09-11-2015, 11:10 AM | #1 |
Rep 269
Engine Mount Bolts
Does anyone have a guide, tutorial or video how to check/replace the engine mount bolts? I understand that it is possible to get at the passenger side ones without too much hassle.
I'd like to see a picture of exactly how/where they are. |
09-11-2015, 11:09 PM | #2 |
Rep 2,665
Some information, then more links to go to more information -
http://www.zpost.com/forums/showthread.php?t=635649
09-12-2015, 08:43 AM | #3 |
Rep 400
Here are some pics from the driver's side. You need to remove the intake manifold to get to these.
Closer up: You can see the front lower passenger side from the wheel well. It is supposed to be where the circle is. To get to the others you need to remove the reinforcement plate and vanos accumulator.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500 |
09-12-2015, 09:57 AM | #4 |
Rep 1,443
I've seen recommendations on here to use 10.9 rated bolts instead of 8.8s. Are the 10.9s an upgraded/revised part that uses the same numbers? 07119905724 (6), 07119905533 (2)
09-12-2015, 10:22 AM | #5 |
Rep 400
The 10.9 grade bolts are a different part number. The link in the second post has the part number for the upgraded bolts. I don't know if they make the "motorsports" bolts anymore. However, BMW still uses those part numbers for the 10.9 grade bolt. They can be found in a variety of applications.
That being said, I'm not 100% convinced that the 10.9 grade bolts are really needed. I think that if properly torqued down the 8.8 will work also. After all, you don't hear a bunch of e46 M3 stories of motor mount bracket bolt failures. If I had gone with 8.8 bolts, I still would have gotten the nordlock washers. I currently have the 10.9 bolts and the smaller zinc coated nordlock washers installed.
09-14-2015, 07:55 PM | #7 |
Rep 269
Thanks for the pictures guys. I did the best I could to feel/look around to see if they were ok. Seems to be good.
What are the symptoms/worst case if these come out? |
09-15-2015, 02:45 PM | #8 |
636
Rep 3,124
Clunking when you get on/off the gas.
Also, the right side stock rubber mount has a limited life span. Mine was badly cracked when I replaced it with Vibra-Technics at about 88k Miles. Hard to see the crack because it's under the little heat shield.
09-15-2015, 03:42 PM | #9 |
Rep 99
I did not need to remove the intake manifold to get to all of the bolts.
Depending on how flexible you are, how small your arms are, and what types of tools/connectors/etc you have access to, you can get to all of the bolts from the top and bottom of the car.
09-15-2015, 03:48 PM | #10 |
Rep 2,782
04-11-2017, 04:40 PM | #13 |
Rep 1,991
That would vary a lot depending on how long they take which will depend on their experience and familiarity with the job. Shop rates vary as lot as well. I had mine done by a fellow board member a few years ago. It took a couple of hours. We only had to remove the airbox and reinforcement plate to get to the bolts on the drivers side. I went with the 10.9 bolts he had on hand. Several of my bolts were loose, but all were present.
04-16-2017, 07:20 AM | #14 |
Rep 47
04-16-2017, 03:24 PM | #15 |
Rep 114
You could do what I had my tech do. While performing a suspension transplant on my M he replaced the six bolts that were easy to reach. All the original bolts were still tight at 34k miles so I don't anticipate any issues in the future with the two remaining bolts. That is the inexpensive method but if any of the original bolts were found to have been loose I might have had all of them done.
11-28-2018, 07:07 AM | #16 |
Rep 382
Actual current McMaster part numbers:
You'll have to get them from McMaster, but probably more of them than you want, but hey, you can never have too much left over hardware. You need 6 M8x25 and 2 M8x35 (where the Vanos oil accumulator bracket is attached). Yea, you're going to get a heck of a lot more of them than you need, but they're dirt cheap. M8x25 = 90854A167 (Sack of 25) M8x35 = 90854A172 (Sack of 25) Nord-Locks = 91812A430 (5 per pack, so get 2 packs.) |
wdb4732.00 |
