10-24-2012, 05:42 PM | #89 |
Rep 648
I emailed Rogue and was told this project got put on the backburner. I guess I'll be going OEM when I install my coilovers
Le Mans Blue '09 BMW M3 Sedan - Current Polar Silver '04 Porsche GT3 - Gone Persian Blue '08 Lotus Exige S240 - Gone Space Gray/Imola '08 BMW M Coupe - Gone |
10-24-2012, 09:13 PM | #90 |
Rep 11,667
^ I figured as much.
That's too bad, this something that is definitely needed for our cars.
10-26-2012, 02:01 AM | #91 |
Rep 1,546
why not go powerflex?
10-26-2012, 03:23 AM | #92 |
Rep 69
10-26-2012, 04:53 AM | #93 |
Rep 11,667
^ correct.
That's why this was started. Nobody makes the offset bush
11-19-2012, 07:02 AM | #95 |
Rep 2,138
Drives: Me
You could use the center bushing but this would change your caster... It I think it would increase caster. What it would do to the scub angle I am not sure.
On person on this board has done this....I just don't remember and I am too lazy to do a search this morning. |
11-19-2012, 07:52 AM | #96 |
Stupid as shit
26
Rep 367
Powerflex should have a solution out by now. Last time I spoke to them (september) they told me that there should be a Z4M version (Z4 non-M is different) out by the end of the October. I installed the rears back in August, so I'm waiting for the fronts now.
11-19-2012, 08:05 AM | #97 |
Rep 11,667
^that would be great
11-19-2012, 08:19 AM | #98 |
Rep 503
Drives: Z4 M Coupe
I'd buy a set as well if they made them. I'll shoot them an email to ask where they are with this.
11-19-2012, 11:48 AM | #99 |
707
Rep 7,850
11-19-2012, 12:38 PM | #100 |
Rep 5,329
I'm in if these are available soon :-)
11-19-2012, 01:29 PM | #101 |
Rep 503
Drives: Z4 M Coupe
This is what they replied...
Hi Giannis Thank you for your enquiry These parts are not quite finished yet, we are hoping to release them in the new year so please keep checking our website for updates Kind Regards Lauren Chambers ~ Sales Assistant
11-19-2012, 03:01 PM | #102 |
Stupid as shit
26
Rep 367
Just wanted to post basicly the same reply
11-20-2012, 12:39 AM | #103 |
Rep 1,546
Dang, I totally missed that, my bad...
11-22-2012, 11:13 AM | #104 | |
Rep 11,667
If they have them before next spring I will be happy .
12-11-2012, 01:16 AM | #105 |
Rep 175
There just arent enough of these cars for anyone to actually make a profit. I was going to have some built for all of us to enjoy with a higher durometer rating and it was going to cost about $8,000 just to have the mold made. Its not like I'd be selling thousands a year so it just isn't worth it.
12-26-2012, 01:42 AM | #106 |
Rep 69
Following the posts of user Shipkiller in the thread "Z4M left front lower control arm", I remembered that I have in the garage a used (but still re-useable) Z4M front control arm. Unfortunately, the control arm bushing (CAB) is installed and I didn't want to ruin it by removing the CAB from the control arm finger (pintal). The control arm finger has a hexagonal shape, with two particularities: - rounded corners; - one extended diagonal (marked with blue color in the picture). Therefore, as the above picture shows, I could only measure the distance "a" using a caliper. Note that a caliper it's not so precise as a micrometer, the position was not optimal, and the temperature was around 0 deg. C. Consequently this measurement should be only considered as "indicative", until a precise one will be taken. From a= 21mm one can calculate the theoretical circle that the hexagon inscribes in: radius= 12.125mm, diameter= 24.25mm. Note that these values are calculated starting from an imprecise measurement. Unfortunately, I had no way to take reasonable measurements of the extended diagonal ("b" in the picture above). As Shipkiller suggested, since there are no aftermarket CABs for Z4M, a possible solution may be to use offset CABs for E36 M3. But those have a round hole, instead of a hex one. If the Z4M control arm finger is large enough, then maybe it can be machined down to fit the E36 round hole CABs. Of, if the finger is too smal, then maybe a sleeve can be inserted over the Z4M control arm finger. |
12-26-2012, 03:07 AM | #107 | |
Rep 5,329
12-26-2012, 08:16 AM | #108 |
Rep 11,667
Sounds like Poweflex is still our only hope.
12-26-2012, 08:59 AM | #109 |
Rep 2,138
Drives: Me
RobertRO,
Thanks for the information. The measurement does not really have to be that precise. Your 21mm measurement is good enough to make some educated guesses on fitment, once I (we) get some more data. In fact you could have taken measurements of the other axis and those might have been good enough also.. If anyone is still waiting for a company to design, develop and test a new set of FCAB’s you are on drugs and need a piss test. I do not believe this will ever happen since there is such a small number of cars that would actually buy a set. No profit in it. . |
12-26-2012, 10:20 AM | #110 |
Rep 11,667
....piss test or not, still hopefully
