12-05-2017, 11:43 AM | #1 | |
salty cowboys fan
6233
Rep 3,435
ECS Rod Bearing Kit
Just picked up this rod bearing kit from ECS. Anybody use this before? I’ve been looking at many threads on this, and I believe it includes all the parts needed. Anything they missed that I should pick up?
https://www.ecstuning.com/b-assemble...1247835439kt2/ Quote:
she’s home! '22 M4 Comp xDrive
12-05-2017, 12:37 PM | #2 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Where is the single self-locking collar nut used?
Some people replace the oil pump sprocket nut with a new one, and use loctite, since there have been a few instances where those came loose. Gasket sealer. Loctite. Some like to replace the steering column bolt. 32306778609 Salty
yousefnjr6233.00 |
12-05-2017, 03:56 PM | #3 |
salty cowboys fan
6233
Rep 3,435
Good question. Looks like it comes off front stabilizer bar per realoem. Actually has 4 of them, and interestingly the now-discontinued Genuine BMW rod bearing kit (recreated here) comes with 4 of them. Maybe ECS thinks I’ll only lose 1? Pretty sure you can reuse those
12-08-2017, 04:35 PM | #4 |
Rep 109
I'm not how you'd be able to do the repair without removing some portion of the power steering pump so I'd say add 1qt ATF, and potentially a few of the banjo washers:
PS Banjo washers - (2) 32411093596 PS Banjo washers - (2) 32411093597 When I did mine I also removed the top bolt holding the oil cooler lines, I don't think this is absolutely necessary but it gives you a lot more room for very little effort and cost: Oil cooler line o-rings (2) - 17222245358 Good luck, post up results. |
