07-19-2012, 12:58 AM | #23 |
///Multiple
2993
Rep 4,243
I looked up the VIN in the Z4M production data spreadsheet and it shows the Interior Color as "VL WALKNAPPA/SCHWARZ (LTSW)". It appears that this means that this car has the Extended Nappa Leather interior with the Carbon Leather trim. Is this correct?
One of the German worlds for "extended" is "verlängerte", so where the standard leather is shown as "Lederaus. Walknappa/Schwarz" meaning "Leather, Nappa/Black", "VL Walknappa/Schwarz" is apparently the abbreviation for "Verlängerte Lederaus. Walknappa/Schwarz" meaning "Extended Leather, Nappa/Black".
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 07-19-2012 at 07:58 AM.. |
07-19-2012, 08:33 AM | #25 | |
Rep 1,992
07-19-2012, 09:02 AM | #26 | |
Rep 421
(LT)SW extended (LS)SW is not |
07-19-2012, 10:49 AM | #27 |
Bad Lieutenant
233
Rep 3,517
SD: It looks sweet! I would examine the interior very carefully. The photo with the "SOS" button shows the clear cover that has yellowed due to UV exposure. Otherwise, it looks to be in good condition, seats have just a bit of shine for 31k, steering wheel is still matte and door sills don't have much abuse.
07-20-2012, 02:17 AM | #28 |
///Multiple
2993
Rep 4,243
Short update:
I bought the car. Interlagos Blue with Black Nappa Leather and Carbon Leather Trim. Also with Premium Package, Extended Leather, Nav, Heated Seats, and, unexpectedly for both for me and the sales guy, a factory iPod adapter. The interior is almost perfect. No wear on the driver's seat bolster at all. The steering wheel looks brand new with no wear at all. The stitching is even clean. On the ground the car looks like a creampuff, a typical low mileage car with only a little over 6,000 annual miles. On the hoist, however, the car apparently had a different personality. First off, it has H&R springs all around. The left rear plastic fender liner is trashed near the fender edge, both fender wells have extensive rubbing on the inside side (towards the center), and the left fender lip has been rubbed excessively, with rubber melted onto the fender edge. The owner apparently had huge wheels and tires on the rear and the tires rubbed excessively to the point of causing damage. On the right rear corner, there is a fist-sized dent in the muffler, there's some heat-shield-covered sheet metal that is deformed, and the exhaut outlet in the right rear valence looks like maybe the exhaust tip contacted it and cracked it and it's been trimmed away. The front bumper cover has been resprayed with obvious signs of paint blending and some slightly mismatched touch-up paint and there's some broken plastic under and behind the front valence. It's possible that it was a weekend track car. Mechanically the car appears sound but there is a slight leak on the right side of the diff which the mechanic said is a stub axle seal. Costly to replace because of the labor but parts are inexpensive. More tomorrow because I'm exhausted and I have to drive from San Louis Obispo, where I finally arrived at 10:00 PM tonight, and drive back to San Diego tomorrow. Lots of pictures to come in the next few days.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 12-11-2019 at 09:06 PM.. |
07-20-2012, 06:32 AM | #29 | |
Rep 1,992
07-20-2012, 06:52 AM | #30 | |
Rep 1,002
Anyhow, Congratulation on the car. I hope it wasn't driven too hard if it was a weekend trackcar. Check the Service Record and see if Inspection 1 was performed (as it should). It would strongly recommend flushing all the fluids (again especially if it was track/driven hard). I just flushed all my 2007 MCoupe (driven gently but spiritly) and so glad that i did since the fluid look rather dark (i know dark color fluids do not mean they don't meet specs) |
07-20-2012, 07:58 AM | #31 | |
Rep 452
07-20-2012, 08:25 AM | #32 | |
Bad Lieutenant
233
Rep 3,517
PM Finnegan, I believe he had a seal replaced. It does sound like a track car, and the seats and original wheel were probably not utilized much so they were popped back in for the sale. This is good, since those seats are not cheap to repair or replace, neither is the wheel. Check the service records for the recent valve adjustment, if it's a track car, I expect them to be check/adjusted yearly or at 15k.
07-20-2012, 09:42 AM | #33 | |
Rep 1,992
07-20-2012, 10:33 AM | #35 |
Rep 1,066
Drives: 2015 X5 50i M Sport
M or non-M?
2019 Cayenne Turbo
Gone but not forgotten: 2006 2.0T A4 Avant, 2007 Z4 Roadster 3.0si, 2006 M Roadster, 2013 550i M Sport, 2015 Cayman S, 2015 X5 50i M Sport |
07-20-2012, 10:41 AM | #36 |
Rep 139
Drives: '12 E92 M3 / '20 X5 M50i
Congrats on the car. The extended leather is really nice, I have it on my '04 3.0. Seems unlikely that someone would track one loaded with nav and ex leather.
I'm looking for a M, and would like to find one spec'd like yours.They had it listed for $30K, did you get a good deal off that? If anyone runs across a for sale late '06 or '07 MR in gray or silver, carbon leather, give me ping! |
07-20-2012, 06:32 PM | #37 |
Rep 1,992
The car actually has 31,000 miles and it is an M so its quite a bit more $$$ than your standard Z4. He didn't say what he actually paid for it either - probably under $30K, but nice Z4M's seem to have been going up in value lately.
07-20-2012, 07:34 PM | #38 | |
707
Here's the thread--see Ocha's caveats on the work. Mine came out okay, but if they need to break in to the diff that can be complicated. Sounds like it's just the axle though, which is a PITA but not as bad as the diff. And Ocha wasn't kidding about these being fairly common--SeanK and I were under his car on Monday while at the track, and his axle seals look exactly the same as mine did. I've added this to my "check with oil change" routine. I'm bet mine will be fine for quite some time, but it's still something to look for from time to time. SD 335is, congratulations on the find. PPI sounds like it was worth it, and I'm guessing you used the items noted to advantage in negotiations. Sounds like the interior is Jeyll to the exterior's Hyde. Interesting. Bumper can off course be fixed up. Valence and exhaust issues sound like a result of the car being somewhat "slammed" and whacking the muffler backing out of a driveway or similar situation. I wonder if the exhaust hangers need to be replaced? (Pretty cheap to do, better off with the DKF version if the rearmost are damaged.) |
07-21-2012, 02:53 PM | #39 |
///Multiple
2993
Rep 4,243
I'm finally back home after a grueling crawl through traffic yesterday. The trip home did not go as planned. I got home at 8:30 PM last night
I had planned to take Highway 1 (Coast Highway) from Monterey all the way down to Santa Monica, stopping in San Luis Obispo on Thursday night. I ended up not leaving East Bay BMW until after 5:00 PM, so I scrubbed the Coast Highway plan and took 101 to San Luis Obispo. I got to my hotel at 10:00 PM. Friday morning I got on the road at 10:30 AM and tried to get on the Coast Highway at Oxnard but the road was closed so I had to get back on the 101. Bottom line, with two gas stops and a lunch stop, it took me 10 hours to drive the ~321 miles home. Google says that it should take 6:06. At least I got really good at finessing the clutch, throttle and gear shifts in stop-and-go traffic. I discovered that Sport Mode is not for stop-and-go traffic! To answer some questions: East Bay BMW gave me a price of $29,000 on the phone on Wednesday, the day before I left to go and see it. None of the independents were open on Saturday and the closest one was booked on Friday, so I had to go up on Thursday morning. I got picked up at the airport in the Z and got to drive it back to the dealer. I was thrilled to see the car in person and on the ground, it looked like a car in Very Good to Excellent condition. As I mentioned, a lot was revealed when it was on the hoist during the PPI. I tried using this as a bargaining tool and offered $27,000, then $28,000 but they weren't budging, said that they didn't have any room on the price, and the most he could offer me was maybe another couple hundred dollars. I said that my flight up there was $250 and the PPI cost $150, how about paying for that? So they knocked off another $400 or a total of $28,600. The M Mobility System and tool pouch were missing so I told them I couldn't drive back without those, so they got them from Parts. Only after I packed the car again for the trip back home on Friday did I realize that all I got was a canister and they didn't give me the compressor. I'm going to contact them for that. The tool pouch only has a tow hook and a screwdriver, is there supposed to be anything else? It appears that there something else going on in the right rear. When I stopped for on Friday morning I noticed that the right rear bumper cover was pulled away from the body. I pushed it back in place it popped out again later. I stopped in Santa Barbara and saw Jon Shafer (Bimmerfest founder) and he had some clear packing tape that I used for a quick and dirty fix. I'm putting it up on jacks this afternoon to take a closer look. I'm guessing there might be problem with the bent stuff behind the bumper to the right of the muffler and it might involve a fender bracket or brace of some sort. I'm goig to give it a good wash first and tomorrow I may hit it with the digital orbital and polish out the paint, give it a good coat of wax and put some Zaino on the leather. The H&R springs were pretty harsh, especially on bridge joints and on the 101 which is some areas is still concrete with lots of expansion joints and tar patches. Speed bumps in parking lots need to be done at nor more than 5 MPH or it's a pretty good hit. I think my first priority is to get the right rear bumper squared away. Next I'd like to get some stock springs and replace the rear wheel wells at the same time. Thanks for all the feedback, you guys have been great!
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 12-11-2019 at 09:09 PM.. Reason: Zaino, not Zymol! |
07-21-2012, 05:23 PM | #41 | |
///Multiple
2993
Rep 4,243
07-21-2012, 08:23 PM | #42 |
Rep 1,066
no pics?
2019 Cayenne Turbo
07-23-2012, 02:01 AM | #43 |
///Multiple
2993
Rep 4,243
Sorry, only had a few hours to give it a good wash and interior cleaning on Saturday. I spent most of the day today getting it up on jack stands to get a better look at the rear fender liners, fix the left rear side marker light which had apparently come unplugged, and redistributing some of the plastic fasteners that hold the fender liner to the bumper liner since all three on the left side were missing. My wife spent a long time on the wheels yesterday and when I took off the rear wheels she decided to clean the inside of the barrels from the rear. I also attempted to bend the bent heat shield on the right side back into place which apparently happened when the car was backed into something, causing a dent in the right muffler, the bent heat shield, and the bumper cover getting melted onto the hot exhaust when the bumper cover got pushed into it.
Anyway, the first shot is from my phone shortly before I got ready to drive home. The next shots are from somewhere along Coast Highway north of Santa Barbara. Other photos can be seen on the dealer's website (link above) which is now marked as "Sold"!
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18 The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12 Last edited by SD ///M4; 12-11-2019 at 09:35 PM.. |
