      07-04-2016, 06:13 PM   #1
Sanderskog
Drives: 2006 Z4MR
Z4M Roadster with OEM BMW 359 wheels
I posted about this a couple weeks back (checking fitment) and thought I'd follow up now that they're installed.
I'm running a 245/35R19 in the front and a 285/30R19 in the rear.
Could not be happier with it. I've had the car about a month, it's stock minus the wheels/tires and Remus exhaust.
      07-04-2016, 09:02 PM   #2
deemo319
deemo319's Avatar
Drives: BMW
That's slammin!
      01-28-2020, 08:29 PM   #3
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
No rubbing at all? I thinking of getting same wheels
      08-31-2020, 11:40 PM   #4
RossBMWZseries
Bringing up an old thread here...
First off, That looks amazing!
How are you running 285痴 in the rear? No modification required? I understand the rear wheel is 10 inches wide. I have the same wheels (not installed yet) but my car is lowered on H&R springs. Was wondering if I can go with 285 without rubbing or gotta keep my 275痴
      09-01-2020, 07:34 AM   #5
AK72
AK72's Avatar
I have 285s on KW suspension, In order to get minimal rubbing you have to dial camber to - 2.5 and obviously adjust ride height, in my case rubbin happening at extreme compression as small line in bumper to panel connection area .
      09-02-2020, 01:22 AM   #6
RossBMWZseries
Minimal rubbing? In other words, 285痴 will rub regardless of any modification being done
I guess I値l stick to 275痴
2014 BMW X5 Sdrive35i F15
2011 BMW 328i E92 LCI
2006 BMW Z4 M Roadster E85
2013 BMW S1000RR K46 R.I.P.
      09-02-2020, 05:59 AM   #7
AK72
AK72's Avatar
275s best choice in case if you don't want to modify settings in you suspension
      09-02-2020, 12:51 PM   #8
RossBMWZseries
Awesome, thanks for clearing this up for me man!
      09-06-2020, 12:32 PM   #9
B328iC
Drives: 97 328iC, 2003 Z4
Any spacers needed?
      09-06-2020, 01:50 PM   #10
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
Minimal rubbing? In other words, 285’s will rub regardless of any modification being done
I guess I’ll stick to 275’s
Please let me know how the 275's work on the 359s, regarding rubbing, etc. I run a set of snows on 359s for my M4, with the plan being to move them eventually to the Z4M, with summers, of course. The Z4 is also lowered with H&R springs.
      09-08-2020, 10:14 PM   #11
RossBMWZseries
Yea for sure man. As soon as my Z4 is out of the shop, I値l put them on to check fitment and let you know
      09-09-2020, 01:22 AM   #12
rsuhandy
rsuhandy's Avatar
Drives: F06 M6;E92 M3;E85 Z4M; 958 SEH
I知 running 359s with 245/35/19 Front and 265/35/19 Rear. I have minor rubbing on the fender liner at 80% to full lock. Anyone else getting some minor rub?
      09-29-2020, 10:15 PM   #13
AK72
AK72's Avatar
not minor at all with 245 35 19 happens at the track, no issues during street
[IMG]undefined[/IMG]
Powered by
      10-27-2020, 10:41 PM   #14
rsuhandy
rsuhandy's Avatar
I ended up switching to 235/35/19 for this exact reason. No more fender liner rubbing. Haven稚 done any track time yet, but at least no more rubbing during aggressive street driving.
      02-26-2021, 07:15 PM   #15
thielepr
Drives: 06 Z4M, 11 M3, 17 230i
Do we have more recent pictures? Anyone else using 359M wheels?
      02-27-2021, 07:49 PM   #16
RossBMWZseries
I知 away from home currently but when I do get back, I値l install them in the M and post pictures. Also, I値l be removing my H&R springs to install H&R coilovers
      02-28-2021, 07:04 AM   #17
maupineda
Drives: E86 Z4MC
I’m away from home currently but when I do get back, I’ll install them in the M and post pictures. Also, I’ll be removing my H&R springs to install H&R coilovers
Beware H&R coils ride pretty bad if your roads are not smooth. It is extremely crashy and they are too low even their highest setting. Also suspension travel on the front is very compromised.
You can make them fine but it takes effort and mix and match with other vendors parts.
Edit... I edited my post above, changes shown in bold black
      02-28-2021, 08:17 PM   #18
RossBMWZseries
Originally Posted by maupineda View Post
Beware H&R coils ride pretty bad if your roads are not smooth. It is extremely crashy and the are low even their highest setting. Also suspension travel on the front is very compromised.
Well, damn it lol. Thanks for the heads up. I bought them along with camber plates. I値l admit that wheels/suspension/stance is not my thing, so I値l let the shop work their tricks and hope it all works out. I値l check back with you guys
      02-28-2021, 08:59 PM   #19
maupineda
Drives: E86 Z4MC
Well, damn it lol. Thanks for the heads up. I bought them along with camber plates. I’ll admit that wheels/suspension/stance is not my thing, so I’ll let the shop work their tricks and hope it all works out. I’ll check back with you guys
Looking forward to your feedback.
In my case I modified my setup so much that all that is left of the H&R coilover kit are the front struts and rear spring height adjusters. Everything else was switched to other brand name components to help me meet my spec (flat ride)
Front linear swift springs @ 250 lb/in
Rear linear TCKline springs @ 600 lb/in
Spring perches for the front struts to accept the 2.5in swift springs
Rear B8 shocks from Non-M Z4
Modified internal bump stops in the H&R struts
with my setup I cannot go any lower than stock, in fact I am 3mm higher at the front; I set the rears to be 10mm raked (lower) vs the front (BMW spec)
These has made the car ride very firmly, but more compliant than the coils I had when I got the car and the H&Rs. I have never driven a stock Z4M, so I don't have that reference, but now my car does not skip on bumps and is very planted.
