCNick
Another update... I just giggled the negative terminal cable and power came back on, or at least interior lights did. I don't have time to mess with it now but will try to start it this afternoon.
I thought the cable wasn't super tight but didn't think it was loose enough to cause any problems. Will update later today.
      05-19-2019, 07:00 PM   #7
DVCNick
So.. car started up fine after regaining power after moving the negative battery cable. So the connection must just be marginal.
I have a shim for the negative post on order and hopefully that will take care of it.
