      07-13-2012, 04:51 AM   #45
Beedub
Originally Posted by Z4-VILLA View Post
Without opening the motor?
Also ball park prices might help people like myself get a headstart if needed to begin saving
LOL
right.... im going to let tom deal with this comment....
tom.... say it.. please. before i do.
      07-13-2012, 09:20 AM   #46
ZStig
instagram 997turbotom
286
Drives: Interlagos Z4MR
Originally Posted by Beedub View Post
LOL
Whats there to say? He already has a stage 1 supercharger kit installed, just wants to be the first to dual-charge this engine
      07-13-2012, 01:32 PM   #47
txz4
txz4's Avatar
60
Drives: 2006 M coupe
just to clarify, Villa wants the prices with jet hot coating on all parts. Wiring included.
      07-13-2012, 01:53 PM   #48
Z4-VILLA
Afghanistan
114
Drives: Z4M Hardtop Roadster
EPIC
      07-13-2012, 01:54 PM   #49
Z4-VILLA
Afghanistan
114
but yeah I would jet hot the heck out othe manifold, dowm pipes, hot side of turbo.....and I think thats about all I can get away with. :-)
      07-13-2012, 04:40 PM   #50
HPF Chris
Drives: 2006 330i & 530i
The turbo manifolds are already coated. No need to coat the downpipe as it is behind the turbo which is under the car.
I will PM both of you a link to the prices on our site. We can't post up prices on these threads (forum rules)
John made more progress today. He found out that one of the O2 sensors was not heating up. Certain codes cause the ProEFI to not control the engine correctly and factory O2 sensor codes are a biggie. John is installing another factory O2 sensor today and it will be back on the dyno.
Chris.
      07-13-2012, 11:12 PM   #51
Z4-VILLA
Afghanistan
114
excellent
      07-18-2012, 12:11 PM   #52
HPF Chris
John removed the last o2 code, was driving the Z4M and making dyno pulls however the car would cut the throttle on each pull. He found a possible glitch in the harness or wiring. It appears the DSC is not receiving the proper signal so John and Jason are going to work on the pin-out today to determine how to quickly resolve the issue.
Chris.
      07-18-2012, 04:42 PM   #53
Beedub
hmm look forward to seeing more updates, keep at it chris your so close its painful!!
      07-19-2012, 03:01 PM   #54
HPF Chris
Thanks. John traced all the wires and they trace through correctly. We are now checking ot see if it's in the CAN bus. ProEFI is providing lots of help. It's the first Z4M they've done so there will be a learning curve.
Chris.
      08-03-2012, 03:11 AM   #55
Z4-VILLA
Afghanistan
114
updates?
      08-06-2012, 02:59 AM   #56
tikamak
Lebanon
58
This project is taking a good amount of time. what's wrong?
      08-06-2012, 01:39 PM   #57
HPF Chris
Sorry guys. Our shop has been buried with other cars. John will be back on it starting this afternoon. I'll get some footage up shortly. WE ARE BACK ON IT!!!
Chris.
      08-06-2012, 07:19 PM   #58
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
LOL not surprised the Z4 gets put to the back as usual
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      08-06-2012, 11:28 PM   #59
ZStig
286
we're used to it.
Even ESS, who say they sold about 30-40 kits (IIRC), don't feel like making the VT2-550 or the VT3 upgrade available in the USA ((
      08-14-2012, 10:33 AM   #60
HPF Chris
John has been working with ProEFI on this. We are now putting in a signal conditioner on the crank sensor wire. Apparently the ProEFI ECU might be changing the resistance on this wire causing the DME to cut the power on the car.
Chris.
      08-15-2012, 01:52 AM   #61
Z4-VILLA
Afghanistan
114
mature tuner right here....this guy actually writes updates not like the other clowns
      08-29-2012, 11:30 AM   #62
Beedub
ok update for you all.... unfortunately it seems pro-efi/ lutz all of them cant get the ecu to work with our setup :-( im hoping they can workout where the problem is so we can move on with these turbo builds...... i was pretty excited by all of this...
HPF just to let you know, we dont care if the news is good or bad but keep us updated, you have lots of potential customers here, hell we dont mind if its all bad news, its just great to see the effort to make it work.
      08-29-2012, 11:34 AM   #63
Z4-VILLA
Afghanistan
114
Beedub you must be off today...
      08-29-2012, 11:36 AM   #64
ZStig
286
or it could be his +8 hr timezone
      08-29-2012, 11:40 AM   #65
Z4-VILLA
Afghanistan
114
Tom you F$%king troll you....still butt hurt about yesterday I see.
      08-29-2012, 03:51 PM   #66
Beedub
bit of both........
off for a week and my timezone helps.......... :-)
