05-03-2012, 05:20 PM | #23 |
#dubspec
6337
Rep 5,201
OP, what is the milage on your car? just curious if these bolts break within a certain milage bracket...
05-03-2012, 05:57 PM | #24 | |
Rep 1,097
Remember if you do this fix, you need to purchase the large bolts that hold the bottom reinforcement plate as they are one time use. |
05-03-2012, 06:16 PM | #25 | |
1821
Rep 5,337
05-03-2012, 06:35 PM | #26 | |
Rep 11,667
Loctite 2620 is good to 650 deg F
05-03-2012, 06:50 PM | #27 | |
Rep 11,667
my only issue for this application is that the load bearing surface area of the Nordlocks is less than the OE washer. That's why I won't be using them. IMO this whole bolt issue is getting over thought. Why is it that the E46 M3 doesn't have the same problem? I think it's QA assembley line issue.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 05-04-2012 at 05:12 AM.. |
05-03-2012, 08:27 PM | #28 |
Rep 1,107
05-03-2012, 09:12 PM | #29 | |
Rep 421
Screws are not the problem. . . . . Last edited by Ron Stygar; 05-03-2012 at 09:21 PM.. |
05-03-2012, 10:54 PM | #30 |
Rep 251
Good evening my friends.
So the car is is out of warranty... The car has less than 33k. and since I hate the way 1st and 2nd gear feels even with the neo... trans mounts..... I went with the 75d motor mounts. For $150, the worst that can happen is that you'll see them here for sale in a couple of weeks.... but if those mounts fix the notchy gears.... then I'll stick with them. Since this is my dd car, I ordered the parts right away and they should be here tomorrow. This stupid problem pretty much criples the car... I'm glad they didn't brake far away from home. Anyhow, thank you all for your advice(s). |
05-03-2012, 11:34 PM | #31 |
Rep 1,097
05-04-2012, 11:49 AM | #32 | |
Rep 1,107
Also something that comes to mind is that the TSB is for the failure/loosening of the passenger side bolts, not the driver's side bolts. Yet, folks are replacing the driver's side as well. Have people had their driver's side bolts loosen on them? |
05-04-2012, 02:00 PM | #33 |
Rep 1,107
For the life of me I can only feel one of the front bolts. Not a lot of room there to get my arm in, and I'm a mountain biking, tennis playing skinny assed boy!
05-04-2012, 02:44 PM | #34 |
Rep 421
05-04-2012, 02:45 PM | #35 |
Rep 421
05-04-2012, 03:03 PM | #36 |
Rep 251
Hello people, what's the best spot to raise the engine so that I can get the motor mounts and bracket bolts replaced.... I'll find out exactly what's broken tonight..... just need to lift the engine a bit to get started.
05-04-2012, 03:24 PM | #37 |
704
IDK about the lift point.
When you get the new motor mounts in please report the NVH and impact, if any, on shifting quality and etc. I'll add it to the sticky. Those are poly mounts, right? |
05-04-2012, 03:36 PM | #38 |
Rep 251
Yes sir... I also have the neo trans mounts.... I'll let you know once everything is back together.
05-05-2012, 08:29 AM | #39 |
Rep 1,107
05-05-2012, 09:13 AM | #40 |
Rep 11,667
If you pull the wheels & liners you can get to them.
05-05-2012, 08:30 PM | #41 |
Rep 251
Quick update:
If anyone bet money on the bracket bolts.... was right. The bottom right is missing and the bottom left broke and half of it still inside The picture of the first cat is what creates the vibration as you can see why. |
05-06-2012, 12:21 AM | #42 |
Rep 2,867
Why is this issue only happens on e85M/e86M and nothing else? No reports (not that I'm aware of) on regular e85/e86 or e46M
05-06-2012, 01:20 AM | #43 |
Rep 1,663
SI B 22 01 09
"Prolonged heat exposure to the right side engine mount bracket, during the engine assembly process, may cause the bolts, which hold the engine bracket to the block, to lose the specified tightening torque." I pre-emptively upgraded my bolts to the 10.9 bmw motorsport bolts + nord-lock washers with a high quality anti-seize. Edit: Part numbers in this thread BMW Motorsport Engine Mount Bolts.
05-06-2012, 11:37 AM | #44 |
Rep 2,867
Right...that is the "official" words from BMW. Since the M version runs through the same assembly line, why is it that the other Zs are not affected?
