      04-26-2018, 07:24 PM   #1
scrammer
scrammer's Avatar
Drives: 2017 M3 Ultimate
Large plug on the side of the rear of the oil pan
Guys,
I was in for an oil change at the dealer with the Z4M-R today and here is the exact comment on the receipt …
There is large plug on the side of the rear of the oil pan that looks to be leaking.
I asked the SA and he said the tech's were not familiar with the plug. It does not have its own item number as it is part of a complete oil pan, and there is no guide for service.
I have not noticed a single drop on the garage floor in the last year plus…
Any insight?
Cheers
Colin
Current ///M: 2017 M3 Ultimate
Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3
      04-27-2018, 01:29 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Yep. Large plug.
      04-27-2018, 09:59 AM   #3
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
i get oily residue on mine there occasionally,no dripping though.No clue where its coming from.the steering columm is directly above that, maybe some grease from that joint? not sure.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      05-12-2018, 11:53 AM   #4
scrammer
scrammer's Avatar
no worries then ...
thanks
      05-12-2018, 03:54 PM   #5
fdagen
Drives: 2006 Z4M Roadster
Replace it. It's a known issue.
      05-13-2018, 02:30 AM   #6
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
just drain the oil, pull the plug, and reinstall it with some liquid gasket.
StickMon636.00
      05-21-2018, 12:06 PM   #7
kav
Drives: Z4M
Revisiting this.
What sort of tool do I use to remove that plug?
