      08-11-2012, 12:32 AM   #1
StickMon
StickMon's Avatar
Drives: 2006 MR
Wire Harness Over Head Cover
Anyone know what the wire harness is for that sits over the top of the coil harness on the S54? It winds through a plastic housing held down by 2 plastic clips and 2 eyelets that go over the studs for the ///M cover.
I just did my first solo valve adjustment. When I peeled back this harness, I noticed a grey wire and a white wire that come in the lower square grommet and go immediately to what looks like a cylindrical connector. Some Bubba that had previously worked on the car had crushed these 2 wires between the head cover and the rear eyelet to the point that the conductors were visible. Fixed it with some tape and plastic tubing, but I can't help but wonder what was quite probably shorting out.
      08-11-2012, 11:19 AM   #2
marinb
marinb's Avatar
Drives: 2017 911 GTS
It's for the four O2 sensors and the EGT sensor.
      08-11-2012, 10:32 PM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Thanks.
Time will tell if this was the source of my intermittent "both banks simultaneously lean" codes.
      08-25-2012, 06:47 AM   #4
BruceJ
6 of Diamonds (ret)
BruceJ's Avatar
Drives: 2011 E93 335is
Originally Posted by StickMon
Thanks.
Id say you found that problem. Be surprised if it was anything else.
2007 Z4Si(gone)
Couple E30 Verts (DD)
2003 330i
2011 E93 335is - current fav
      08-25-2012, 07:05 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^whs
Most certainly the problem
Nice work on the find.
We found a similar thing on a friends car when doing the shims.
These are some of the many reasons I find doing your own work to be so satisfying.
