11-21-2016, 04:15 PM | #1 |
636
Rep 3,124
The Juice is Loose!
My beloved blind-spot side-view mirror has the dreaded leak.
Radar-Mirrors says they can't fix it. I'm going to see if I can get it apart, clean out the juice, and get it back together. A search reveals that Vanne and others have done it for the rear-view.
12-02-2016, 05:52 PM | #3 |
636
Rep 3,124
It is a BMW part.
I get the feeling maybe they don't disassemble and re-juice LCDs. I bet for the rear view mirrors they replace the entire internal mirror assembly. In the case of this side view mirror, it is the entire assembly. I got it apart and cleaned up fairly easily, but not without cracking the outer plastic trim. I'm pretty sure I can glue the trim back together so the crack doesn't show. I haven't quite figured out how to put the glass back on the mirrored part and seal it so moisture doesn't get in. Got busy with work and Holiday stuff, so it's now in my 1/2 finished projects queue.
12-03-2016, 08:03 PM | #4 |
Rep 400
If you still have your original mirrors, you can adjust them to eliminate blind spots. I don't know if you do this already, just thought I would post. I've done this for the last couple of years and it works really well even in Coupes.
Here's the youtube video.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
StickMon636.00 |
12-06-2016, 05:44 PM | #5 |
636
Rep 3,124
Yep. Back to stock mirror for now and I always adjust them so I have to lean pretty far to see the side of the car.
I still miss the 5 panel wink mirror I had in the MR2.
12-19-2016, 01:56 PM | #10 |
636
Rep 3,124
For about a week mine seemed dark during the day, like they were dimming when they shouldn't be.
Then the bubble appeared one morning.
