07-13-2012, 04:51 AM | #45 | |
Rep 5,329
right.... im going to let tom deal with this comment.... tom.... say it.. please. before i do.
07-13-2012, 09:20 AM | #46 |
instagram 997turbotom
286
Rep 7,377
Whats there to say? He already has a stage 1 supercharger kit installed, just wants to be the first to dual-charge this engine
07-13-2012, 04:40 PM | #50 | ||
Rep 500
John made more progress today. He found out that one of the O2 sensors was not heating up. Certain codes cause the ProEFI to not control the engine correctly and factory O2 sensor codes are a biggie. John is installing another factory O2 sensor today and it will be back on the dyno. Chris. |
07-18-2012, 12:11 PM | #52 |
Rep 500
John removed the last o2 code, was driving the Z4M and making dyno pulls however the car would cut the throttle on each pull. He found a possible glitch in the harness or wiring. It appears the DSC is not receiving the proper signal so John and Jason are going to work on the pin-out today to determine how to quickly resolve the issue.
Chris. |
07-18-2012, 04:42 PM | #53 |
Rep 5,329
hmm look forward to seeing more updates, keep at it chris your so close its painful!!
07-19-2012, 03:01 PM | #54 | |
Rep 500
Chris. |
08-06-2012, 01:39 PM | #57 |
Rep 500
08-06-2012, 07:19 PM | #58 |
Rep 4,128
Drives: M235i & G30 540i
LOL not surprised the Z4 gets put to the back as usual
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
08-06-2012, 11:28 PM | #59 |
286
Rep 7,377
we're used to it.
Even ESS, who say they sold about 30-40 kits (IIRC), don't feel like making the VT2-550 or the VT3 upgrade available in the USA ((
08-14-2012, 10:33 AM | #60 |
Rep 500
John has been working with ProEFI on this. We are now putting in a signal conditioner on the crank sensor wire. Apparently the ProEFI ECU might be changing the resistance on this wire causing the DME to cut the power on the car.
Chris. |
08-29-2012, 11:30 AM | #62 |
Rep 5,329
ok update for you all.... unfortunately it seems pro-efi/ lutz all of them cant get the ecu to work with our setup :-( im hoping they can workout where the problem is so we can move on with these turbo builds...... i was pretty excited by all of this...
HPF just to let you know, we dont care if the news is good or bad but keep us updated, you have lots of potential customers here, hell we dont mind if its all bad news, its just great to see the effort to make it work.
08-29-2012, 03:51 PM | #66 |
Rep 5,329
bit of both........
off for a week and my timezone helps.......... :-)
