09-01-2011, 10:45 PM | #1 |
Rep 12,570
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.26] |
My New Track Accessory
Using the GoPro has been a blast but past few events have had showers and thus my wipers wouldn't allow me to mount the camera on the windshield. I could use one of their adhesive backed mounts on the front bumper but that's somewhat permanent... But recently came across a tow hook adapter for the GoPro.
This is the perfect spot imo, not only is it more level with the ground but it should pick up the noise coming from the hood. Can't wait to test this out!! |
09-02-2011, 12:30 AM | #3 |
Track Head
24
Rep 503
Great location, about to do the same on my car except using a ContourHD. Also trying to find a proper way to mount the camera and get a good view of the pedals , steering inputs, etc. On most cars the sunroof works great, but the huge divider on our cars makes it a tad difficult to get the right angle.
2004 Porsche GT3 |White
HRE R40 Monoblocks | KW Clubsport Suspension | RSS Lower Control Arms and Suspension Links | GT3RS Wing and Front Bumper | Cup Car Lip | Euro GT3 Seat | GMG Half Cage | Europipe Exhaust | EPL Tuning |
09-02-2011, 01:06 AM | #4 |
Rep 231
Looks great. Where did you get it?
09-02-2011, 01:51 AM | #5 |
More of this than that!
29
Rep 817
Very nice.... please post the model and where it can be procured!
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
09-02-2011, 06:37 AM | #6 | |
Rep 12,570
09-02-2011, 06:42 AM | #7 | |
Rep 12,570
http://www.rennline.com/newssection.asp?dept=982 Few things to note though: 1) This bracket is meant to be used with their tow hook mount. However, due to the curvature of our bumper, the tow hook will NOT clear the front bumper even with the addition of extra washers. Therefore, you will have to call in your order and ask for a special order: a) tow hook screw + b) GoPro bracket but NO actual tow hook 2) As mentioned above, because clearance is an issue, you will need to also specify the need for extra washers. I don't recall how many used but I can check later today how many I used exactly that way you can specify the same number. 3) In their product link, you see the GoPro camera is mounted directly to their metal bracket. However if you look at their other picture where it's mounted on the rear bumper, you see they used one of the GoPro extensions (I believe it's the right angle arm) to get around the offset of the bumper. Because we have similar issues on our front bumper, I had to use that extension as well. FYI the extension is included with your original GoPro kit. If you are interested in this mount, I'd call Rennline directly and ask for Tom. They have great customer service and Tom was the one who I spoke to when dealing with fitment questions so he should be familiar with what you'd need to get this to work. Last edited by 3002 tii; 09-02-2011 at 09:12 AM.. |
09-02-2011, 12:06 PM | #8 |
Rep 376
I have been wanting to add a camera like this for some of my roadtrips. I really like your setup!! When it is mounted outside like that, what kind of protection does the camera lens have against flying debris?
09-02-2011, 04:37 PM | #9 |
Rep 12,570
The camera is sits inside a plastic enclosure provided by GoPro. It seems sturdy and the clasp doesn't seem like it'd come apart easily. Worst case you can buy a replacement enclosure if yours gets scratched up.
09-02-2011, 05:23 PM | #10 |
Rep 1,546
excellent! now all we need is some vids.
also, what are your settings at (to get optimal video length without sacrificing too much quality)?
09-03-2011, 12:42 PM | #11 |
Rep 12,570
My next event is in 3 weeks but this is how it looks mounted on the windshield, VIR in July:
09-03-2011, 03:40 PM | #12 |
Rep 1,097
09-04-2011, 04:05 PM | #13 |
Rep 12,570
09-06-2011, 02:03 PM | #14 |
Rep 376
I just got off the phone with Tom at Rennline. I told him I wanted a bumper mount for a Z4 and he knew exactly what the setup was. "tow hook screw and GoPro bracket but NO actual tow hook." He was very familiar with the setup for Dubbedown, so my order was a breeze. I don't think I was on the phone with Rennline more than 4 minutes and my order was complete. Thanks Dubbedown!! This is way cool. Now, all I need to do is get the GoPro!
09-06-2011, 02:28 PM | #15 | |
Rep 12,570
If you install the GoPro bracket with the screw first, and then install, the bracket may graze the bumper as you rotate it. |
09-06-2011, 03:51 PM | #16 |
Rep 273
Good idea for a mount location. I use RAM mounts for all my vehicle mounted equipment, so already have a bunch of mix and match components and device cradles. They are incredibly solid and adjustable, and once you've got a mounting solution for a new vehicle, you can mount any other device you have an attachment for.
For this, I'll just put an inexpensive RAM ball (a few dollars) on the end of a threaded rod adaptor - should work perfectly! This is RAM's GOPRO mounting system. http://www.ram-mount.com/NewProducts...5/Default.aspx |
09-28-2011, 11:33 AM | #17 |
Rep 376
Dubbedown, I haven't seen any of your videos from the bumper mount posted. How is it working out for you? Any issues with vibration or anything? Also, what is the rubber O-ring for on Rennline's screw mount for? Was that just to hold the washers on during shipping? Is it used when mounting to the bumper? Have you been able to check the # of washers you are using? I apologize for all the questions.
Since I now have this bumper mount, I ordered the GoPro last night. After looking at the videos from Cyrus on another thread, I am anxious to get going on this.
09-28-2011, 11:54 AM | #18 |
Rep 109
http://4wheelonline.com/atv/Sport_Cameras.175023 Good deals on cameras.. also have a bunch of Go Pro Hero kits.. all super cheap.
2007 Z4M Coupe - 2010 Ducati 848 - 1968 Mustang 302 |
09-28-2011, 02:14 PM | #19 | |
Rep 12,570
I do use the black rubber washer in case when I pull the mount out of the bumper, don't want to lose any white plastic washers. Plus I think it tigtenes better using that as opposed w/o it. |
09-28-2011, 04:12 PM | #20 | |
Rep 12,570
They were selling the LCD bacpac free if you purchased a GoPro at their normal retail price. Free shipping over $100 and orders ship fast... |
09-28-2011, 04:44 PM | #21 | |
Rep 376
10-05-2011, 08:13 AM | #22 | |
Rep 12,570
Bad news: Non-stop rain combined with thick fog at Watkins this past weekend, apparently the worst weather they’ve ever had (multiple crashes). Therefore did not get a chance to use the GoPro mounted to my bumper, instead ran it from the interior. OK news: Will have a chance to test it once more in 2 weeks at NJMP Lightning. |
