FORUMS
- 5
| 05-01-2011, 05:37 PM | #1 |
![]() ![]() Drives: Sapphire Black/Black Z4Mc Join Date: Oct 2008
Rear Differential/Axle Leak
I was under the car yesterday and noticed this (see photos). The first area is on the passenger side by the differential where the axle connects to the diff. The second is a bit further up on the passenger side and on what I believe is the gas tank (it does not smell like petrol and is more lubricant-like). There are no drips or anything of that nature on my garage floor and no odd sounds (compared to Skelekitty's car). Nothing like this under hers which is clean as a whistle. The driver's side axle/diff shows something similar as well, but not as pronounced.
My major worry is that the reason things are not dripping is because there is nothing left to drip which would not bode well for the lifespan of the diff. I guess I could remove the top fill hole and check for fluid (no idea on the procedure there ). The car is still under warranty, so it's off to the dealer with it I guess. I have a good SA and shop, but I'd like some opinions on what I'm seeing here and a recommended course of action from those who are more mechanically/technically savvy than I am before doing so. Good dealer or not you never know what it will be like the next visit, and I would prefer to be prepared/knowledgeable before going. Any thoughts, ideas, advice, recommendations or you guys can offer? |
| 05-02-2011, 07:57 PM | #4 |
deft danish devil
Drives: 2007 BMW M Coupe Join Date: Apr 2009
I had the same type of leak on the input flange side of the diff. Took it to the dealer, the seal was replaced. I picked the car up, there was a bad vibration introduced at 65 mph. The driveshaft was replaced next. The vibration was still there. Next BMW secondary support recommended the entire differential be replaced. Done, and problem solved, with a new differential at 10k miles...
| 05-03-2011, 11:56 AM | #5 | |
| 05-27-2011, 05:37 PM | #6 |
Update: Pinon seal is bad. Being replaced under warranty. Hopefully I'll get the car back tomorrow (parts are due to have arrived 30 minutes ago).
![]() 2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047 |
| 05-27-2011, 07:32 PM | #7 |
50$ says they put it back together wrong, changing that seal means essentially rebuilding the diff.
| 05-27-2011, 07:51 PM | #8 |
Not going to take that bet O-Cha. You're right over 95% of the time.
So will the problems that result from putting it back together wrong be obvious? How about potentially hazardous? I have a track day coming up--I don't want the diff locking up at high speed or anything "fun" like that. Hmm, if it's essentially re-building the diff then I'd guess there's a break-in required and fluid change at 1,200. Looks like no track day in that case. Anything you can add would be appreciated.
![]() 2007 Sapphire Black Z4M / Apex EC7s / Eisenmann Exhaust / Euro Headers/Cat / Aero Sideskirts / DIY Stubby / Ultimate Pedals / AS SSK / RB Rotors / Other Stuff #1047 Last edited by Finnegan; 05-27-2011 at 08:08 PM. |
| 05-27-2011, 11:18 PM | #9 | |
PS the oil you noted on the axles IS the axle seals, but the larger amount you noted behind the heat shield is indeed the drive shaft seal, pretty much every single one leaks from the factory, this could also be CV joint grease though and not diff fluid, as this gets spun out as well if the simple paper seal is no good.
| 05-28-2011, 01:41 AM | #10 |
Thank O-Cha. That information is very helpful and appreciated!
![]() I'll make sure I ask them about all the seals and the preload. I'll just have to see how it pans out--worst case I guess I end up with a new diff which isn't the end of the world.
| 05-31-2011, 07:05 PM | #11 |
Well, the update from the dealer is that the whole thing is buttoned back up and functioning correctly. We shall see, and I'll go over the parts list with them tomorrow when I pick it up. My car was kind enough to have a headlight fail while it was at the dealership, so that was replaced (bulb, controller...ballast?) while she was in. (I'll have to thank her for her good timing.)
| 05-31-2011, 07:27 PM | #12 |
Here's hoping they got it right for you.
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
| 05-31-2011, 10:00 PM | #13 |
Thanks! Like I said, worst case it's a new diff, but having it done right the first time would be a major plus.
| 06-01-2011, 02:19 PM | #14 |
Okay, I have the car back and I can't find any issues. Pinon and axle seals replaced, car seems fine at low and high speed. Let's just say I tried it at a "range" of speeds and on corners.... I'll get to see how it feels at the track next Monday.
Other things completed while it was there: Flaw in clear plastic on top of shift knob--knob replaced under warranty.I think I've got a pretty good dealer/shop. I also think the assorted 12 packs of beer (Sam Adam's sampler this time, Sierra Nevada last time) I leave in the back of the car for the techs and my SA don't hurt either!
| 06-10-2011, 02:18 PM | #15 |
Update: Tracked the car w/o issue in the wet and dry, no issues, car feels solid and diff is working as it should.
| 07-12-2011, 05:13 AM | #16 | |
CCA member
thanks for any insight.
Magnetic oil pan, tranny & diff plugs, Redline fluids, Zeck CDV, Dinan tri-brace, ProDryS, 3M film, Alum stubby, PBR Ceramic Pads, Nitrogen! j/k !!
![]() Last edited by 330indy; 07-14-2011 at 12:38 PM. |
| 07-14-2011, 12:37 PM | #17 | |
CCA member
| 07-22-2011, 07:57 PM | #18 |
deft danish devil
| 07-22-2011, 11:45 PM | #19 |
Clearly not all service departments have the same level of skills and capabilities. Like O-Cha said, it's tricky to get this work done correctly. It's not a paint by numbers thing, and that's all most techs are capable of. This takes real mechanical skill. So yes, it is ridiculous, but not terribly unexpected given the record most dealer shops have for repairs. I base that that on what I've seen on the forum when something, like VANOS bolts or anything mechanically complicated, goes wrong.
| Bookmarks |
