09-03-2017, 02:03 PM | #1 |
Rep 1,130
Z4M oil: Castrol or original BMW? Quick reply appreciated
It's time for me to do the oil change on both Bimmers. I always buy what BMW recommends for oil which is the Castrol 10W60, but I now see they also offer Original BMW Oil 10W60 in a blue label reading "M twin Power". It specifically indicates that it's for M engines, turbo and non turbo, including the S54. It's a little cheaper per liter compared to the Castrol. Which one do you guys opt for?
2014 BMW X5 Sdrive35i F15
09-03-2017, 05:34 PM | #2 | |
704
Without seeing the specs of tests between the two, I really can't offer an opinion of merit. I can offer some opinion FWIW. First, I find the claim "good for all M engines" dubious at best (as a statement) as a turbo motor runs hotter oil temps, and spends its life at the lower end of the rev range. A high-revving motor like an S65 or S54 subjects oils to different stresses (and vice versa). In fact, for track applications, many of us are running RL (or other brands) of 15-50 due to what track stress does to 10-60. Horses for courses. Where's that leave you? Maybe go with the traditional stuff for now, when you have time to research the specs like shearing, viscosity breakdown, additives. |
09-03-2017, 07:03 PM | #3 |
Rep 1,130
Everything you said makes perfect sense. Thanks for your input. I'm glad I went with the traditional Castrol.
09-03-2017, 08:25 PM | #4 | |
704
And you've ready to run! |
09-04-2017, 08:23 PM | #5 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
OIL THREAD!!
Since the car has had Castrol 10w60 since new and my UOAs have been good, I kept using it when BMWs "official" oil supplier changed to Shell. For my E39 M5 as well.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
09-07-2017, 05:00 PM | #6 |
Rep 1,130
Ha good to know, thanks for the input guys. Now that you mention Shell, What do you guys opt for when it comes to gasoline? They did away with Shell here where I live so I don't get to pump V Power anymore. I would use Chevron as my 2nd choice but that's too far from my location. Any recommendations? I pump Exxon or Phillips 66 premium
09-07-2017, 05:54 PM | #7 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Dang, and I went out of the way to use the new Shell oil. Then again, I don't track my car and rarely get it above 5000 RPM, so for me it probably doesn't make much difference either way. So says the guy who needs a vanos work and new bearings. ;-)
Salty
09-09-2017, 12:28 PM | #8 | |
Rep 3,286
09-09-2017, 02:15 PM | #9 | |
Rep 2,866
09-12-2017, 05:16 PM | #10 |
1821
Rep 5,337
This is probably irrelevant to the discussion, but it just so happens I got my Blackstone UOA report back today, and I checked, the last time I changed the oil was almost exactly 1 year ago (well, before this last change 2 weeks ago to send in the used oil) using BMW's Shell Twin Turbo 10W60.
Not that it really matters, as the car had been running EXCLUSIVELY Castrol Edge 10W60 (or the BMW equivalent) for nearly 10 years before the Shell/BMW partnership necessitated the change (I didn't know they switched until GetBMWParts.com sent me the new oil change kit with the new TwinTurbo 10w60). On my mechanic's recommendation I'm switching to LubroMoly 10W60, which by all technical specifications is BMW LL-01 approved and compatible, and about $3.00 per liter cheaper...Plus my mechanic runs it in his S54 converted E36 C-Mod race car.
09-12-2017, 07:46 PM | #11 | |
704
Edit: Amazingly we have an oil and gas thread going here without anyone going all keyboard warrior. No one even banned. Gives one hope. |
09-12-2017, 09:32 PM | #12 |
1821
Rep 5,337
I reserve my keyboard warrior persona for track pissing matches.
Car has 49,7xx miles now on factory OE bearings. I used to attend far more events than I do now, and back then I would take FULL advantage of my "instructor's pay" so it's hard to equate days from 10 years ago to today. It's easier to count the numbers of 20 minute sessions, and that's approximately 300 on this car. Best guess is about 7,000-8,000 miles driven on track, 70% of that spent during the first 5 years. First week of ownership, as soon as the break in service was done at 1,000 miles, I took it to Auto Club Speedway. Other than ALWAYS do a warm-up lap until oil is past 180 degrees, I drive it like I stole it on track but usually keep it under 4,500RPM on the street unless I know I won't be caught (or in low gears on a canyon run). I don't think I do anything special. I don't even change oil more often, the first 4-5 years or so I change it once between the free oil change that BMW pays for, but more often than not the 1 year mark comes up before the 8,000 mile mark. The other thing is outside the track miles 90% of all the miles piled up were done at freeway cruising speeds in 6the gear, I.e. driving to and from the track.
09-12-2017, 11:40 PM | #13 | |
704
So, here's the thing, I'm betting you are very smooth with throttle inputs. No stabbing, stamping, jumping on throttle. Even when going WOT smooth application and squeezing the throttle. Probably even smooth off throttle. I'm wondering (with a wonderful sample size of one) if that driving style reduces stress on the bearings. Might be totally silly and might not account for motor physics/mechanics. That's no where in my area of knowledge. But I'm looking at those miles, the kind of miles, and the Blackstone report and trying to see what differs here. Bearings are a consumable item almost like brake pads for some, others, not so much. A friend of mine has over close to 100K on her Z3M, and she has a lot of track time in there as well. But, she's super smooth on her inputs too. On, off throttle, it's never abrupt. I know others who hit the track a fair bit and have burned through bearings like a hot knife through butter. Makes me wonder. In any case, keep doing whatever you're doing as it's keeping things nice and healthy! |
09-13-2017, 12:15 AM | #14 |
1821
Rep 5,337
No, I don't "hammer down" on the throttle, I "grew up" driving a 170hp 323Ci on track, that weighed more than my MZ4 Coupe. I drive "it" like a momentum car. I only hammer down when it's someone else's car, gas, and tires.
My friend who drives a 2002Ti would probably laugh at that statement.
09-13-2017, 02:00 AM | #15 | |
704
09-13-2017, 08:55 AM | #16 |
Rep 870
Finnegan, it sounds like these folks agree with your basic line of thought:
https://grassrootsmotorsports.com/fo.../125000/page1/ I have no idea how the first 30K of my roadster's life were driven. I had an initial oil analysis done, and everything looked fine. I do know how I drive, and it is all with proper warm-up, almost no short drive times, very easy launches, very smooth acceleration, no high revs, etc. My S54 now has almost the same exact miles as Hack, and my lead levels went very high in the last analysis. So, it could have been that the damage was all done to the bearings and only a micron of material was left for me to wear away before I took ownership of the car. Or? Just throwing out another anecdotal story. Salty
Finnegan704.00 |
09-14-2017, 09:26 AM | #17 |
Rep 1,107
So it seems we're left with:
Castrol 10W-60 Liqui-Moly 10W-60 Redline 15W-50 Do we want to further discuss which of these is better suited for particular use cases: - Daily driver that sees some short trips with some mid-range revving - Weekly driver that sees suitable warm up and high revving (7K rpm) spirited driving but no track use - Weekend car that occasionally sees some track use I'm the second use case. I went one oil change last year with the BMW twin turbo oil and when I switched back to the Castrol I thought I noticed that my 3,500 rpm Vanos noise was more noticeable (until car was hot, 30 minutes of driving). |
09-16-2017, 09:55 AM | #18 |
salty cowboys fan
6159
Rep 3,408
I've gone back and forth between TWS/Edge & "the turbo oil" and didn't notice and differences. I believe last time I changed I used Castro Edge Supercar, which appears to be the latest TWS marketing exercise
she’s home! '22 M4 Comp xDrive
StickMon636.00 |
09-18-2017, 01:51 PM | #19 |
636
Rep 3,124
Thanks. I didn't know there was a "Castrol Edge Supercar".
Could be a contender for my next change, especially if our filters are on Amazon.
09-18-2017, 06:33 PM | #20 | |||
Rep 1,130
09-18-2017, 06:59 PM | #21 |
636
Rep 3,124
I think so!
To be put in a class with Koenigseggeggeggeggegg!
09-18-2017, 07:37 PM | #22 |
Rep 1,923
Ravenol. That’s what I use
