      03-10-2010, 05:36 PM   #45
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
does anyone knows a repeater for a 125 KHz AM signal? receive and transmit the am signal?
      03-10-2010, 09:12 PM   #46
Diokaef
Engineer
Diokaef's Avatar
EWS Immobilizer
http://www.meeknet.co.uk/E38/E38_Imm...tem%20EWS3.pdf
https://www.bmwmc.net/catalog/61%200...mmobiliser.pdf
      03-11-2010, 01:53 AM   #47
Diokaef
Engineer
Diokaef's Avatar
more testing on this.
      03-11-2010, 01:59 AM   #48
Diokaef
Engineer
Diokaef's Avatar
No need for the key anymore, just 1 button to press, 8 digits security code with 5 attempts or it shut off for 15min, does not require cutting any wires
      03-11-2010, 02:05 AM   #49
Diokaef
Engineer
Diokaef's Avatar
Keypad
2 color options for the keypad and 2 for LED and 2 designs.
      03-11-2010, 02:31 AM   #50
Diokaef
Engineer
Diokaef's Avatar
How is done:
1) Remove SW lock and iGN switch+Ring antenna for ews and module.
2) connect relays between harness and Ign Switch.
3) turn key to Ign 1
4) Close everything in a steel or aluminum box with a lock.
5) hide the box under the dash
6) Use keypad to enter code and activate Ign.
7)press button to turn on the car
8)press button to turn off
9)enter lock code on key pad to lock deactivate ign (so no one can just press the button and take off with your car.
Done
      03-11-2010, 02:34 AM   #51
Diokaef
Engineer
Diokaef's Avatar
If for some reason one day this stop working you just have to remove from the box and connect the harness back on ign switch and mount everything back on the car.
that way you will not have warranty problems.
      03-12-2010, 07:57 PM   #52
crfine88
crfine88's Avatar
442
Drives: E86M
you have put a tone of research into this.
thanks for the contribution.
      03-13-2010, 10:24 AM   #53
Diokaef
Engineer
Diokaef's Avatar
Thank's I can wait to put on my car but I want make sure that I cover all possible downsides of it first.
      04-05-2010, 07:23 PM   #54
Diokaef
Engineer
Diokaef's Avatar
      04-16-2010, 10:17 PM   #55
Diokaef
Engineer
Diokaef's Avatar
Just installed on my friends car today, it works, did not need to bypass the Immobilizer, Me and my friend made it with microprocessors and a few relays and ...... but that is not like a DIY type of devise, I install a immobilizer able/disable with the system so it cannot be hot wired, it uses the car immobilizer to work. also was not necessary cut any wires, totally plug and play. it uses a keypad with a pin# to activate the immobilizer.
Sorry guys but to be a safe module (push start/stop) this was way more complicate then I wanted it to be, and impossible to DIY without a lot of electronics experience. ( I'm working on patent this and sell in the sponsor classifieds)
I do have the DIY for push start/stop (only) made with relays if you guys want, but no way to use it without have to insert and leave key on ignition for immobilizer purposes. (No need to turn the IGN ON with key)
let me know.
      06-14-2010, 02:56 PM   #56
Diokaef
Engineer
Diokaef's Avatar
[u2b]<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/XhyHALJ-T6M&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/XhyHALJ-T6M&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>[/u2b]
IT is done.
For BMW I was able to work with EWS III IMO and plug and play also comfort access no need for keys even to open the door.
I will post a video of it on My Z4M in a few weeks after it come out of the shop.
Also I used a Nissan button and was able to reproduce all the functions of that button.
I did also a custom button with the M logo on it.
      06-14-2010, 03:03 PM   #57
Diokaef
Engineer
Diokaef's Avatar
No need to do this as stated on #51
5)
6)
7)
8)
9)
Comes with starter kill, Ign kill, and fuel pump kill(need extra connections for fuel kill)
works with the Immobilizer and not bypass
      07-07-2010, 03:53 PM   #58
Diokaef
Engineer
Diokaef's Avatar
Here e90 button To whom want to use it.
http://sites.google.com/a/netmgr.co....p-start-button
      07-21-2010, 11:38 PM   #59
Diokaef
Engineer
Diokaef's Avatar
      09-12-2010, 08:33 PM   #60
Diokaef
Engineer
Diokaef's Avatar
ON the Z
Just finished installing this today.
No keys needed, not even for doors.
[u2b]<object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/kOWgprraujo&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_ US&feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/kOWgprraujo&color1=0xb1b1b1&color2=0xd0d0d0&hl=en_ US&feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="385"></embed></object>[/u2b]
see here for more details http://www.zpost.com/forums/showthread.php?t=430948
      02-05-2011, 03:49 AM   #61
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
holy shit....nice.....how much?
      02-05-2011, 03:54 PM   #62
Diokaef
Engineer
Diokaef's Avatar
I was offering for less but with al the parts cost going up it would be around at $840
      02-17-2011, 12:24 PM   #63
porshah
porshah's Avatar
197
Drives: M4, R8, Huracan - All topdown
Impressive! Just read the entire thread. Lots of work, but looks amazing. Great job!
