09-05-2017, 12:07 PM | #1 |
Rep 109
Coding cheat sheet?
My apologies in advance for this question as I'm sure it's been asked many times before.
I just acquired a 2007 Z4M and have been searching around for coding resources. My last BMW was an M235 and I successfully used E-SYS to code without issue but it seems like the documentation to do so on the E86 is pretty sparse. I've searched the forum and found several mentions of it being used successfully (adding blinker/lock functionality, etc) but I couldn't locate any resources on how it was being accomplished or what parameters are being changed. Is there a cheat sheet somewhere that I'm just not finding? Thanks in advance |
09-06-2017, 09:17 PM | #2 |
Rep 2,564
No cheat sheet, by I wrote up how to enable M track mode.
09-07-2017, 07:33 PM | #3 |
Rep 109
That actually helps a ton thank you.
Your post mentions NCS Expert which is the bit I was somehow missing, I spent a ton of time chasing down E-SYS info (because that's what I was familiar with) without realizing the E86 requires a completely different coding suite. Thanks! |
